Latest post Tue, Mar 25 2008 7:31 PM by rustybucket. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Mar 23 2007 11:34 PM
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    5.7** Exception:FILE_OTHER, filename:D:\OMFI MediaFiles....
    I just upgraded and install AXP 5.7 and everything went smooth.  I click on a clip to play and I get the above message.  I've searched the forum and nothing seems to help.
    (1.) I did go to media tool and tried to play a master clip from there with no success.
    Any ideas?
    HP dc7700 @ 2.13 ghz Intel Dual Core 2cpu XP service pak 2 (2002 v.) 3.5 gb ram nvida Quadro FX 1500 [view my complete system specs]
    Legal Cutter "The most successful people are those that are good at plan B."
  • Fri, Mar 23 2007 11:58 PM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    Re: 5.7** Exception:FILE_OTHER, filename:D:\OMFI MediaFiles....
    When I try to capture I get the following message "Exception: Video signal but not captured." can this be related?
  • Sun, Mar 25 2007 5:53 PM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    Bump
  • Sun, Mar 25 2007 7:45 PM In reply to
    what is the complete message?
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Mon, Mar 26 2007 5:34 PM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    JK,
    I get the following messages:
    "Exception: FILE_OTHER, filename:K:\OMFI Media Files\NewTape401.45EDF.8EA8DO.omf"
    "Exception: SYS_ERROR, status:1453,msg:Insufficient quota to complete the requested service.
    and when I captre I get the following message:
    "Exception: Video signal present but not captured"
    any ideas or sugguestions
  • Mon, Mar 26 2007 5:38 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,944
    • Points 82,400
    sounds like a corrupt file or folder. Rename the OMFI media files folder on th edrive with problems and try again. If that works start moving batches of media from the renamed folder back to the newly created by Avid. Do not move the 2 MSM files.
    Menno
    35+ MC's - 224TB Isis - 2.2 PB Spectra T950 - Interplay - 2 Media Central's - 3 TM's - 2 STP's - 500 TB Isilon - 2 Vantage - MOG SPeedrail... [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
  • Mon, Mar 26 2007 7:31 PM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    Baklap...Capture queston
    Baklap,
    I was able correct my OMFI issue.  However, I am stilling getting my capture error message. "Signal but not capturing."
    I up graded to 5.7 and never had the message with 5.6  before but I think the problem in in my Res:  When I have it set to D25 411 MXF I get the error message but when it is set to 15:1s MXF it captures fine.
    I am using the Canopus ADVC 100 from a sony deck.  What should be my setting and how can I us D25 411MXF without getting any error message?
  • Mon, Mar 26 2007 7:40 PM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    Re: Baklap...Capture question
    Now it's not capturing at all.  I get the following message.
  • Mon, Mar 26 2007 9:29 PM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    I've switched from MXF to OMF res: and I'm still getting the below message:
    "Exception: Video Signal Present but not captured"
    I've reinstalled the Nvidia drivers, still same problem.  I've uninstalled and reinstalled 5.7 but no success.  Should I try to roll back to 5.6.4 and see if I can get back to where I was last week?
    Any ideas welcomed!!
  • Mon, Apr 2 2007 12:56 AM In reply to
    • illini2000
    • Joined on Sat, Mar 31 2007
    • Posts 9
    • Points 105
    I'm having the same problem.  The issue is not present when I use avid 5.7 in windows xp.  I posted the issue elsewhere since I saw no answers to your post.  It doesn't make any sense because the video plays through just fine but won't capture.
  • Wed, Aug 8 2007 1:32 AM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
    illini,
    Did you ever get the problem fixed?  I had to roll back to 5.6 because for some reason 5.7 will not  work on my system....any ideas?
  • Tue, Mar 25 2008 5:32 PM In reply to
    Joining the bandwagon here.... video plays fine but will not capture.  Get the 'Video present, but not cpatured' error.....
    Using a mac g5 with 5.7 and just upgraded to 5.8 and having the same exact problems.....  Anybody know of a fix  for this?  Or what's happening with it?
  • Tue, Mar 25 2008 6:29 PM In reply to
    • patrickgi
    • Los Angeles
    • Posts 114
    • Points 1,300
     Once I replaced my Videocard with a recommended video everything worked out fine.
  • Tue, Mar 25 2008 7:23 PM In reply to
    rustybucket:
    Is this the same system as the one in your posts in this post in the Xpress Pro - Mac forum?
    good luck,
    Carl
    Media Composer 2020.9 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Tue, Mar 25 2008 7:31 PM In reply to
    Yes, it is.  Still getting the "Exception: Video signal present but not captured" error when trying to capture from the GL2
    patrickgi--> I checked my video card, It meets specs as far as I can tell:  ATI Radeon 9600 (128mb).  This ok?
    Edit:  Sorry, I didn't realize this was the PC forum....  Anyways, seems that an error this specific would have more to do with Avid than OS.....?
