Hi all,
I've recently puchased MC Ultimate 2023.12.0 running on iMac Retina 5K 27" 3.6 Ghz 8-core Intel i9 March 2019, AMD Radeon Pro 580X 8 GB, Memory 64 GB, OS Sonoma 14.2.1
Testing the system both ways -- from media on a 12GB SanDisk drive and Samsung T7 Shield.
Both times playing down a 28min seq of the last show I worked on, with no other applications running or bins open. My CPU usage soars to 147% and CPU temp increases. I did turn off PhraseFind Indexing as it almost fried my CPU over 76C/1269F.
I tried to clear bin memory under the About Avid Media Composer Configuration and memory still spikes.
Is there a setting I need to set to keep this from overheating my CPU?
Thanks in advance,
~ JG33
Hi JG33,
Is the media that you are playing back already transcoded or linked? as linked media are usually processor intensive.
Ajay
On MacOS, a fully utilized core is counted as 100% in the Activity Monitor. An 8 core CPU fully loaded is equal to 800%. 147% seems normal.
DQS
www.mpenyc.com
