Latest post Sun, Mar 31 2024 6:04 PM by Philip Kapadia. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Mar 28 2024 7:21 AM
    • monkeyberry
    • South Africa
    • Posts 647
    • Points 7,985
    Changing multiple clips of group audio
    MC 2023.8.2
    Hi, would like to find out if there is a method to speed up a process.
    I have an entire timeline of hundreds of clips,  all of them are group clips.  I am currently manually right clicking on the groups audio and the drop down appears and then I select the correct track in the group.  Is there a way to somehow select the whole tracks clips and get it to do a global select of a certain track in the group?  Currently it will take forever to right click every single clip in the timeline.  (it should have been laid up correctly when started but it wasnt)
    System Specs Sufficient :) [view my complete system specs]
  • Sun, Mar 31 2024 6:04 PM In reply to
    Re: Changing multiple clips of group audio
    It would take you longer to find a workaround than to just grind through the sequence.
    Not in front of an avid right now so can't find one for you but might look when I get back
