Latest post Wed, Feb 14 2024 5:12 PM by IF.... 4 replies.
  • Sun, Feb 11 2024 1:46 PM
    • IF...
    • Joined on Wed, Feb 8 2006
    • Posts 80
    • Points 1,050
    Workstation for Media Composer 22.10
    Hello everyone,
    I should buy a workstation to edit small (from 2 minutes to 20 minutes) project in 1080p importing files shooted in 4k H265. I usually link and trascode same as source, same framerate, HQX.
    I was looking for HP Z series with Intel Xeon. These cpus have lower frequency than Intel i9 13900k.
    My question is:
    Is it better spend 1200 euros for renewed HP Z4 with Xeon W-2123, 64gb ddr4, quadro p2000... Or buy i9 13000k, Motherboard Asus tuf gaming Z790, ddr5 64gb 6000mhz with my old gtx 1060 6gb ram to build a custom pc?
    Thank you all
    Custom PC: MC 2018.12.15| Cooler Master Silencio 550 | Motherboard Asus Maximus Formula V | Xeon 1270v2| Ram 32GB Corsair VengeanceLp 1600Mhz | Nvidia... [view my complete system specs]
  • Mon, Feb 12 2024 5:17 AM In reply to
    • IF...
    • Posts 80
    • Points 1,050
    Re: Workstation for Media Composer 22.10
    Please, could someone shares its custom pc.
    1 win/mac
    2 avid vers.
    3 custom build
    4 issues/no issues.
    It could be an interesting archive for everyone.
    Thank you all.
  • Tue, Feb 13 2024 12:57 PM In reply to
    Ok, My main edit system:
    - Custom built
    - Ryzen 7 3700x
    - 64GB of Crucial DDR4 RAM running at 3200MHz
    - Nvidia RTX A4000
    I would go down the custom build route if I were in your position. It's more affordable to build your own system. But be careful, Your system won't be 'Avid qualified', meaning we can only offer best-effort support.
    The most important component in an unqualified setup is its graphics card. Almost any mid/high-level CPU can run Media Composer, but GPUs need qualified drivers to run the latest AI engines well. Script Sync/PhraseFind indexing, Temporal, spatial, colour encoding adapters, some effects including colour grades, and UME transcoding/exporting are all GPU accelerated.
    For serious editing, you should have 32GB of RAM minimum, and 64GB recommended. This means you can set a higher media cache/video memory so more frames can be cached to RAM instead of constantly reprocessing.
    philip.kapadia@avid.com
    My Equipment & System Specs
    Media Composer & Nexis ACSR
  • Tue, Feb 13 2024 2:27 PM In reply to
    • IF...
    • Posts 80
    • Points 1,050
    Thank you very much. So appreciate. ❤️
  • Wed, Feb 14 2024 5:12 PM In reply to
    • IF...
    • Posts 80
    • Points 1,050
    Hello again...
    So with I7 13700KF, asus Tuf z790, DDR 5 64gb, Gtx 1060 6gb (will upgrade later) nvme 1tb (OS), external ssd 800 MB/s.. Would be enough to edit 4k DNxHR HQX footages?
    Thank you all.
