Latest post Fri, Mar 18 2022 2:07 PM by mts-dev. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Mar 15 2022 1:58 PM
    • mts-dev
    • Joined on Fri, Dec 10 2021
    • Posts 18
    • Points 215
    Media Central Plug-in dev server getting NET::ERR_CERT_COMMON_NAME_INVALID error
    Hi there,
    Running a plug-in app going to localhost gives me this error on chrome:
    I mostly ignore this error but the plug-in has been crashing and Media Central constantly reports a"NET::ERR_CERT_COMMON_NAME_INVALID" error to the console. I want to rule this out as the source of the crash. How do I fix this problem?
    Edit:
    Wanted to add more info about the crash and the error. The crashes only seem to happen after the plug-in sends and receives data from an external API I wrote. As far as I can tell there's nothing wrong with the response, Media Central does not report any react specific errors. Just as the proxy server crashes, Media Central reports "NET::ERR_CERT_COMMON_NAME_INVALID" errors from the plug-in's attempts to make GET calls to https://localhost/auth/tokens/current or https://localhost/app/1c2dea9539283e7ba4e3.hot-update.json.
  • Fri, Mar 18 2022 2:07 PM In reply to
    • mts-dev
    • Posts 18
    • Points 215
    Re: Media Central Plug-in dev server getting NET::ERR_CERT_COMMON_NAME_INVALID error
    I think I've found the cause. The localhost certificate used by cloudux-starter-kit does not have a "Subject Alternative Name" as chrome reports in the screenshot I posted. This causes chrome to block all calls to https://localhost, this then crashes the proxy server. A solution that works is setting the #allow-insecure-localhost chrome flag to enable which "Allows requests to localhost over HTTPS even when an invalid certificate is presented". It does not feel like a safe option so I would still like to know if there is a better solution to this problem.
