Latest post Wed, Jun 19 2024 2:12 AM by gainfulclifden. 2 replies.
  • Fri, Jan 6 2023 1:51 PM
    Newsroom Management CTMS Asset Self Not Returning Expected Response
    Using the ia:queue-stories-by-id link it is possible to obtain a list of stories together with their attributes.
    There is an issue when using the "self" link to subsequently update the details of a story.
    An example of a genuine "self" link is shown below. Note that it reflects the original request in that the embed query includes both nsml and aeset-attributes
    https://cloudux.wysdom.local/apis/avid.inews;version=0;realm=INEWS7/assets/ARCHIVE.2022.DEC.22..28681475.139899.0?embed=nsml%2Casset-attributes&section=fields
    After executing the request the response does not include the attributes
    Filed under: , ,
  • Fri, Jan 13 2023 1:07 PM In reply to
    • Olena
    • Joined on Fri, Jan 13 2023
    • Posts 1
    • Points 15
    Re: Newsroom Management CTMS Asset Self Not Returning Expected Response
    Hi Michael
    if you want to get asset attributes via executing 'aa:asset-by-id' request you should use 'embed=attributes':
    https://cloudux.wysdom.local/apis/avid.inews;version=0;realm=INEWS7/assets/ARCHIVE.2022.DEC.22..28681475.139899.0?embed=nsml%2Cattributes&section=fields
    because 'embed=asset-attributes' was designed to return asset attributes only in requests which are send to queues to separate queue attributes and asset attributes
    you see this issue because all parameters in the request apply to all links in the response
    but we will think how to improve this
  • Wed, Jun 19 2024 2:12 AM In reply to
    Hi Olena happy wheels,
    Yes you are right, the DNS records must be created for the VM and after that you need to check the DNS settings in the CentOS (/etc/resolv.conf) the DNS server must be configured as well as search groups(domains). After chanches in resolv.conf do not forget to restart coredns POD in the system namespace to apply the changes.
