I believe Avid (quietly) discontinued support for Firewire after version 2023.3.1.
If you can roll back to that version or earlier, capture should work normally. MC 2022.12.8, for instance, is still available in the downloads area.
Thanks for the info. Glad you found a working solution.
My experience capturing with 2023.3 was on macOS, so I can't speak to why Windows had issues with this version.
The DSR-11 was the first deck I ever bought, over 20 years ago; great little deck. In those days I captured via a Mojo. These days I only have one deck for legacy HDV and DVcam, the JVC HD BR50. Fortunately that has HDMI out and RS422 deck control, so I capture via an Ultrastudio 4K Mini. It's better than firewire since it has error correction and it scales to DNxHD 1080 very nicely. Maybe OHCI drivers have changed too in Windows, that make firwire play less nicely, with some versions of the now deprecated Firewire capture in Avid.
