Latest post Tue, Jun 6 2023 8:19 PM by DStone. 12 replies.
Page 1 of 1 (13 items)
  • Thu, May 18 2023 9:40 PM
    • OscarL
    • Joined on Thu, May 18 2023
    • Posts 6
    • Points 100
    Choppy Quick Transition
    Hi there,
    I am trying to add some dissolves between some clips in my sequence. For some reason the dissolve is smooth in some places and choppy in others. I have tried adding the transition with rendering, adding without rendering, and shifting the transition in different ways within the sequence. Also, the choppiness is there regardless of the type of quick transition and the number of frames which it lasts.
    Would love some help, thanks!
    Filed under: ,
  • Fri, May 19 2023 8:30 AM In reply to
    Re: Choppy Quick Transition
    Hi Oscar,
    What type of media are you trying to transition between, is it Avid managed?
    Does it happen with other sequences or just this sequence?
    Freelance Film Editor | Technical Expert @ Avid
    [email protected]
    My Equipment & System Specs
  • Fri, May 19 2023 5:12 PM In reply to
    • OscarL
    • Posts 6
    • Points 100
    Hi Philip,
    The media is Avid-native and it happens in other sequences as well.
  • Fri, May 19 2023 5:25 PM In reply to
    WHat happens if you do a video mixdown of a few seconds before, over the transistion and then after.
    How does that play? smooth or choppy?
    T 07581 201248 | E [email protected]
  • Sat, May 20 2023 4:39 PM In reply to
    • OscarL
    • Posts 6
    • Points 100
    Still choppy with the mixdown.
  • Sun, May 21 2023 4:06 PM In reply to
    Are there any indicators on the TC track? These would be blue, yellow, or red lines where the playback is choppy.
    Media Composer 2024.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 64gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Sun, May 21 2023 4:38 PM In reply to
    • OscarL
    • Posts 6
    • Points 100
    Nothing there. I have noticed that there is a small green dot on top of the transition which is smooth which is absent from the ones that are choppy. Even though I rendered all of the effects equally do you think there's anything there?
  • Mon, May 22 2023 4:43 AM In reply to
    Can you post a screenshot of the timeline showing a choppy and a smooth transition?
  • Mon, May 22 2023 9:14 PM In reply to
    • OscarL
    • Posts 6
    • Points 100
    Choppy Transition
    Smooth Transition
  • Mon, May 22 2023 11:48 PM In reply to
    What is your render settings (codec and quality)?
    What kind of drive are you using for the render drive?
    MC 2024.12, W11, ASUS z690m, Intel 13900K, MSI 4090 Suprim Liquid, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Sonoma... [view my complete system specs]
  • Wed, May 24 2023 5:32 PM In reply to
    • OscarL
    • Posts 6
    • Points 100
    My project's settings: 2K 2048x1536 4:3 24P
    My drive is an HDD.
  • Wed, May 24 2023 7:15 PM In reply to
    What codec is your render settings? DNxHR LB? DNXHD 145? etc.
  • Tue, Jun 6 2023 8:19 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,969
    • Points 50,650
    • Moderator: MCA Mac
    OscarL:
    My drive is an HDD.
    You need to be a bit more specific. Is this a spinning hard drive, or a solid state disc?
    Dave S.
