Latest post Tue, Mar 25 2025 6:21 PM by Marianna. 3 replies.
  • Mon, Mar 17 2025 9:52 AM
    • Lewis Holleran
    • Joined on Thu, Dec 8 2022
    • Edit123, Glasgow
    • Posts 4
    • Points 40
    Exception: MXFIndexTableMapperSegmented::ReadRange - ANC Essence Data Key not found at expected offset
    * Exception: MXFIndexTableMapperSegmented::ReadRange - ANC Essence Data Key not found at expected offset
    Getting the above exception with some footage which was transcoded to DNxLB in 24.10, across a couple of cameras, if I load the clip to the composer window and scrub this exception appears.
    If I deselect the data track & disable data track monitoring then I can scrub without the exception appearing.
    So it would seem some data track info is corrupt, or is the culprit at least.
    How can I resolve without reingesting this footage?
    Cheers!
  • Wed, Mar 19 2025 4:58 PM In reply to
    • Posts 12,083
    • Points 261,695
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Re: Exception: MXFIndexTableMapperSegmented::ReadRange - ANC Essence Data Key not found at expected offset
    Lewis
    The ony way I know is to remove the data tracks that are corrupt and re-ingest the footage.
    You can try to go  to your Avid MediaFiles folder and delete the two media databases: msmFMID and msmMMOB. Delete these two files and exit the Avid MediaFiles folder. See Refreshing Media Databases.
    Then try it again before you resort to re-ingesting.
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Tue, Mar 25 2025 3:21 PM In reply to
    • Lewis Holleran
    • Edit123, Glasgow
    • Posts 4
    • Points 40
    Hi Marianna,
    Thanks for getting back to me, I'll try rebuilding the databases and see how it goes.
    I'm hoping we can avoid it as it's only really an issue when we match frame, once it goes to online we'll be conforming so that should fix and data track issues at that point.
    I think I'll wait until the project is finished, go back and try see if the database rebuild works so I'm not disturbing the edit at the moment.
    Will feed back!
    Cheers,
    L
  • Tue, Mar 25 2025 6:21 PM In reply to
    • Posts 12,083
    • Points 261,695
    • ! Avid Employee
      ForumsAdministrator
    Thanks so much.
    Looking forward to hearing as I have 2 others wiht the same thing and if they get back to me - I will report back to you.
