Latest post Fri, Oct 18 2024 10:21 AM by Philip Kapadia. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Oct 5 2024 11:57 AM
    Sudden problem linking to MXF files
    Hello,
    This one has really flummoxed me!
    So I've been sent a drive of footage to edit, all shot FX6 XAVC, intra 422. So far so normal. But I just can't link to or import the footage (see attached). Shows 'Can't be linked'.
    It's very weird because on the same drive is a previous project, shot with the same cameras in the exact same format, and I can link to that fine with MSP_MXF plugin (see second part of attached). What changed?!
    I can play the problem footage in Catalyst Browse and VLC so I know the media is there and plays.
    I've tried copying to a different drive, and also opening a new project without success.
    I'm going to ask for the footage to be sent again but as I can actually play it in other apps I'm not sure that will help.
    Anyone have any bright ideas? It's driving me crazy!
    Many thanks
    Dylan
    Editing on iMac / Ventura / Media Composer Ultimate 2024.6
  • Sat, Oct 5 2024 1:47 PM In reply to
    Re: Sudden problem linking to MXF files
    I would try linking the files on a different Avid system to learn more about this.
    Will that different Avid system have no issues...or the same as you've described?
    -Telegram!
  • Sun, Oct 6 2024 3:29 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,184
    • Points 50,505
    Have you tried manually selecting how Avid is trying to link the footage? I have had cases where it says "Can't be linked" but I forced Avid to use one or the other methods available. Good luck, Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Mon, Oct 7 2024 9:36 AM In reply to
    Hi Jef,
    Thanks for this. Can I make sure I'm doing what you suggest correctly?
    In the input/link window I'm right clicking the Plug-in column - where it currently says 'can't be linked'.
    The drop down gives me a 'link with' option - Autodetect, Canon XF Plugin for AMA, MXF, UME link.
    In the previous files I've been working with - which link OK -  I've seen Avid is using 'MXF' of these options, and 'UME' when there's a MP4 wrapper.
    Sadly I can't link with these or any of the options.
    I also tried to download the Nablet AMA plugin, but that hasn't helped either.
    Last resort - asking to be sent the rushes again in case there was an issue there.
    Thanks again,
    Dylan
  • Mon, Oct 7 2024 12:24 PM In reply to
    Do you have the entire folder structure of the media intact?
    Have you tried to link by volume to the folder structure?  You have to clip a box in source browser to do that. See below. Top left square.
    https://avidtech.my.salesforce-sites.com/pkb/servlet/rtaImage?eid=ka96e0000008df3&feoid=00N6e00000HSEt1&refid=0EM6e000006nFHI
  • Sat, Oct 12 2024 11:39 AM In reply to
    Thanks for this,
    I can't figure out how to get that list of plug-ins in the Console though - that's would be useful.
    Just FYI the only workaround I've figured out is to use Sony Catalyst to re-export all the files, same as source.
    And for some reason those files are then readable by Avid.
    No idea what that tells me about the original issue.
  • Wed, Oct 16 2024 3:26 PM In reply to
    Hi Dylan, check the naming of the folders in your path where your footage is, that you are trying to link to. Make sure there are no special characters (. /, etc.) in the name of the folders and try again. good luck Howard
  • Thu, Oct 17 2024 8:06 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 325
    • Points 4,035
    I'd also recommend installing the Nablet AMA plug-in. https://nablet.com/xavc-xdcam-ama-plugin
    HP z240, HP z440, HP z840, HP Z4 G4, HP Z2 mini G4, Z2 mini G5, Dell Precision 3430 and 7810, Apple iMac 27-Inch (2019). All are 32GB-64GB of RAM. nVidia... [view my complete system specs]
  • Fri, Oct 18 2024 10:21 AM In reply to
    Hello Dylan,
    Are you in a position to email me a very small sample of these clips which won't link, for me to test and analyze in my lab?
    Freelance Film Editor | Technical Expert @ Avid
    [email protected]
    My Equipment & System Specs
