Latest post Mon, Mar 31 2008 3:43 PM by Marianna. 3 replies.
  • Sun, Mar 30 2008 5:29 AM
    • Posts 11,372
    • Points 233,130
    Export to Device - strange behaviour
     Well it is strange to me..... Smile
    I have output via firewire to my Sony HDV deck with no problems.
    Today I tried with a clip that had a Video Mixdown track in the timeline and I was presented with the following error.
    Exception: CM_LABEL_NOT_FOUND, tt:3,  Inum:1
    I loaded the original timeline (from which I had made the mixdown) and tried to output it - no problems!
    What is the obvious explanation that eludes me? Geeked
    Regards,
    Douglas
  • Sun, Mar 30 2008 9:15 AM In reply to
    Re: Export to Device - strange behaviour
    Hi Douglas,
    The first thing to try is mixing down the sequence again and try to export again.  Perhaps the mixdown media is corrupt.
    If that doesn't work, try making a duplicate of the sequence by first loading the sequence into the source monitor and editing it into a new timeline.  Try exporting the new sequence.  If it works, something in the old sequence is corrupt.
    If that doesn't work, the next step is creating a new user and try to output the sequence.  If it works, then your other user setting is corrupt.  If that doesn't work, create a new project and open your sequence from within it, and try to output.  If that works, then your old project settings are corrupt.
    If none of that works, when you come back tell us more about the sequence and the mixdown.  Are they the same resolution?  Same frame rate?  Is there anything about the mixdown that is different from the rest of the media in the project?
    good luck,
    Carl
    Media Composer 2020.9 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Mon, Mar 31 2008 1:35 PM In reply to
    Also double-check that the resolution of your video mixdown is compatible with your sequence and FW output.  You can't use a DNx codec if you want to putput via FW.
  • Mon, Mar 31 2008 3:43 PM In reply to
    • Posts 11,372
    • Points 233,130
    Thanks for the input, Carl and Kevin.
    I have not had a chance to try any of the suggestions yet.
    Luckily my discovery is not a big threat .  . . .  .  so I will try later in the week to find the cause of the problem.
    Regards,
    Douglas
