Latest post Sat, Jan 28 2023 3:52 AM by Robert Martindale. 21 replies.
Page 2 of 2 (22 items) < Previous 1 2
  • Wed, Jan 25 2023 1:25 PM In reply to
    • mtahir
    • UK
    • Posts 561
    • Points 6,885
    Re: Blackmagic Desktop Video and MC menu problem
    i've opened a case with Blackmagic about this and the other issue I'm having with the SD output to a client monitor. Supplied them with information and just waiting to hear back from them. As soon as I do, I will update everyone.
    MC2022.12 (Win10) | DaVinci Resolve Studio | Dell T7500 with 2 x 6-Core Intel Xeon X5690 3.46GHz CPUs | Triple-Channel 96GB (48GB per CPU) 1333MHz DDR3... [view my complete system specs]
  • Wed, Jan 25 2023 9:26 PM In reply to
    rolling back to v 11 did not solve the issue for me
    I9-NVidia3060-160ram-WIN11PRO-MC23.12-NewBlueFX-Photoshop-Shutter Encoder-Boris Continuum 12.5-VLC Player [view my complete system specs]
  • Fri, Jan 27 2023 4:10 AM In reply to
    ROLLING AVID BACK TO 2020.12, USING V 11.4 OF DECKLINK DID GET THE MONITOR BACK
  • Fri, Jan 27 2023 8:12 AM In reply to
    • Mercer
    • Joined on Thu, Apr 15 2010
    • UK
    • Posts 873
    • Points 11,290
    Robert Martindale:
    Is there a particular reason you need to use an old version? The problem is that the latest versions have changed the naming cconvention of the driver folders, used by Avid. Upto 12.4, this is not the case, but if you roll back you will still need to completely de-install the new versions. In rolling back Avid, it possibly did this anyway and so it will now work.
    MC with Symphony option, 2022.10, HP ZBook 17 G5, i7-8850H 6 core/64GB ram/512 M2 ssd/Nvidia Quadro P5200/16GB/FHD, HP Thunderbolt Dock G2, BMD Ultrastudio... [view my complete system specs]
  • Fri, Jan 27 2023 8:27 AM In reply to
    just testing......the 12.4 version did not help with 2022.12 so i rolled them both back...happy editor now and will wait to hear what BM and AVID do to fix this going forward......
  • Fri, Jan 27 2023 10:06 AM In reply to
    • Mercer
    • UK
    • Posts 873
    • Points 11,290
    Robert Martindale:
    As I said, simply rolling back to 12.4 will not fix the issue, if you had already installed 12.4.1 or 12.4.2. You have to uninstall and delete the Blackmagic Desktop Video folder too (or use Mtahir's workaround on Windows). 12.4 works here fine, as it should, after having done that. It's not an Avid issue - it's a BMD one.
  • Sat, Jan 28 2023 3:52 AM In reply to
    12.4 worked with 2020.12....after 2022.12 installs, i will report back
    sorry...it did not work to run v12 (or any other version in my testing) with v2022.12...i will now try 2021.12
    success....with v12 and MC 2021.12 with the .7 patch....or without
    so, it is clear this is NOT just a Blackmagic problem...BM and AVID need to talk and get this resolved in V 2022.12
