Latest post Fri, Apr 15 2022 7:59 AM by ZFigas. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Apr 7 2022 4:04 PM
    Media Composer 2021.12.1 Available Now - 7 April 2022
    Avid is pleased to announce the release of Media Composer 2021.12.1 today, April 7, 2022, at noon ET. This is a maintenance release for MC 2021 users.
    Location at Launch: The Media Composer 2021.12.1 is available on the Download Center only.
    Status of Support Plan: The ability to launch this Media Composer 2021.12.1 software is dependent on the status of your Upgrade and Support Plan on the date this software version was released. Media Composer 2021.12.1 was released on Thursday April 7th, 2022 at 12 at noon ET.
    Changed in Media Composer v2021.12.1
    What’s Fixed in 2021.12.1: The following have been fixed.
    • Bug Number: MCCET-4360. In some instances, exporting to a P2 device resulted in pixelated and inverted images.
    • Bug Number: MCCET-4465. MC Option not getting enabled When MC is Cloud License and Option is FNO License
    • Bug Number: MCCET-4399. If you performed an Export as Graphic and NDI was active, you might have received an “AMEResourceManager ReconfigHW_LegendBoB_Capture” error.
    • Bug Number: MCCET-3854. During export some AAF Sound settings did not save.
    • Bug Number: MCCET-4481. (Production Management) Clips with the Restrictions did not appear with the red triangle in the Media Composer bin.
    • Bug Number: MCCET-4509. In some instances, the image appeared garbled after loading a sequence in a Color Correction workspace.
    • Bug Number: MCCET-4449. In some instances, when working with MultiCam sequences, Media Composer was sluggish.
    • Bug Number: MCCET-4402. With Gang enabled, selecting all Timeline Clip Notes resulted in a hang.
    • Bug Number: MCCET-4395. (ScriptSync) If you added color to a range of script indicators, when you closed and then reopened the script, the indicators were filled even if they were not previously filled.
    • Bug Number: MCCET-4513. (Production Management) In some instances, you might have experience a significant slowdown when performing an Edit While Capture.
    • Bug Number: MCCET-4498. Lassoing in Bin Frame View using Shift or Ctrl did not work properly.
    • Bug Number: MCCET-4056. Applying a Matte key effect to a ProRes 4444 file did not preserve the fill layer.
    • Bug Number: MCCET-4437. Selecting “Set Audio Suite Plugin In/Out” from the AudioSuite Plugin fast menu does not work on rendered effect after performing an Undo.
    • Bug Number: MCCET-4519. In some circumstances you might have received an error when using Color Correction with dupe detection enabled.
    • Bug Number: MCCET-4382. In some instances, Dynamic Relink settings unexpectedly reverted to Most Recent.
    • Bug Number: MCCET-4562. In some instances, LTC signals did not parse correctly in Read Audio Timecode.
    • Bug Number: MCCET-4332. Transcoding linked 50fps h264 clips to 50i resulted in the wrong duration.
    • Bug Number: MCCET-4479. When moving bins in a project, it can take too long for the bin to respond and in some instances the beachball appears when moving the bin.
    • Bug Number: MCCET-4443. You might have received a “m_qDrag deleted with deleteLater” error after dragging a button from the Command Palette to another button under the Composer Window.
    • Bug Number: MCCET-4501. If a floating Timeline window is made smaller, scrolling with the mouse wheel does not work properly.
    • Bug Number: MCCET-4450. Media Composer | Enterprise might have launched as Media Composer standard.
    • Bug Number: MCCET-4436. If Dynamic Relink was enabled, an imported audio file might have appeared offline.
    • Bug Number: MCCET-4494. (Production Management) In some instances, after checking in sequences, the thumbnail in Access would display “No head frame.
    For details on the complete bug fixes, see the Knowledge Base Media Composer 2021 Documentation page.
    ReadMe: The new ReadMe will be uploaded to the Knowledge Base Media Composer 2021 Documentation page at launch.
    Media Composer 2024.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 64gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, Apr 8 2022 9:22 AM In reply to
    • gswilson
    • Joined on Thu, Feb 4 2010
    • Belfast, Ireland - now, Frankfurt am Main, Germany
    • Posts 357
    • Points 4,730
    Re: Media Composer 2021.12.1 Available Now - 7 April 2022
    After almost 4 months still nothing updated in Titler+. Huh?No
    Gerry
    MC 2022.12, Win 10 Pro(21H2), Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 1080Ti GPU(Studio Driver 527.56),Samsung 850 Pro... [view my complete system specs]
  • Fri, Apr 8 2022 7:06 PM In reply to
    This is only a maintenance release: bug fixes and compatibility with later operating systems.
    The 2022.4 version coming soon has some great new features.
  • Wed, Apr 13 2022 10:26 AM In reply to
    • ZFigas
    • Joined on Tue, Jan 31 2006
    • Poland
    • Posts 209
    • Points 2,680
    In MC 2021.12.1, Workspaces has been drastically downgraded.
    Zb.
    HP Z8 G4, 2xXeon-6246R, 128 GB RAM, Win 11 Enterprise, MC 2024.6, Nvidia RTX A4500, driver 552.34, Boris Red 5.6, BCC 2024.5, Saphire 2021.02, Adobe CC... [view my complete system specs]
  • Wed, Apr 13 2022 1:29 PM In reply to
    ZFigas:
    Zb.
    Czesc Zbigniew,
    Could you help me understand why? I can forward this on Smile
    Filip
  • Thu, Apr 14 2022 9:01 AM In reply to
    • ZFigas
    • Poland
    • Posts 209
    • Points 2,680
    Witaj Filip,
    Example:
    https://www.dropbox.com/s/zb1cesc2x80le1a/bandicam%202022-04-14%2010-54-06-580.mp4?dl=0
    Avid doesn't keep my own workspaces.
    Regards
    Zbigmiew
  • Thu, Apr 14 2022 9:31 AM In reply to
    • ZFigas
    • Poland
    • Posts 209
    • Points 2,680
    Color Correction Mode icon completely disorganizes workspaces. It takes half an hour to fix the situation.
    Zb.
  • Thu, Apr 14 2022 10:35 AM In reply to
    Darn that does look annoying.
    Does the issue persist when you dock your panels instead of float them? Did this issue occur in a previous version of Avid?
    Try to reset your site settings: https://www.youtube.com/watch?v=l0vJhAtMS2Y
  • Fri, Apr 15 2022 7:59 AM In reply to
    • ZFigas
    • Poland
    • Posts 209
    • Points 2,680
    I'm afraid that after a long time of fighting workspaces, I realized where the mistake was.
    In the fact that I was guided by logic.
    Optimistically, I assumed that since I can define my own workspace, eg CC, it can include selected windows, eg only 3 - obligatory CC, sources and timeline. I after save everything is OK.
    Then I create another New Workspace for Edit in which I have more windows, e.g. a few bins, source, timeline and I save it.
    If after that I change my own workspaces between Edit and CC, the windows shift or the windows with Edit Workspace appear in it.
    The only method is for CC workspace to have the same windows as Edit, plus CC.
    I did not understand it, the logic was beyond me.
    That's just how MC works.
    It is completely tragic to use Color Correction Mode icon. Everything is completely "drifting" for me, I waste time to redefine workspaces.
    Finally, an important note. This is not a matter of the latest version as it worked for me because under no circumstances have I touched my workspaces for a long time.
    Zbigniew
