Marianna et al,
Can you please advise what is the current status of the fix for AJA hardware? AJA engineering has advised me that they are continuing to wait on a fix from Avid. The Avid internal issue IDs are:
MCDEV17407
MCCET-5232
We still cannot move our shop off MC 2021 because playback stutters thorugh the AJA hardware on all 2022 and 2023 releases.
rockpaperscissors: Marianna et al, Can you please advise what is the current status of the fix for AJA hardware? AJA engineering has advised me that they are continuing to wait on a fix from Avid. The Avid internal issue IDs are: MCDEV17407 MCCET-5232 We still cannot move our shop off MC 2021 because playback stutters thorugh the AJA hardware on all 2022 and 2023 releases.
Hi Rob,
We made a follow up to our Engineering team for the status of the bug. We will update you once he heard back from the team.
Ajay
Hi Marianna & Ajay,
Has there been any movement on this? We're still running MC2021 as anything newer produces unusable playback on the AJA devices.
rockpaperscissors: Hi Marianna & Ajay, Has there been any movement on this? We're still running MC2021 as anything newer produces unusable playback on the AJA devices.
This is still a work in progess that the team is continuously working on. I made a follow up to the team and asked for the details.
Is there an update on this issue? We are plagued by the playback issue.
Hi Carr-Hughes Productions
I made a follow up about the MCCET-5232 bug last week. As per checking this bug is in the top of the to do for our developers.
I will make another follow up to it.
Has any to-do been done on this?
Ajay Yumul: Hi Carr-Hughes Productions I made a follow up about the MCCET-5232 bug last week. As per checking this bug is in the top of the to do for our developers. I will make another follow up to it. Thanks, Ajay
I'm also interested to learn if, when and in which version(s) of media composer the issue with AJA hardware will be resolved.
I have several customers reporting the laggy performance after upgrading to media composer 2022, 2023 and 2024.
Avid reseller ACSR at Telmaco
http://www.telmaco.gr/en/
Hey there Jeroen
I just checked the bug MCCET-5232 and looks like AJA is working on a fix right now and are testing it. We should know more in the next week.
Ping me on email.....
[email protected]
