Latest post Fri, Mar 24 2023 5:02 PM by ripvanmarlowe. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Mar 23 2023 12:46 PM
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 1,288
    • Points 15,915
    Mixed i and P timeline - best way to output P?
    Right mix of 17 cams.  I need to work in i as the majority are i and seem to get artefacts when exporting if working in P.
    Its music so need to output P really - what the best way to achieve that from within Avid and without any Saphire plugins etc?  Been a while since I did it as always have to work in i for TV!  Cheers.
    Ultimate 2022.12.1, Blackmagic Intensity Pro, WIN 11 on 7000Mbps M.2 SSD, Nvidia Quadro P4000, Asus Pro Art Z690 i9 12900k 5.0 GHz, 8TB M.2 SSD - its nippy!
  • Thu, Mar 23 2023 12:59 PM In reply to
    Re: Mixed i and P timeline - best way to output P?
    Have you tried bringing the interlaced content into a Progressive timeline and experimenting with the motion adapter that will be applied?
    As you need to export as a P its best if you can do that conversion in the timeline so you can see the result during the edit.
    Remember you can promote to fluid motion for any shots that still don't look good. But the render times are long and they can produce artefacts of their own.
    T 07581 201248 | E [email protected]
  • Thu, Mar 23 2023 1:45 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,184
    • Points 50,475
    My go to interlace to progressive tool these days is Resolve Studio (must be Studio).  It does a good job.  But it needs a timeline where the clips are flagged as interlace and progressive.  You could come up with some tricky ways to get there from Avid.  Or try to do the whole thing from an interlaced output.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Thu, Mar 23 2023 1:56 PM In reply to
    • DIESELE
    • Posts 1,288
    • Points 15,915
    I tend to get that zig zag interlaced effect on hand movement etc when I do that Pat.  Its a big arena concert and fluid motion always gets screwed by the flashing lights in my experience.
    I thinkI need to work in i as the P can cope with that but not vice versa.  How to get a P output after that somehow that retains vertical resolution?
    Cheers and thanks for the help.
  • Thu, Mar 23 2023 2:37 PM In reply to
    DIESELE:
    To me, that indicates that the footage has been flagged incorrectly, or you are using  the 'Both Fields" option in the motion adpater/effect.
    I'd go for Blended Interpolated, which shouldn't be thrown out of whack by flashing lights. You will, however, always lose some vertical resolution.
    P.S.: If you need to output in P, I would work in P, not I.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Fri, Mar 24 2023 5:02 PM In reply to
    Also remember to render effects in P as well or you will have to re-render everything when you output in P.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2022.10 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
