Latest post Fri, Mar 9 2007 6:37 PM by Danebo. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Mar 8 2007 5:11 PM
    • Danebo
    • Joined on Mon, Apr 10 2006
    • Posts 18
    • Points 240
    How to do a simple Matte Key
    I'm having trouble getting a matte to work. I have 3 elements one is my backround video, the second is my video I want to cut and third is my white matte key with alpha. If someone can show me step by step on how to do this that would be great. I've tried the Help menu in Liquid, but I can't find it.
    Dane
    KIMA-TV Promotions
    AL7.1 build 3494 Windows XP Professional Service Pack 2 Dell Precision 530 Radon 9800 Xeon,2 gig dual processers 2 gig ram 400 gig hard drive Deck, Sony DSR-1500 Fire Wire Dual Monitors, 2 Princetons 21"
  • Thu, Mar 8 2007 6:58 PM In reply to
    Re: How to do a simple Matte Key
    No sure about liquid, but in Media Composer it's done like this:
    V1= background video
    V2= fill video for foreground
    V3=stencil white on black for matting
    Place a matte key effect from the effect palette on V3 and you're good to go. You may need to play with invert key and swap sources.
  • Thu, Mar 8 2007 7:02 PM In reply to
    • LewS
    • West Palm Beach, FL
    • Posts 10,277
    • Points 132,650
    • Moderator: MCA PC
    Create a matte track. Click on the track header of the track you want to matte where the track name is. Add a matte track from the menu and place you matte graphic on that track. That should do it.
    3.15GHz E8500 CPU, Intel MB w P35 chipset, 4GB memory, Pioneer DVD burner, onboard audio, nVidia Quadro FX1700 512MB , 2TB (4 x 500GB) Raid 0 on Vantec... [view my complete system specs]
    LewS
  • Thu, Mar 8 2007 7:57 PM In reply to
    • Smetvid
    • Madison, WI
    • Posts 468
    • Points 6,315
    There is a whole chapter in the PDF manual on track mattes.  Go to Reference Manual : Edit : Special Functions : Matte track and track mattes.
    If you want to use video clips as your matte you must make sure it matches the resolution of the timeline.  If the resolution does not match the matte will not work automatically and you will have to drag the track matte cpu effect to your matte clip.
    For DV projects the matte clips actually have to be 720x486.  That is because of Liquid using 720x480 and 720x486 for the same project.  720x480 clips will work but you will have to add the track matte cpu filter.  Clips at 720x480 with an alpha channel may or may not work.  It really is best to stick to 720x486 for the mattes however because they work 100% of the time for me.  In fact I even encode SD mpeg files as high profile and so I can encode them at 720x486 so they will work as mattes.  Mpeg2 files seem to be the pickiest of all the formats when it comes to working as a matte.  If you keep to the strict standards then you should have no problem.
    Still image mattes seem to not have as many restrictions placed on them.
    System A: P43.2 875 chipset 1GB ram 256MB 9600 pro video. Liquid Pro System B: P43.0 HP laptop 512MB ram 128MB ATI video. Liquid System C: P42.4 845... [view my complete system specs]
    Coming soon! Liquid editing tools, tutorials and media/FX content. www.Smetware.com
  • Thu, Mar 8 2007 8:12 PM In reply to
    • LewS
    • Posts 10,277
    • Points 132,650
    • Moderator: MCA PC
    The matte master has spoken.
    LewS
  • Thu, Mar 8 2007 8:15 PM In reply to
    • Danebo
    • Posts 18
    • Points 240
    I will try your suggestions and let you know my results,
    Dane
  • Thu, Mar 8 2007 10:48 PM In reply to
    • KBKM
    • Joined on Fri, May 12 2006
    • Germany
    • Posts 80
    • Points 1,050
    I have never really worked with matte and would be very interested to see what you want to archieve and how the "in between" results and the final result looks like.
    Maybe you can explain a little more detail with some files to show what you mean.
    Would be great
    KBKM
    My system specs: WIn XP SP2, Pentium 4, 3,2 GHz, 2 GB RAM, ACPI Multiprocessor PC, 2x ATI Radeon X600 graphic card, 305 GB video raid on SCSI drives, a Maxtor 6B160MO, Silicon Image SiI 3114 SoftRaid 5 Controller
  • Fri, Mar 9 2007 1:15 AM In reply to
    • Danebo
    • Posts 18
    • Points 240
    I got it, I will use this effect in my next promo.
    Thanks to all.
    Dane
  • Fri, Mar 9 2007 1:48 AM In reply to
    • sam the sham
    • Apple Valley, Ca
    • Posts 925
    • Points 11,795
    KBKM:
    Would be great
    KBKM
    You can view a "How-To" Matte video here: http://www.pinnaclesys.com/publicsite/us/Tutorials/Online+Tutorials/
    MC 6.0.3.1 thank you very much, FCP X v.10.2.3, MAC Pro, 2 @ Intel Quad-Core Xeon 2.4 GHz,(Westmere),12gb 1066mhz DDR3 ram, ATI RadeonHD 5870 1GB. 3@ 1TB... [view my complete system specs]
  • Fri, Mar 9 2007 6:37 PM In reply to
    • Danebo
    • Posts 18
    • Points 240
    KBKM,
    What I did is I went into the PDF help menu, page 477 I think and printed out the step by step ways to make a matte. The PDF has pictures so it's really easy to follow. I can't upload from my computer (not allowed), good luck.
    Dane
