Latest post Thu, Mar 19 2009 6:02 PM by mjolnarn. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Mar 19 2008 5:29 PM
    • XCHC2006
    • Joined on Tue, Mar 18 2008
    • Posts 6
    • Points 90
    Avid Media Composer - "failure to initialize audio hardware"
     I just loaded  Avid Media Composer  and as the program is initialize when it gets to "initializing audio I get error message that says "failure to initialize audio hardware. Any ideas?
  • Wed, Mar 19 2008 5:41 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: Avid Media Composer - "failure to initialize audio hardware"
    This is usually due to an incompatibility between the Audio card and the software. Check the system requirements to be sure you have a qualified card and are running the correct drivers for your software version.
  • Wed, Mar 19 2008 6:07 PM In reply to
    • XCHC2006
    • Posts 6
    • Points 90
     Does anyone know what the name of the right Realtek driver I should have?
  • Wed, Mar 19 2008 6:09 PM In reply to
    Search the forums for "realtek" and you should get an answer in there.  One caveat, though; I've only seen a couple of posts where a driver update fixes the problem.  Most people wind up getting a Soundblaster Audigy 2 card.
    good luck,
    Carl
  • Wed, Mar 19 2008 8:34 PM In reply to
    • XCHC2006
    • Posts 6
    • Points 90
    So best think to do is get the Soundblaster Audigy 2 card. by putting that in it will over ride the sound card that came with my comp.?
  • Wed, Mar 19 2008 8:44 PM In reply to
    I can't guarantee, but I can tell you that I've been on this board since before 2005, and I've seen literally hundreds of posts from people with audio card problems just like yours, and I've never seen a post from anyone who did not solve the problem after getting a Soundblaster Audigy 2 card.  If you search the forums for "realtek" you'll find a lot of these posts if you'd like to read through them.
    I belive all you have to do is tell Windows (via the sound settings) to use the Soundblaster card rather than the onboard audio card.
    good luck,
    Carl
  • Tue, Mar 17 2009 9:10 PM In reply to
    • carlmarx
    • Joined on Tue, Mar 17 2009
    • Posts 4
    • Points 50
    Hi there folks
    What Soundblaster Audigy 2 card, anyone recommend  one as there are quite a few different models.
    Carl
  • Tue, Mar 17 2009 11:33 PM In reply to
    • carlmarx
    • Posts 4
    • Points 50
    Forgot to add...I need a sound card, suitable for the new  version of "Media Composer" due for release this month, upgrading from"Xpress Pro HD v5.1"....
    I currently have "Realtek HD audio" which does not work with my "Xpress Pro HD".
    Regards
    Carl
  • Wed, Mar 18 2009 4:51 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,365
    carlmarx:
    I am using an audigy 4 on one sys and an XFi Elite Pro on another, different price tags for them but both works well.
    As other users have told, I am sure that an Audigy 2 also will work well.
    Tomas
  • Wed, Mar 18 2009 4:32 PM In reply to
    • carlmarx
    • Posts 4
    • Points 50
    Thanks Tomas for the advice.
    Installed creative 7.1 Audigy SE Sound card and works, but when I import file, audio is out of sync, Any ideas what is the cause for this???
    Regards
    Carl
  • Wed, Mar 18 2009 5:28 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Very good that it works for you now.
    About the OOS prob, I have no idea, importing a file should never affect the sync, what type of file was it and what was your settings in the import dialogue.
    And, you have of course disabled the onboard audio from bios ... ?   sorry but I had to ask.
    Tomas
  • Thu, Mar 19 2009 11:38 AM In reply to
    • carlmarx
    • Posts 4
    • Points 50
    Hi Tomas
    The file was MPEG4...I think that might have been the problem
    Carl
  • Thu, Mar 19 2009 6:02 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,365
    Very good
    Tomas
