I'd like to know a solvable workflow for this. Can I import into AXP native HDV and then transcode to DNxHD - then transfer the media to the symphony? What is the easiest way to do this???
Thanks.
We recently began using the Convergent Design w/ the Sony HVR-M25 into SN 1.6.1, and ...it works! It is slow sometimes to initially recognize the deck, and seems to work best using the 'generic edit deck' template, rather than the Sony HDR-500 that Symphony seems to think is connected. Batch digitizing goes fairly well over multiple clips, althought there is the occassional hiccup that usually requires exiting and reentering capture mode.
For evaluation, we tested the Miranda, which was not as responsive, and this, combined w/ pretty poor experience w/ the Miranda DV Bridge back when led us to the Convergent, which in itself only seems like a bandaid until Sony (or Someone) builds an actual HDV edit deck w/ proper I/Os, etc.
Keith
