Hi IanD
What version of Media Composer are you running?
In the source browser, what plug-in is the system using to link to the files? If you click on the plug-in, are there other choices available?
try flipping a test file in Shutter Encoder to MP4 and see if that works.......feels like a weird codec issue....
try flipping a test file in Shutter Encoder.....
Shutter Encoder does have a batch import function....so you can get all this done at once
IanD:I put one of the MP4 files through Handbrake and had it formatted as an MP4, and this new file does get imported by Avid and plays with no issues. While this is a solution, I would rather find a solution with Avid, as reformatting dozens, if not hundreds of files would take an incredibly long time and be inconvenient, to say the least.
IanD:the only recent activity that could have caused the problem is with OBS, my recording program: after updating it, recorded files didn't show thumbnails in Windows, but downloading a codec resolved the issue, and they play fine in file browsers, just not in AVID.
From the description of the problem it sounds like something changed in OBS, so I'd start looking there to see if there's a setting/workflow adjustment you can make that will make the recordings compatible again.
The other way you could go is see if OBS has a specific plug-in for Avid you could install that will allow linking to work properly.
Glad you were able to get it sorted out!
