Hello,
I am running Artists DNxIQ with Premier Pro and I get stuttering playback with encoded files (H.264). When I unplug Artist, the files playback normal. Raw files straight from the camera (Sony FX6) playback smooth with Artist. Any advice for the stuttering performance on encoded files?
Are you using the latest I/O device drivers?
Editing Movie Magic.
My Equipment & System Specs
Media Composer Ultimate 2022.12.2 | Pro Tools Studio 2022.21 | Sibelius Artist 2022.12
Driver 12.2, apparently not. I see there is a 12.4. I will let you know if that is the fix.
Did you ever get better results with the DNxIQ on Premiere? I may need to do the same thing.
If not, are/were your playback problems only with mp4 files? Does ProRes perform normally?
