Latest post Wed, Mar 16 2022 10:18 PM by Job ter Burg. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Mar 15 2022 3:44 PM
    • Adrian Redmond
    • Joined on Wed, May 28 2014
    • Posts 304
    • Points 4,220
    Mastering workflows
    I'd be interested to hear how other MC editors tackle the mastering and archiving of their productions.
    When my production is complete andf the timeline is fully rendered, I usually do the following -
    1. Digital cut to HDCAM master for archiving
    2. Mixdown of video and audio tracks to mxf files for archiving
    3. Export to file - typically H264 .MOV uncompressed (from which other compressed formats may be made as required).
    As I am still running MC 8.5.3 (with Symphony) I cannot master directly to H.265/HEVC - I am currently testing a conversion route via Shutter Encoder but haven't got this to work quickly enough yet.
    Does anyone know if Shutter Encoder can work with a pair of audio/video mxf mixdown files from the timeline - and assemble the two files together for conversion to for example H.265?
    I have found one reliable route to achieving a high quality compressed MP4 version - load the uncompressed mov file up to YouTube than when processed, download the file as MP4 - for a 30 something GB MOV files this results in a 290MB MP4 file with no noticeable compression artefacts. So far this is the best way I have found to achieve a high quality smallish MP4 file.
    I would like to hear how others approach their mastering, archiving and conversions :)
    Avid Media Composer v. 8.5.3. with Symphony Option on HP Z820 Dual Intel E5-4650L 8-core HT 2.6GHz CPU with 256GB RAM (192GB available to OS), NVidia Quadro... [view my complete system specs]
    Adrian Redmond
    Owner / Producer / Editor
  • Tue, Mar 15 2022 8:32 PM In reply to
    Re: Mastering workflows
    Interesting question.
    For short form projects with raw files of perhaps 300GB I keep the camera originals for about half a year. I delete the MXF media files, If I ever need to edit something again in this project I bring my media in either by relinking or batch re-import.
    For longer-form projects (depending on the project) I export an uncompressed, mezzanine level DNxHR HQ, and a H.264 MP4 at 12mbps (HD) then delete the camera originals.
    Since MC can't queue exports that will be encoded differently, I export an uncompressed or mezzanine level, then transcode in Media encoder or shutter encoder to my other flavours.
    Not sure if shutter encoder can bring together a separate audio file and a video file, and then combine them into one video file. I've never tried that.
  • Wed, Mar 16 2022 10:11 AM In reply to
    Is that HDCAM or HDCAM SR?
    HDCAM is sub sampled to 3:1:1 so suitable for playback from but not as a master.
    I don't think shutter encoder can use 2 different sources.
    H265 is very processor intensive (around 3 times that of H264) so I suspect your crate will be the limiting factor.
    T 07581 201248 | E [email protected]
  • Wed, Mar 16 2022 7:35 PM In reply to
    Pat Horridge:
    I thought it did. Via Merge and/or Replace Audio. But have never done that in SE, I must admit.
    Media Composer Symphony | PT Ultimate | Win11 HPZ | OSX MBP [view my complete system specs]
  • Wed, Mar 16 2022 10:06 PM In reply to
    Job ter Burg:
    Pat Horridge:
    The merge / replace audio is under the without conversion section. So you can replace the audio but not transcode that the same time.
    But you coul do it in 2 passes. Replace the audio and not transcode and then transcode the resulting file.
  • Wed, Mar 16 2022 10:18 PM In reply to
    Ah, of course. Got it. Thanks!
