Latest post Tue, Aug 29 2023 1:05 AM by durchell. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Jul 28 2023 3:41 PM
    • ChrisH
    • Joined on Thu, Sep 4 2008
    • Posts 133
    • Points 1,685
    Can't type metadata into bin column/Can't populate custom columns
    Hi all
    If I type text into a custom metadata bin column (Text view), nothing shows up. If I type into a default column such as "Comments", nothing shows up, but if I switch to Script view, whatever I type in "Comments" DOES show up. I f I switch back to text view, it's missing from "Comments" again.
    My assistant on the same NEXIS project on a PC doesn't have this issue. In fact if I type into a column on my system, it's blank, but the text I typed shows up on his system.
    TIA,
    Chris
    Mac Studio
    OS 12.6.6
    Avid MC 2022.12.4
    Work: Freelance, so usually a recent-ish Media Composer and NEXIS Home: MC24 and up, OS Sonoma, iMac Pro 2017 [view my complete system specs]
  • Sat, Jul 29 2023 6:08 PM In reply to
    • Polar-Bear
    • Joined on Mon, Dec 28 2020
    • Zurich, Switzerland
    • Posts 15
    • Points 230
    Re: Can't type metadata into bin column/Can't populate custom columns
    Hi Chris
    I'm having this issue with sequences on 2022.12.4 on a Mac Pro 7,1 running Monterey. Absolutly no metadata entry possible for sequences except start TC and name. With masterclips and subclips it works fine.
    This problem occurs with newly created projects on 2022.12.4 as well as with migrated projects created in 2021.12.6 and earlier where it worked flawlessly.
    This is a real bummer as I used to burn in metadata from the sequence bin columns with the burn in effect (costum columns mainly) a lot.
    Would be nice to see a fix very soon.
    Cheers
    Lars
    Media Composer 2023.8.2 on Mac Pro (16c, 192 GB, W5700X, Monterey) // Mac Studio (M2 Max, 32GB, Ventura) // Macbook Pro (M1 Pro, 16GB) [view my complete system specs]
  • Wed, Aug 2 2023 3:23 PM In reply to
    • ChrisH
    • Posts 133
    • Points 1,685
    That is a pain, Lars. I might ask around and see if the issue can be escalated.
    Hopefully sorted soon, Cheers.
  • Wed, Aug 2 2023 3:41 PM In reply to
    • ChrisH
    • Posts 133
    • Points 1,685
    Marianna is looking into this for us, she beat me to it, haha Big Smile
  • Thu, Aug 3 2023 12:08 AM In reply to
    • Jared
    • Joined on Tue, Aug 15 2017
    • Posts 14
    • Points 140
    I've run into this as well (in 21.12.9), and rolled back to 21.12.8 for the time being.
  • Thu, Aug 3 2023 9:40 AM In reply to
    • ChrisH
    • Posts 133
    • Points 1,685
    Good to know, thanks!
  • Mon, Aug 28 2023 5:52 AM In reply to
    • durchell
    • Joined on Mon, Aug 28 2023
    • Posts 2
    • Points 10
    Has this issue been sorted yet? Manythanks
  • Tue, Aug 29 2023 1:05 AM In reply to
    • durchell
    • Posts 2
    • Points 10
    Any response from Marianna?
  • Wed, Aug 30 2023 8:46 PM In reply to
    • aynsb
    • Joined on Thu, Oct 20 2011
    • Posts 56
    • Points 600
    Hi folks,
    I am also having this issue.  Thanks for documenting!
    So, to clarify, this is an issue in 2022.12.4, 5, 6, and 9 but not 2022.12.8?  Jared, rolling back to 2022.12.8 worked for you?
    Thanks!
  • Thu, Aug 31 2023 4:17 AM In reply to
    There's no 2022.12.5/6/7/8/9 yet. 2022.12.3 does not have this bug. 2022.12.4 does.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Thu, Aug 31 2023 5:01 PM In reply to
    • aynsb
    • Posts 56
    • Points 600
    Ah thanks, Job ter Burg.  I misread some of the other posts as referencing 2022 when they were actually 2021, and was very confused.  Thanks for setting me straight!
