Latest post Thu, Apr 4 2024 8:53 PM by ChrisH. 13 replies.
Page 1 of 1 (14 items)
  • Sat, Nov 18 2006 1:46 PM
    • avid andy
    • brooklyn
    • Posts 10
    • Points 180
    corrupt bin crashes avid? Any techniques to fix?
    Hi I was working on a sequence in 5.6 when suddenly there was a power interruption while I guess the computer was writing to disk. When I re-opened the project - it would crash when opening the bin that had the sequence I was working on.
    I moved the bin out of the project temporarily and the project opened, but not I cannot open that bin either in the project or via import.
    Is there any tricks I can use to open or repair that bin or is it lost to me forever? I've been using avid for years and this is the first time this has ever happened to me.
    Windows PC/3 Ghz Pent 4. 1 GB Ram Matrox Parahelia Windows XP (SP2) Addonics eSata Storage System Avid Xpress Pro 5.6 Sony DSR-40 Deck [view my complete system specs]
  • Sat, Nov 18 2006 2:16 PM In reply to
    Re: corrupt bin crashes avid? Any techniques to fix?
    Have you tried to salvage it from the Attic?
  • Sat, Nov 18 2006 2:35 PM In reply to
    • avid andy
    • brooklyn
    • Posts 10
    • Points 180
    Yes. I have, but the version in my attic comes before the sequence I'd like to save, so I am hoping to find a way to pry open the one one that wont open
  • Sat, Nov 18 2006 2:48 PM In reply to
    Maybe try starting a new project and opent the bin?
    Other than that, I'm kind of stumped. Sorry
  • Sat, Nov 18 2006 5:03 PM In reply to
    No additional ideas about the Bin ... but, running Avid for years and no Battery Backup?
    (wwld)
  • Sat, Nov 18 2006 5:31 PM In reply to
    I guess the problem is not with Avid but with windows. Writing seems to be interupted because of the power problem. File might be physical corrupt. Do a windows disk check.
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 4x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC latest, Mojo... [view my complete system specs]
  • Mon, Nov 20 2006 2:20 AM In reply to
    • avid andy
    • brooklyn
    • Posts 10
    • Points 180
    Unforunately I am on a remote shoot up in alaska. I have to work with what I have at the moment ->
    I won't be a dead horse , but here is the current run down.
    The media seems to not be corrupt. The clips themselves are fine. The bin containing  several sequences crashes avid when I try to open it, or any recent one from the attic or from a backup of the project files. Really old versions of this bin do open.
    I've started a new project and copied the files over - that didn't work. I hid all the media, and refreshed the databases - still - avid crashes when I attempt to open this one bin.
    I've even run some diagnostics on the drive. The drive is healthy and fine. The file however is not.
    Any last ditch methods to saving this bin and it's sequence before it's time to just recut it from scratch?
  • Mon, Nov 20 2006 3:40 AM In reply to
    Last ditch efforts:
    In the Settings folder, under Avid, trash MC State, Site Settings, and Site Attrributes.
    In the Project folder, trash the Project Settings file (.avs).
    Launch Avid and create a new User Profile.
    Turn off Render-on-the-fly prior to opening the Bin.
    Moving forward ... I always have a Bin called Sequence Backups.  Periodically, I make interim copies of Sequences, store them there, and keep the Bin closed when not in use.  A closed Bin is less likely to get corrupt in the event of a system crash.  For a larger project, create multiple Backup Bins.  These are in addition to any other copies you make for offsite storage.
    (wwld)
  • Wed, Nov 22 2006 1:47 PM In reply to
    • avid andy
    • brooklyn
    • Posts 10
    • Points 180
    just to bring this thread to a conclusion - I found the problem:
    I had installed a trial of a 3rd party plugin. THe plugin had expired while  I was cutting with disastrous results. It caused avid to crash and when it came back up the bin was totally inaccessible.
    When I removed the plugin from the plugin directory. The bin and it's attic cousins became accessible again - so i don't have to recut this sequence again.
    Hopefully this helps someone someday.
  • Wed, Nov 22 2006 2:18 PM In reply to
    Wow... what a nightmare, but luckily you don't have yourself stuck doing extra work just before the holiday.
    Thanks for posting back.
  • Wed, Nov 22 2006 4:04 PM In reply to
    Turning off Render-on-the-fly is a test that can isolate that kind of problem.  If Avid "can't" process an effect, it'll crash.  The expired plugin would have been impossible to process.
    (wwld)
  • Mon, Sep 28 2009 11:26 AM In reply to
    • SimRah
    • Joined on Tue, Feb 17 2009
    • Melbourne, Australia
    • Posts 13
    • Points 155
    It helped me! Thanks guys, you saved me half a days work with this discussion!
    Regards
    SimRah
    avid andy:
    AVID Media Composer Version 3.0 (2008); Windows XP-Pro (Version 2002) with Service Pack 3; Intel Core 2 Duo Processor E8400 @ 3.0 Ghz with 3.25 Gig of... [view my complete system specs]
  • Tue, Sep 24 2013 11:23 PM In reply to
    • shcuts
    • Joined on Sun, Feb 12 2012
    • Posts 18
    • Points 180
    I know this post is ancient but this helped me out today and I just wanted to say thanks.
  • Thu, Apr 4 2024 8:53 PM In reply to
    • ChrisH
    • Joined on Thu, Sep 4 2008
    • Posts 133
    • Points 1,685
    This solved my problem... in 2024! Thanks Randall!
    Work: Freelance, so usually a recent-ish Media Composer and NEXIS Home: MC24 and up, OS Sonoma, iMac Pro 2017 [view my complete system specs]
