Latest post Wed, Jul 9 2025 4:22 AM by superboy520. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Jul 28 2024 10:57 AM
    • xudon
    • Joined on Tue, Apr 15 2014
    • Posts 16
    • Points 210
    Getting access token in CTMS
    Hi All,
    I was following instruction on getting access token in authentication. In Authorization header, i need to enter Base64 encoded payload<Application ID:Application Secret>. Where can I get app ID and app Secret from? Is it my system admin? or do I need to apply to it or where?
    I'm working on converting interplay SOAP web services calls to Rest API calls.
    Thanks a lot for the help!
    Don
    Filed under: , ,
  • Sun, Jul 28 2024 12:08 PM In reply to
    Re: Getting access token in CTMS
    Hello Don,
    Which instructions were you following? Could I get a link to that documentation for context?
    Freelance Film Editor | Technical Expert @ Avid
    [email protected]
    My Equipment & System Specs
  • Mon, Jul 29 2024 12:06 PM In reply to
    • xudon
    • Posts 16
    • Points 210
    Here is the link for the steps i followed, i stuck on the step 3.
    https://developer.avid.com/cert/getting_started_with_ctms/guide.html
  • Tue, Jul 30 2024 11:50 PM In reply to
    Apologies for my delayed response. I notice this is for CloudUX.
    Could you send me an email so I can get you in touch with a developer or an individual who can answer this?
    [email protected]
  • Thu, Aug 29 2024 9:22 AM In reply to
    Hi all,
    I also ran into an issue when trying to generate an access key on the MCCUX REST API.
    I registered a test app in my Marketplace Seller account to create App ID and Secret. The status currently is "In Review". I base64-encoded the string <App-ID>:<Secret> and used it as Authorization Header (prefixed with "Basic ").
    I tried both, Postman and curl. However, I am not able to get an access token back. The error message is "Unknown client or client authentication failed." I strictly followed the instructions on
    but without luck. Then I tried to execute the call with curl directly from the CUX host itself - same error message.
    Does anyone know a missing bit over here? I welcome any idea that could help.
  • Tue, Jun 3 2025 10:56 PM In reply to
    Hi Andreas Hartmann Drift boss
     I'm also having the exact same error, even though I've checked the App ID and Secret carefully, and encoded correctly, it still says "Unknown client or client authentication failed". Tried both Postman and curl but they didn't work, making me suspect that the app might be in "In Review" status. I don't know if anyone has passed this step, I really need more specific instructions.
  • Wed, Jul 9 2025 4:22 AM In reply to
    Hi Andreas Hartmann Sprunki Abgerny Thank you. Welcome to the wild, unpredictable world of the Abgerny Game Online!
