Latest post Wed, Jun 6 2007 1:23 PM by cashin. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Jun 5 2007 5:16 PM
    • cashin
    • Joined on Tue, Jun 5 2007
    • US
    • Posts 13
    • Points 145
    Exception: ADM_DIO_ERROR_OCCURRED
    Capture window displays only top half with no way of expanding lower region.  Received the following error message upon engaging V1, A1 & A2 tracks in capture window.  If I reinstall Avid Xpress Pro will I lose my media files or timelines?
    Exception: ADM_DIO_ERROR_OCCURRED, DIOerr: PMDIOParser Helper::Parse-error occurred in parser TSPPacket sync byte is invalid-sync-byte: 0 X 0
    \devices\digitalio\Pyromaniac\PMDIO Tester\ MPEG Parser\ TSPParser.cpp
    251
    iMac (Retina 5K, 27-inch, 2020) Proc: 3.6 GHz 10-Core Intel Core i9 Mem: 128 GB 2667 MHz DDR4 Gfx: AMD RAdeon Pro 5700 XT 16GB OS: Catalina... [view my complete system specs]
  • Tue, Jun 5 2007 5:22 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,945
    • Points 82,935
    Re: Exception: ADM_DIO_ERROR_OCCURRED
    Without having any info on your system, versions or setup i will be guessing.,... try to run the Avid installer and it will prompt you with a repair option as well. That will be non destructive... do backup the project files before proceeding just in case.
    Menno
    @VPRO and NTR The Netherlands 40+ systems [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
  • Tue, Jun 5 2007 7:35 PM In reply to
    • cashin
    • US
    • Posts 13
    • Points 145
    Thank you very much.  I'll try the Avid installer repair this evening.  Here's my system info:
    Avid Xpress Pro HD (version???  purchased March 2007 at B&H, NYC)
    PC with Intel 2.4GB Dual Core
    2 X 1GB memory
    Windows XP Professional- service pack 2
    nVidia GeForce 7600 GS GPU with 512MB GDDR2 memory
    Quicktime 7.1.6
    PCI to 1394 (firewire 800) card
  • Tue, Jun 5 2007 7:41 PM In reply to
    ettajames:
    Knowing your version number is ESSENTIAL to trouble-shooting.  Telling us when/where you bought it means nothing.
    Quicktime 7.1.6
    Also, this is not supported yet.  But likely is not the cause of your issue.
  • Wed, Jun 6 2007 9:00 AM In reply to
    • cashin
    • US
    • Posts 13
    • Points 145
    Great,
    I'm running Avid Xpress Pro HD 5.2.1
    (Correction) Quicktime 7.1.5
    Windows Media Player 10 (how can I be sure I'm running the v9.5 codecs?)
    After a thorough reinstall of first my video card driver and then Avid,
    I am still experiencing problems.  My capture tool only displays its top two sections with no way to expand the lower sections.  When I engage V, A1 & A2 on the capture tool, I receive the message "No signal present" when my deck is plugged into the firewire port that's built into the motherboard.  If I engage the V, A1 & A2 on the capture tool when the deck is plugged into my firewire to PCI card, I receive a different message:
    Exception: ADM_DIO_ERROR_OCCURRED, DIOerr:PMDIOParserHelper::Parse - error occurred in parser TSPPacket sync byte is invalid - sync_byte: 0x0
    \devices\digitalio\Pyromaniac\PMDIOTester\MPEGParser\TSPParser.cpp
    251
    There is one device that registers as not working with my computer's device manager: nVidia WDM Video Capture (universal) "This divice cannot start. (code 10)"
  • Wed, Jun 6 2007 12:55 PM In reply to
    What FireWire capture card are you using?.... the onboard?
  • Wed, Jun 6 2007 1:03 PM In reply to
    • cashin
    • US
    • Posts 13
    • Points 145
    Card:  Koutech 3+1 Port FireWire
    http://www.newegg.com/Product/Product.aspx?Item=N82E16815104224
    Motherboard: Intel BLKDG965WHMKR
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813121053
  • Wed, Jun 6 2007 1:18 PM In reply to
    • Baklap
    • Posts 6,945
    • Points 82,935
    can you check and see what chipset is on this? You can see that in the device manager under 1394 plus sign.
    Menno
    Twitter Account
    My Keys
  • Wed, Jun 6 2007 1:23 PM In reply to
    • cashin
    • US
    • Posts 13
    • Points 145
    Texas Instruments OHCI compliant IEEE 1394 Host Controller
    Unibrain driver / OHCI Compatible Board
    I don't know which is the card and which is the motherboard
