Latest post Thu, Jan 5 2023 5:00 PM by Colonel March. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Apr 4 2022 10:08 AM
    Export issue video h264 but no sound
    Trying to export as a file my film as a MP4.  In AVID the video and sound play but when I export the file with both video and audio checked I get the video but no sound. Just trying to get a version to email friends to view.
  • Mon, Apr 4 2022 11:19 AM In reply to
    Re: Export issue video h264 but no sound
    What type of audio codec did you select? Some players won't accept PCM sound on an h264 mp4. Should work if you use AAC.
  • Mon, Apr 4 2022 12:42 PM In reply to
    Thank you for the fast reply.  I used PCM.  When I get home later today I will switch it to AAC - I saw the two options and stuck with the default of PCM.  That's what I was also wondering was my default Windows Media Player couldn't handle the audio whereas Youtube or Vimeo being essentially media players would regardless of PCM or AAC.  But I was hoping to avoid putting my film on Youtube even in private mode.
  • Mon, Apr 4 2022 2:15 PM In reply to
    I use Handbrake, Preset >Web >Vimeo Youtube HQ1080p60. The result is a highly compressed mp4.mv4 file with AAC audio in good overall quality.
    MB: ASRock Z390 Taichi Ultimate. CPU: Intel Eight Core i9-9900K/3600 16MB Cache, SATA Hard Disks Raid (2x4 TB), GPU 1200MHz. GC: Gainward RTX2080 Super... [view my complete system specs]
  • Mon, Apr 4 2022 7:05 PM In reply to
    Roland Achini:
    Why the conversion to 60p?
    I love Handbrake, but have switched to Shutter Encoder for most jobs. Also, MC 2020.4 and later do a great job at exporting directly to h264. Quick and great quality.
  • Tue, Apr 5 2022 8:10 AM In reply to
    Job ter Burg:
    I see no alternatvie "50p" in handbrake. However after export I checked the file in media info, and it says 50p.
  • Tue, Apr 5 2022 8:19 AM In reply to
    If you dive into the Picture settings you should see there's a frame rate option, including one that remains the existing framerate.
  • Tue, Apr 5 2022 10:27 AM In reply to
    The switch to AAC worked thank you.  I would add in regards to the other replies...
    In my case exporting as a file one has to remember to have the codec remain the same as your video whereas mine was AVC Intra 100.  Otherwise video degradation will occur. The export options you have to change the codec from H264, DNXHD(?) to AVC Intra 100 in the drop down window and use a MOV container file.  Then in the import window of a new AVID project you must change the codec from H264 Proxy to AVC Intra 100.  Youtube accepts MOV files where now I can list it as private and share it with colleagues, friends and family.
  • Tue, Apr 5 2022 10:46 AM In reply to
    Job ter Burg:
    I got it, thank you.
  • Thu, Jan 5 2023 5:00 PM In reply to
