Latest post Thu, Aug 29 2024 9:22 AM by Andreas Hartmann. 4 replies.
  • Sun, Jul 28 2024 10:57 AM
    • xudon
    • Joined on Tue, Apr 15 2014
    • Posts 16
    • Points 210
    Getting access token in CTMS
    Hi All,
    I was following instruction on getting access token in authentication. In Authorization header, i need to enter Base64 encoded payload<Application ID:Application Secret>. Where can I get app ID and app Secret from? Is it my system admin? or do I need to apply to it or where?
    I'm working on converting interplay SOAP web services calls to Rest API calls.
    Thanks a lot for the help!
    Don
    Filed under: , ,
  • Sun, Jul 28 2024 12:08 PM In reply to
    Re: Getting access token in CTMS
    Hello Don,
    Which instructions were you following? Could I get a link to that documentation for context?
    Freelance Film Editor | Technical Expert @ Avid
    [email protected]
    My Equipment & System Specs
  • Mon, Jul 29 2024 12:06 PM In reply to
    • xudon
    • Posts 16
    • Points 210
    Here is the link for the steps i followed, i stuck on the step 3.
    https://developer.avid.com/cert/getting_started_with_ctms/guide.html
  • Tue, Jul 30 2024 11:50 PM In reply to
    Apologies for my delayed response. I notice this is for CloudUX.
    Could you send me an email so I can get you in touch with a developer or an individual who can answer this?
    [email protected]
  • Thu, Aug 29 2024 9:22 AM In reply to
    Hi all,
    I also ran into an issue when trying to generate an access key on the MCCUX REST API.
    I registered a test app in my Marketplace Seller account to create App ID and Secret. The status currently is "In Review". I base64-encoded the string <App-ID>:<Secret> and used it as Authorization Header (prefixed with "Basic ").
    I tried both, Postman and curl. However, I am not able to get an access token back. The error message is "Unknown client or client authentication failed." I strictly followed the instructions on
    but without luck. Then I tried to execute the call with curl directly from the CUX host itself - same error message.
    Does anyone know a missing bit over here? I welcome any idea that could help.
