I'm working on a documentary right now and having a difficult time trying to figure out how to sync the audio&video.
For example, I've got 83 video clips and 64 audio recordings. Some shots are slo-mo so they don't need audio. The audio doesn't have timecode and there might also be some false-takes in it. Because it's a documentary so they couldn't take any notes while shooting.
I also tried selecting both video and audio and do ''waveform analysis' but it would take forever.
Is there a proper way to sync audio for a project like this?
Much easier for you to watch this video than try to understand what I mean via text
https://youtu.be/He0ONp3tXf0
You could do waveform analysis, but I find doing it manually is more accurate and proper.
Editing Movie Magic.
My Equipment & System Specs
Media Composer Ultimate 2022.12.2 | Pro Tools Studio 2022.21 | Sibelius Artist 2022.12
dudzin: Hi, I'm working on a documentary right now and having a difficult time trying to figure out how to sync the audio&video. I also tried selecting both video and audio and do ''waveform analysis' but it would take forever. Is there a proper way to sync audio for a project like this?
I can make some suggestions, but need to know a little bit more, first:
did you get a sucessful AutoSequence of all your Video clips? IE, did the video clips shoot with TOD, timecode, thereby leaving Filler gaps in your Autosequence?
Start there, and I'll get to sound...
-Telegram!
Thank you. It does generate a sequence but there's no gap in between each clip... so it doesn't seem like it was shot with timecode.
dudzin: Thank you. It does generate a sequence but there's no gap in between each clip... so it doesn't seem like it was shot with timecode.
OK, if you can, please look at the video clips in a Bin which can show a column with Starting TC. What is the TC number that ALL the clips are showing? Is it 00:00:00;00 or ?? ...or does each clip have different timecode that increments?
Also, important: Can you verify that there is some sound on the clips? And if there is "audio TC" on one of the channels?
Standing by...
I can also ask what you know about the shoot, in terms of camera. And, how are the clips named? Are they sequential-- give and example, please.
Also: which MC version are you running? PC or Mac?
