Latest post Sat, Mar 29 2008 5:57 PM by jamdivo. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Mar 29 2008 6:20 AM
    • jamdivo
    • Posts 8
    • Points 80
    HDV Playback issues
    Hello everyone: I have done some research about this problem but I haven´t found any reference to it in the forums. I am running MC on a laptop for quite a while, for the first time I am working on a HDV project. I had some problems with deck control while capturing the media but playback was fine. As I kept having more material digitized, playback problems arouse, first skipping audio and video while playing and some crashing. This seemed memory a problem so I began freeing memory space: stoped some processes, halted startup programs, computer performace maintenance... The persisting problem which I haven´t been able to solve is that video seems to be stable during playback but audio is delayed and echoed. I am using an HP ZD8000 Laptop 2 gb ram 2.8 P4 external HD 7.200 rpm Every help is must welcome :) Cheers! Jorge Divo
  • Sat, Mar 29 2008 9:49 AM In reply to
    Re: HDV Playback issues
    Try moving some media to your internal drive to test out wether your external HD is fast enough for HDV...
    MC 7.0 Symphony 7.0 Win 7 64bit 1 x XW 8600 quad 16gig ram 480gig SSD FX 5400 4 1tb 32 mb cache drives Pro tools 10 Avid fx Avid 3d Matrox... [view my complete system specs]
  • Sat, Mar 29 2008 10:17 AM In reply to
    Hi Jorge,
    What kind of audio & video cards do you have on the system?
    good luck,
    Carl
    Media Composer 2020.9 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Sat, Mar 29 2008 2:41 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Hello, thanks for answering. Actually, I had all the media in the internal drive and moved ir to the external because of the playback issue. I agian did what you sugested, moved some clips to the internal drive and disconected the external, but still it does the same. I believe that ther should be some setting in the laptop that onflurnces this. Still am on the same spot, Thanks
  • Sat, Mar 29 2008 2:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Could you do us a favor and list the system specs for that laptop, Including the Audio and Video cards please?
  • Sat, Mar 29 2008 3:09 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Hello, The audio card is altec lansing, I hag got no furhter specs. The vido card is ATI Mobility Radeon X600, 128 mb. I am still trying to workout what is going on for, as I sayd in the first post, at the beguining playback had no problems. Thanx
  • Sat, Mar 29 2008 3:37 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Ok, here is the update. I just switched the playback to half resolution and it is playing properly. This gives me some tranquility but leads me to believe that it is a memory issue. The media is still in the external drive. Any sugestions? Thanks
  • Sat, Mar 29 2008 5:49 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Hello Blkdog, the system specs: Brand: HP Product Line: Pavilion Notebook Operating System Compatibility: PC Operating System: Windows XP Home Processor Manufacturer: Intel Processor Type: Pentium 4 Processor Speed: 2.8 GHz Bus Speed: 800 MHz Level 2 Cache: 1 MB Hard Drive Capacity: 80 GB Installed Memory: 2 GB Maximum Supported RAM: 2048 MB Video Card Type: ATI Mobility Radeon X600 Video Card Memory: 128 MB Sound Card Type: Altec Lansing As I refered in my last post, I believe it is a memory issue because I can playback with no problem in low res. Though I will not need high res for editing, I will surely need it for D-Cut. Thank you for your help. Jorge
  • Sat, Mar 29 2008 5:57 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Re: HDV Playback issues - Last Update
    After dealing with several processes, cleanups and system performance routines, I have managed to playback in all availabel resolutions with no visible problems. I will keep testing to hopefully have steady stable performance. Please, If you have more suggestions I will suerely appreciate them. I will post further results. Thank you all, Jorge
