Latest post Tue, Apr 8 2025 1:42 PM by Robert Martindale. 28 replies.
Page 1 of 2 (29 items) 1 2 Next >
  • Mon, Nov 4 2024 12:18 AM
    • mglpost
    • Joined on Wed, Jan 18 2012
    • Posts 10
    • Points 180
    Media Composer 2024.10 Title tool
    Cheers for getting the Titler+ tool up and running! I've been putting it through its paces, and I've got a couple of suggestions that would really speed up the workflow:
    1. Fine-Tune with Arrow Keys: Once text is selected, it’d be a massive time-saver if we could adjust size, kerning, etc., with arrow keys + modifiers. Right now, clicking around to change these settings is painfully slow, and dragging to resize lacks precision.
    2. Pixel-Based Sizing: Can we move to pixel sizing instead of rounded numbers? Every agency and brand I've worked with demands pixel accuracy (150px, 72px, etc.). When a client says they want the title at 150px, the current tool leaves us guessing.
      3. Certain fonts are not displaying correctly, but in Photoshop etc that are?
      Would love to see these changes.
  • Mon, Nov 4 2024 7:41 AM In reply to
    Re: Media Composer 2024.10 Title tool
    Is there a way to save multiple styles with font, color, etc. for future use without saving all the other parts of the title?
    If a title is dropped into a bin, can you tell it to only save certain parameters?
    I9-NVidia3060-160ram-WIN11PRO-MC25.06-NewBlueFX-Photoshop-Shutter Encoder-Boris Continuum 12.5-VLC Player-Resolve 19.1.4-I5-M4 MacMini 16g RAM... [view my complete system specs]
  • Mon, Nov 4 2024 7:42 AM In reply to
    Skewing objects such as boxes is not possible, only fonts?  If not, please add that.
  • Mon, Nov 4 2024 12:42 PM In reply to
    • AvidElad
    • Joined on Wed, Mar 28 2018
    • Posts 35
    • Points 445
    • ! Avid Employee
    mglpost:
    Hi mglpost and thenaks for the feedback.
    • Fine Tune with Arrow Keys: We will look into additing keyboard shortcuts for some of the most common functionalities. FYI, Text Justification (CTRL+SHIFT L/R/E), Kerning (ALT+Left/Right) are currently avilable. Also, for now, you can also use the Effect Editor and move through the different parameters using Tab and input precise values in the process.
    • Pixel Based Sizing: We will look into adding a setting to use pixel based values. the benefit of having the current system value is that it is consistent regardless to the raster size.
    • Fonts display issue: Could you please provide examples and or screenshots? Note that based on users feedback we've decided to reflect to the user is a font is not supported on a given lanuage - other applications are falling back to a default font without the user knowing about it, so it is not necessary that PS display the correct font.
  • Mon, Nov 4 2024 12:45 PM In reply to
    • AvidElad
    • Posts 35
    • Points 445
    • ! Avid Employee
    Robert Martindale:
    Currently, it is only avilable while saving it as template in a bin which saves everything. However, it is possible to apply parts of the save template into a selected object by:
    1. Selecting the new object.
    2. From the bin drag your template with the desired style onto the desired parameter group of the selected object.
    For example, is you wish to use the template's font, you can drag the template onto the Font group of the selected object.
  • Mon, Nov 4 2024 12:46 PM In reply to
    • AvidElad
    • Posts 35
    • Points 445
    • ! Avid Employee
    Robert Martindale:
    Thanks, you are correct. We'll add that as a feature request. Thanks
  • Mon, Nov 4 2024 4:21 PM In reply to
    • Posts 12,182
    • Points 262,760
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    mglpost:
    mglpost......
    Got this and adding it to the titler + product board for consideration.  If the team has questions on your suggestions or needs more deets, they will reach out and ping you at your @me.com email address.
    Thanks for this....
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Tue, Nov 5 2024 12:12 AM In reply to
    Great tip....dragging the template on to an object works well.....thank you.....
    Has this always been true and i just missed it?
  • Tue, Nov 5 2024 10:14 AM In reply to
    • AvidElad
    • Posts 35
    • Points 445
    • ! Avid Employee
    Robert Martindale:
    Glad to hear! Yes, it was always been working like that :) with MC you learn new things every day :)
  • Tue, Nov 5 2024 10:16 PM In reply to
    I never really got this far before...some issue always came up.....nice to have a basic titler in place that works and does not crash or glitch when it animates.....
    ....the interface always baffles me a bit with the split screens for the titler dedicated window and it all being duplicated in the effect controls....now, i can get used to it....
    ...and there is no doubt you have to be sure only the track you are working on is active.....or the titler may seem to be unresponsive....
    .....if it works...lets work it....start by doing a basic tutorial on filling in letters with video.....
  • Wed, Nov 6 2024 11:05 AM In reply to
    • AvidElad
    • Posts 35
    • Points 445
    • ! Avid Employee
    Robert Martindale:
    The Dashboard is there to provide users with the essential tools in one place - you can probably get 90% of your title edits in there (excluding keyframing).
    However, if you find it redundant or diruptive, with the new version 24.10 the choice is yours. You can go to Settings > User > Effect Editor and uncheck "Open Dashboard Automatically". This way, whenever you go into Effect Mode on a Title the Dasboard won't come up. (at any give time you could click the dedicated button in the Effect Editor toolbar to bring it if desired.
    The auto track monitor is a nice request. I'll log it in our system as a potential feature request.
    As for the Fill Replacment, I do hope a tutorial will be generated soon, until then the process is rather simple:
    1. Create your Title
    2. In the Effect Editor: Set Foreground > Fill Overlay to 100 (should turn fill to black (transparent) at this stage)
    3. In the Timeline: Step-in to your title segment and add media to sub-track 1.2 (fill)
    Now you should see the media in 1.2 coming through your title - Here's my shiny gold text:
    Elad
  • Thu, Nov 7 2024 10:57 AM In reply to
    nice....and golden for sure....thanks for the information....it appears that everything in the title is changed with the bgnd change....so, any outline or shadow also gets filled in...
    is there a way to have video in the main text and keep the outline?  Just a guess that would mean creating duplicate titles and laying the outline only title on top of the orgiinal.....
  • Thu, Nov 7 2024 1:35 PM In reply to
    AvidElad:
    Thanks Elad, I just created this KB article: How to place a video inside text with the Avid Titler +
    Freelance Film Editor | Technical Expert @ Avid
    [email protected]
    My Equipment & System Specs
  • Thu, Nov 7 2024 2:08 PM In reply to
    • AvidElad
    • Posts 35
    • Points 445
    • ! Avid Employee
    Robert Martindale:
    Correct, the media is applied to the foreground of the affect and therfore affecting all object's fill. As you've mentioned and as you can see in my example, you can simply duplicate the layer and add your outline and/or shadow.
    Philip Kapadia:
    AvidElad:
    Philip, thats great, thanks.
  • Fri, Nov 8 2024 9:10 AM In reply to
    the tutorial is a decent starting point.....suggest you add the tip about shadow and outline.....
    also, the video fill can be easily manipulated for size/position/cropping/color, so editors can get the exact fill they want if the video has movement or different highlights....example...wanting a flag waving in the font...if the fill is not changed for size, only a small portion of the flag will show....
