Latest post Wed, May 18 2022 9:53 PM by Philip Owens. 5 replies.
Page 1 of 1 (6 items)
  • Wed, May 18 2022 5:13 PM
    Is it possible to create new user profile, and import previous settings?
    Everybody knows this one - every tech suppport contact usually begins with "have you created a new user profile", and while I understand the need for support to ensure user profile cruft isn't causing an issue, it's a nightmare request as to recreate all those little tweaks one makes to the UI, tools and workflow is next to impossible.
    Is it possible to create a new user profile that satisfies the requirements of cruft-elimination, and then import all one's previous settings,without screwing up this new profile with the problem all over again?   Without this ability, I am so frustrated with constantly creating new profiles.
    MBP 2020, 2.5Ghz 8 Core, 64GB RAM, 8GB VRAM [view my complete system specs]
  • Wed, May 18 2022 9:08 PM In reply to
    Re: Is it possible to create new user profile, and import previous settings?
    Yes of course.
    Create the new user profile and confirm issue is resolved (if its not then possibly the old user profile isn't at fault)
    If the systems stable then use file open settings file.
    Along side your user settings screen.
    You can now drag from the old user file to your user settings.
    But you need to do it in sma batches and re test. Otherwise you risk dragging across the duff setting.
    T 07581 201248 | E pat@vet-training.co.uk | www.vet-training.co.uk|
  • Wed, May 18 2022 9:19 PM In reply to
    Thanks Pat.  Not sure I understand this though?   Maybe it's cos I'm on 2022.4, but I don't see File > Open Settings File?  Or in the Preferences menu, I don't see a way to drag and drop anything?
    Pat Horridge:
  • Wed, May 18 2022 9:41 PM In reply to
    I'm on a system in the morning so will check.
    But it's under one of the top menus while you have the user settings window open.
    I'm also on 2022 version but it's been there for ages.
  • Wed, May 18 2022 9:49 PM In reply to
    Hi.
    You can copy all of the settings your prefer from you old user profile.
    cj
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    Christian Jhonson
    Avid Ambassador
    christianjhonsoon@hotmail.com
  • Wed, May 18 2022 9:53 PM In reply to
    Pat Horridge:
    Aha!   Never noticed that the contents of the File menu changed when that was open - I think I can figure out from here, thank you so much Pat!
