Latest post Tue, Feb 20 2024 3:21 PM by Aarolian. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Feb 15 2024 8:44 PM
    • Aarolian
    • Beacon, New York
    • Posts 25
    • Points 325
    Multi Pass H.264
    I've been trying to lay off a 48 minute film using the H264 multipass setting. I have a 250GB C drive. I'm getting a window that states that the drive is full. Is there a way to bypass the C drive or some other option. Thank you.
    Dell Precision 5820 Tower, 4.1GHz CPU, 128GB RAM, 250 GB Operating Drive, 25TB Internal drives. [view my complete system specs]
    Filed under: , ,
  • Thu, Feb 15 2024 8:47 PM In reply to
    Re: Multi Pass H.264
    In your export settings you should be able to choose another drive. Do you have one?
    Media Composer 2024.2 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Feb 15 2024 9:22 PM In reply to
    Is that a Quicktime preset? I would absolutely ignore that and use the modern MOV or MP4 export tabs in stead. Way faster an better color management.
  • Fri, Feb 16 2024 2:25 PM In reply to
    • Aarolian
    • Beacon, New York
    • Posts 25
    • Points 325
    Yes. I have 5 other drives.
  • Fri, Feb 16 2024 6:59 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 306
    • Points 3,805
    Check under Settings > Project > General and adjust your Temp path to a different drive in additional to making sure your media creation settings and export settings are also on your desired drive.
    Job ter Burg:
    And because the modern way doesn't let you set keyframes or control how the bitrate is apportioned at all, you may end up with horribly blocky frames following major scene (image) changes.
    For sure the new way is fast but quality may vary. While the old way is slow and dependable.
    HP z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, HP Z2 mini G4, Z2 mini G5, Dell Precision 3420 & 3430, Dell Precision 7810, Apple iMac 27-Inch... [view my complete system specs]
  • Tue, Feb 20 2024 3:18 PM In reply to
    • Aarolian
    • Beacon, New York
    • Posts 25
    • Points 325
    Will do. Thanks.
  • Tue, Feb 20 2024 3:21 PM In reply to
    • Aarolian
    • Beacon, New York
    • Posts 25
    • Points 325
    I think it has to do with the temp folder on my C drive. I'm trying to remove files to make more space on the drive.
    I emptied the temp folders but that wasn't enough. I only have 25GB of free space.
