Latest post Sat, Dec 7 2024 8:31 PM by Philip Kapadia. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Nov 28 2024 8:14 PM
    Screengrab function
    There is a feature in PP, "Export Frame" with a camera icon, that takes screengrabs and stores then wherever you want.  Does MC have the same function at all?
    D.
    Avid MC (2024.10) - Computer: New Build - Motherboard: Gigabyte Z790 Gaming X AX DDR5 Motherboard. Processor: Intel Core i9 13900KF 3.0Ghz 24 Core LGA... [view my complete system specs]
  • Thu, Nov 28 2024 8:24 PM In reply to
    Re: Screengrab function
    Park on the frame, rightl click the viewer > export > graphic then choose a jpg or a tif and export it to whereever you want. Little bit long-winded but same result.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2022.10 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
  • Sat, Nov 30 2024 11:33 AM In reply to
    Thank you, Andi
  • Sat, Nov 30 2024 1:59 PM In reply to
    Also, does MC have a Global FX Mute button?
  • Sun, Dec 1 2024 3:43 PM In reply to
    An editor friend of mine coming from PP asked me the same question and I asked here. The lovely Phillip was kind enough to provide a workaround which basically accomplishes the same thing. Not quite as elegant but it does allow you to play through a sequence without getting slowed down
    https://community-azure.avid.com/forums/p/233700/959906.aspx
    Andi
  • Mon, Dec 2 2024 8:56 PM In reply to
    Hi Andi,
    Coming back to screengrabs, your suggested method does not seem to work.  See below,
  • Tue, Dec 3 2024 7:58 PM In reply to
    I don't understand? When you hit save it will save a TIFF to wherever you set your save loction?
  • Thu, Dec 5 2024 4:27 PM In reply to
    Thank you.
    But why is it when you solve one problem, another arises?  So, I've just followed the process and the TIFF saved in the Pictures folder (I thought originally it had gone to desktop, so my bad there). But then when I move the playhead and seek to take another screengrab from here, following the same process only now adapting the file name so as to create anew rather than overwrite, the image captured is exactly the same as the first one.  In short, now moving the playhead makes no difference; only the first playhead position seems to be the only image captured.  Weird.  Please advise, DC
  • Thu, Dec 5 2024 4:30 PM In reply to
    Figured it.  I had the in-point marked, and when saving the "Use Marks" option is ticked.  Just unmark the timeline and then you can take as many different screengrabs as you like.  Thank you for your help, D.
  • Fri, Dec 6 2024 5:52 PM In reply to
    Glad you got it working.
    Andi
  • Sat, Dec 7 2024 8:31 PM In reply to
    An alternative way of quickly exporting a frame from your sequence without configuring a JPEG export is to print your composer window.
    Highlight your record monitor, then click CTRL+P, then save to PDF.
    Media Composer should then generate a PDF, I've attached an example (download in Microsoft Edge). You can configure the print settings to make the PDF as large as the frame
    Freelance Film Editor | Technical Expert @ Avid
    [email protected]
    My Equipment & System Specs
