Another joyful creation of programmers.
I have been installing new versions of MC for many years.
This time, the Repair and Remove checkboxes appear during the installation.
No matter what I do, MC 2023.3 installs no MC 2023.8
ZFigas
MC 2023.8 installed without problems but two of the new features don't work.
When I try the 'Create script from clip' feature I get the following error:
Next, when using the 'Phrasefind AI' feature there is a Phrasefind Index error and the status indicator stays red.
I used the features in different projects and with different languages and have the most recent language pack installed.
Is anybody else experiencing the same problem?
Dell M5760 - Intel Core i9 - 64 gig RAM - Windows 11 Pro - NVIDIA RTX A3000 & Intel UHD Graphics - Media Composer 2022.10 w/Symphony/ScriptSync/PhraseFind options - 4TB Thunderbolt drive - 4 TB eSata Raid box - Pro Tools 2022.10 - Nuendo 12 - DaVinci Resolve Studio 18 w/micro panel & UltraStudio Pro - Wacom Intuos
I installed MC2023.8 without problems, but two of the new features don't seem to work.
When I try the 'Create script from clip' feature I get an error window with the following text:
AvNN Error 275
Connection refused
Message=
name= Connection refused
className= class Poco::Net:ConnectionRefusedException
AvNN Error: 275
When I use the 'Phrasefind AI' feature I get an index error and the status indicator stays red.
I used both features in different projects and different languages and I did install the most recent language pack.
Does anybody else experience the same problems?
Would appreciate you comment.
limeli1: I installed MC2023.8 without problems, but two of the new features don't seem to work. When I try the 'Create script from clip' feature I get an error window with the following text: AvNN Error 275 Connection refused Message= name= Connection refused className= class Poco::Net:ConnectionRefusedException AvNN Error: 275 When I use the 'Phrasefind AI' feature I get an index error and the status indicator stays red. I used both features in different projects and different languages and I did install the most recent language pack. Does anybody else experience the same problems? Would appreciate you comment.
Hello,
Can you email me your system ID for the Media Composer and I'll have someone from the team to check on it.
Please send it to: ajay.yumul@avid.com
Please copy and paste the inquiry as well.
Ajay
FWIW, same error here.
EDIT- Fixed by clean installing. Assume folks have goitten the word by now.
Good news. This was on the top of the fix list and is fine in v 2023.8
Bug Number: MCCET-5022. Copying and pasting keyframes in the Effects editor did not work
for all properties.
The clean install of 2023.8 as suggested is next.
I would like to complete and close the problem raised by me. I am 100 years old and always installed new versions in the same way, I uploaded the new version, then unzip and install.exe.
Now I did the same, the Repair and Remove screen appeared.
I tried both, after Remove I did install from disk
and I installed version 2033.3 (!!!). I completely do not understand how it is possible that after running Install 2023.8, version 2023.3 is installed.
I did otherwise, uninstalled MC 2023.3 in Control Panel and then installed 2023.8 via Avid Link.
And now it's OK.
However, I find the Repair and Remove screenshot on 2023.8 installation to be highly misleading. And for this, MC 2023.3 is installed.
Regards
I tried to do a clean install of 2023.8 four times.
Twice it worked with all the defauts. Twice it failed when the install folder location was changed to another drive.
It is installed now but why this behavior?
I'm trying to give this transcripting a go but getting this error.
Error creating script for 'clip name':
AvNN Error: 916, Setup failed
Hi there
You are right-clicking on one or more selected clips in your bin and then choosing “Create Script from Clip” -correct?
Is tht when you see the eror?
A few notes
When searching for numbers in a transcription, use Arabic numerals (e.g. 100) instead of spelling them out with text (e.g. one hundred).
Transcripts created with 2023.8 are not compatible with older versions of Media Composer. However, older scripts, which have already been created, will migrate without an issue.
Yes.
I am getting the same error on AMA;d and inported clips 0 some short :35 secs and some long 30 minutes.
Just tried the new 2023.8.1 and still getting the error:
ck123: Just tried the new 2023.8.1 and still getting the error: Error creating script for 'clip name': AvNN Error: 916, Setup failed
Can you email me your Media Composer system ID and and I'll have the team check on this issue.
