Latest post Sun, May 29 2022 9:12 AM by Tentaor. 6 replies.
Page 1 of 1 (7 items)
  • Wed, May 18 2022 6:41 AM
    • Tentaor
    • Joined on Thu, Nov 15 2007
    • Posts 44
    • Points 505
    Unable to import/link *.mp3
    Hi!
    I am unable to import or link mp3 files in Media Composer.
    If I drag the file from the finder to a bin nothing happens.
    If I drag it with the ALT key pressed to link it, nothing happens either.
    If I try to import it from a bin I get a message saying the file can't be imported but I can link and consolidate it. If I do that, a screen ends up with an error "The file ***** is an unknown file" and it doesn't work either
    Help please!
    Avid version 2022.4
    Avid Link 2022.4
    MAC STUDIO MAX 64GB MAC OS 12.3.1 /// IMAC 27 LATE 2013 32 GB RAM OSX Catalina 10.15.7 Media Composer 2022.4 [view my complete system specs]
  • Wed, May 18 2022 7:51 AM In reply to
    Re: Unable to import/link *.mp3
    Is this with all .mp3 files or just one? Do the files play outside of Media Composer? Can you try importing or linking a file that you know is good?
    Media Composer 2022.4 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Wed, May 18 2022 9:28 AM In reply to
    • Tentaor
    • Posts 44
    • Points 505
    All the Mp3 fail. All play correctly outside MC. Previously mp3 imported does not import again now.
    I´m in Catalina.
    I tried to reinstall without succes.
    I downgraded to 2021.12.1 (MC) and 2021.12.2 (Avid Link) and Install MediaComposer Legacy Components without succes.
    I´m working transcoding all MP3 to WAV with Encoder. WAV import works well.
  • Wed, May 18 2022 9:49 AM In reply to
    This is a common problem in Catalina or later versions of MacOS with Media Composer.
    These search results might have some more information that would help: https://bit.ly/3wmgitA
    If not, I suggest you create a case on the MyAvid support portal and someone will get to you asap.
    https://www.avid.com/US/support/support-contact  If you don't get anywhere with them, send an email to Chris Bové (chris.bove@avid.com).  He is Avid's customer advocate, and can help you.
  • Wed, May 18 2022 7:12 PM In reply to
    • Tentaor
    • Posts 44
    • Points 505
    This is crazy!
    I tried to create a case but my acces to the Support Portal was not active. I filled the form to activate it but it is in process yet. It´s very strange. I´have an active perpetual license with support until August
    "Unlimited online technical support, billing and account help, with up to one business day response time"
  • Wed, May 18 2022 7:51 PM In reply to
    Send an email to Chris Bové (chris.bove@avid.com) and Raff Condalor (raff.condalor@avid.com).  They are Avid's customer advocates, and can help you.
  • Sun, May 29 2022 9:12 AM In reply to
    • Tentaor
    • Posts 44
    • Points 505
    Thank you very much. I have done what you have told me and I have been able to contact Avid support. After a 1 hour remote support session we discovered that it only failed to link converted mp3 files from a specific website. Changing the online converter has stopped failing with those files. However both Premiere and DaVinci worked perfectly with those first files (also working on Catalina)
