Latest post Tue, Jul 5 2022 5:42 PM by Telegram!. 3 replies.
  • Mon, Jul 4 2022 9:45 PM
    • nymills
    • New York City
    • Posts 357
    • Points 5,105
    Changing Aspect Ratio For Portrait Social Media
    How can we change the aspect ratio to cut Portrait social media pieces? We have a ton of stuff in MC that needs to be reformatted. I'm sure it's easy.
    Thank you!
    Win10Pro 64Bit, Media Composer Ultimate/SS/FF/Symphony 2022.4, Boris FX Suite HP ZBook 17 G6, 128GB Ram, RTX 5000, 250GB SSD System Drive, 1TB SSD... [view my complete system specs]
    Michael Mills
    TeleStory Pictures
    www.telestorypictures.com
    "Some people see things and say,'Why?' I dream things that never were; and say,'Why not?'"
  • Tue, Jul 5 2022 1:45 PM In reply to
    Re: Changing Aspect Ratio For Portrait Social Media
    nymills:
    Thank you!
    I think this is a good topic with different possibilities. (see bottom note)
    *Also be careful if a "dual" ratio deliverable is being edited using Frameflex.
    I can only suggest that you determine what specific ratio is required based on the deliverable. If your existing normal-ratio Project is online, go to Settings> Format tab > Presets: > My Presets. That's where you want to find it. If not there, or "My Presets:" doesn't exist-- you'll need to make your own preset.
    What I have done on v2022.4 is: Close out to reveal the Select Project interface; select New Project; select Format: and navigate to bottom of dropdown to Custom; in Raster Dimension add your desired ratio...e.g. 1080 x 1920; Select Save Preset; Add your custom Preset Name; select OK:
    You do not have to press CREATE unless you want to have separate projects... but that is not always required. Your saved custom Preset should now become available in your existing, normal-ratio Project, under My Presets.
    Beyond that, I believe you then get involved with FrameFlexing your masterclips and * here you decide based on whether you have already Frameflexed some or all your masterclips in service to your original normal-ratio sequences. If that's the case, you may very well want to use a separate Portrait-sized project, and bring Bins into it. I am *pretty* sure you can then easily do mass FrameFlexing on many clips into the narrower Frame Aspect Ratio without disturbing the FrameFlexing you may have done on the same clips in the original normal ratio project. * BUT: please do a test on one or two clips first...go back to your original normal-sized Project and inspect those clips to see if they also become Portrait-ratio. You tell me, after testing OK?
    So one way or another, inside your original project (using the new Portrait ratio Preset), or while in the new Portrait-ratio Project ...a Frameflexed clip on a timeline permits further careful individual repositioning within the narrower view.
    Do a test Export to your deliverable to make sure everything is hunky dory.
    EDIT: I'm on v2022.4 PC with Quicktime installed. It looks like I can also now do an Export to MOV which will "Crop to Mask Margins".
    Did a quick test after adding a 9:16 Black Mask.
    Seemed to do the trick just showing whatever was visible inside the mask... not sure about any sidebars though ...better check that by Importing back to MC.
    There is probably a way to use a different, Custom Mask size and Crop.
    The resulting file in Media Info displayed;
    Video
    Format                                   : VC-3
    Commercial name                          : DNxHR HQ
    Format version                           : Version 3
    Format profile                           : RI@HQ
    Codec ID                                 : AVdh
    Codec ID/Info                            : Avid DNxHR
    Duration                                 : 1 s 34 ms
    Bit rate mode                            : Constant
    Bit rate                                 : 220 Mb/s
    Width                                    : 1 080 pixels
    Height                                   : 1 920 pixels
    Display aspect ratio                     : 0.563
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 (30000/1001) FPS
    Color space                              : YUV
    Chroma subsampling                       : 4:2:2
    Bit depth                                : 8 bits
    -Telegram!
  • Tue, Jul 5 2022 5:06 PM In reply to
    If you have "normal" landscape HD then scaling for 9:16 is going to be a quality compromise.
    You have too many pixels in width so will need to crop and too few in height so you will add black letterbox ING bars or scale that will lower quality and further reduce the width.
    If you want portrait outputs you really need to aquire in portrait.
  • Tue, Jul 5 2022 5:42 PM In reply to
    Pat Horridge:
    Hi Pat,
    While we are waiting for OP to mention deliverables & original shooting specs,
    I just saw that I could also Export a 607 X 1080 file from my test timeline which was normal from an HD project with a 9:16 Black Mask added. All I did was unlock the Export equal scaling icon and type in 607 X1080. Is that going to look so horrible on a social media site, which I suspect is for viewing on phones? I viewed the result in QT Player and saw no sidebars.
    from Mediainfo:
    What is surprising to me is that although I am Exporting from a 1080i Project, my codec Family choice is limited to DNxHR 444 (Compression = 10bit or 12bit ), with no other HR option or a DNxHD option showing in the drop-downs.
    Video
    Format                                   : VC-3
    Commercial name                          : DNxHR 444
    Format profile                           : RI@444
    Codec ID                                 : AVdh
    Bit rate                                 : 139 Mb/s
    Width                                    : 607 pixels
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 0.562
    -Telegram!
