Latest post Sat, Jun 8 2024 1:55 PM by Telegram!. 1 replies.
Page 1 of 1 (2 items)
  • Wed, Jun 5 2024 8:30 PM
    • rcooper
    • Posts 100
    • Points 1,490
    changing audio clip color by mic
    Is it possible to apply a different color to each track of a polyphonic audio clip? For example: Trk 1 Mix; Trk 2 Boom; Trk 3 character #1; Trk 4 character #2; Can each of these tracks have their own color that can be visible in the timeline? thanks roger
    MAC pro OS 12.6.8, 48 GB 1866 MHz DDR3 RAM, 3.5 GHz 6-Core Intel Xeon E5, MC vers. 2024.2.0, AMD FirePro D500 3 GB [view my complete system specs]
  • Sat, Jun 8 2024 1:55 PM In reply to
    Re: changing audio clip color by mic
    I just checked this on v.2021 (pc), and yes, there's a Local Color workaround that goes like this:
    Take your .wav master clip and create a new sequence with it;
    Add Local Color to each clip per track;
    optionally, you can Re-Name the tracks;
    then Lock that Sequence, drag copy to a bin where you eventually can use it as a Source;
    When you edit from this .Wav-turned-into-Local-Color sequence, your clips/tracks appear on Timeline with your local colors intact. (when you edit from the masterclip, they do not)
    "Timeline Local" must be enabled in your Timeline Fast Menu. Clip Color> View Setting, of course.
    -Telegram!
