Latest post Fri, Nov 1 2024 12:17 PM by ugo1. 7 replies.
  • Fri, Sep 20 2024 4:19 PM
    • ugo1
    • Joined on Thu, Jul 13 2006
    • Italy
    • Posts 293
    • Points 4,025
    panasonic gh7 prores raw import problem
    hi, I'm trying to import a apple pro res raw file from gh7 but I'm not enable to do it I use latest video drivers on windows 11 and 64GB of ram Iìm using the latest version of mediacomposer trail version regards ugo
    Case: Phantek Enthoo Luxe, Motherboard: Asus Prime WS299 Sage/10G, Cpu: Core i9-10920X,Ram: 32GB Ripjaws 4, GPU: Asus Nvidia Rtx 2080 Super 8 GB, Sound... [view my complete system specs]
  • Fri, Sep 20 2024 4:28 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 322
    • Points 4,010
    Re: panasonic gh7 prores raw import problem
    Did you install.. Apple ProRes RAW for Windows 1.3 System Requirements: Windows 10 64-bit File Size: 837 KB https://updates.cdn-apple.com/2020/windows/001-36880-20200831-dd7a918b-e5de-4145-add4-c835639d9476/ProResRAW.msi This software enables playback of ProRes RAW and ProRes RAW HQ video files in compatible applications on Windows systems.
    HP z240, HP z440, HP z840, HP Z4 G4, HP Z2 mini G4, Z2 mini G5, Dell Precision 3430 and 7810, Apple iMac 27-Inch (2019). All are 32GB-64GB of RAM. nVidia... [view my complete system specs]
  • Sat, Sep 21 2024 6:28 AM In reply to
    • ugo1
    • Italy
    • Posts 293
    • Points 4,025
    yes is installed regards ugo
  • Sat, Sep 21 2024 9:15 AM In reply to
    • ugo1
    • Italy
    • Posts 293
    • Points 4,025
    I have the same problem with project in prores HQ 422 made withg gh6 that haven't any problem with older version of media composer. Which is the solution? Regards ugo
  • Sat, Sep 21 2024 11:45 AM In reply to
    • ugo1
    • Italy
    • Posts 293
    • Points 4,025
    Hi, I create a new user and old project play again. With proes raw file I get this error Videoeffectconsumer -- unexpected status returned from renderefffect any idea? REgagards Ugo
  • Sun, Sep 22 2024 2:06 AM In reply to
    rewrapping the files in Shutter Encoder to ProRes might fix this as a temp solution.
    Or flip them to some other format.
    I9-NVidia3060-160ram-WIN11PRO-MC24.10-NewBlueFX-Photoshop-Shutter Encoder-Boris Continuum 12.5-VLC Player [view my complete system specs]
  • Mon, Sep 23 2024 11:27 AM In reply to
    • ugo1
    • Italy
    • Posts 293
    • Points 4,025
    Hi yes only prores raw doesn't work regards ugo
  • Fri, Nov 1 2024 12:17 PM In reply to
    • ugo1
    • Italy
    • Posts 293
    • Points 4,025
    I can't try Media composer 2024.10 are now the problem solved?
    Regards
    Ufo
