Hi Community!
We have a use case where we would like to have mono .wav files run through AMT to end up on specific audio tracks in Media Composer.
Example:
a recording from a SoundDevice with 5 seperate mono tracks in the same "take" when run with AMT all ends up on "A1" we want them to end up on A1-A5 respectively based on either embedded metadata or through injected metadata.
They way to do this directly in Media Composer is naming the clips with a suffix as "_3" for A3 - is there a related workflow/solution for AMT?
Thanks in advance!
- Christian
