Latest post Mon, Nov 22 2021 11:56 PM by Philip Kapadia. 7 replies.
  • Tue, Nov 16 2021 8:34 PM
    • MikNewbie
    • Joined on Wed, May 5 2021
    • Posts 6
    • Points 90
    Blue/Green Screen Questions for AMC/First
    I'm a film student. I'm making a music video and used blue screen outside while filming. I'm guessing I should edit the blue screen clips first before inputting them into my project?? Also, is there a really good video tutorial about how to edit when blue screen was used?
    One final question: is it possible to layer videos and/or pictures onto other videos in AMC/First? Or do I need an FX program to add things like fire and people where no blue screen was used?
    Thanks.
  • Tue, Nov 16 2021 8:47 PM In reply to
    Re: Blue/Green Screen Questions for AMC/First
    MikNewbie:
    Thanks.
    You can do an awful lot in Avid Media Composer, without having to go into after effects :)
    Here's a tutorial on Green Screen: https://youtu.be/BdtOEdUI5eI
    The effect to Key out a screen is called "SpectraMatte"
  • Wed, Nov 17 2021 6:54 PM In reply to
    • MikNewbie
    • Posts 6
    • Points 90
    Thanks, Philip!
    So helpful! =)
  • Wed, Nov 17 2021 8:56 PM In reply to
    MikNewbie:
    Thanks, Philip!
    So helpful! =)
    All good my friend. GL with Uni/school/college.
  • Mon, Nov 22 2021 1:41 AM In reply to
    • MikNewbie
    • Posts 6
    • Points 90
    Hi Again,
    I have MC/First and it doesn't have SpectraMatte. I did find a youtube video on how to remove the background but it takes some of the image that I want to keep. Any tips to fix this?
    Thansk!
    Mikki
  • Mon, Nov 22 2021 9:41 AM In reply to
    MikNewbie:
    Hi Again,
    Thansk!
    Mikki
    Type in "SpectraMatte" into your effect palette. It's possible that the MC first versions do not include the spectramatte effect. I know that MC first definitely does not include AniMatte for example.
  • Mon, Nov 22 2021 7:55 PM In reply to
    • MikNewbie
    • Posts 6
    • Points 90
    Hi Philip,
    MC First uses Key > RGBKeyer instead of Spectramatte. This is easy to use. However, it takes away part of the foreground that I want to keep. I found a video a week or so ago about adding some color effects to the background but I haven't been able to find that video again.
    I'm thinking if I can get the background to be a different color, I'll be able to successfully use the RBGKeyer???
    I have no idea but I have to have a rough draft by tomorrow. I've been watching a ton of video tutorials but I haven't found one that addresses this issue I have.
    Do you have any ideas?
    Thanks!
    Mikki
  • Mon, Nov 22 2021 11:56 PM In reply to
    MikNewbie:
    Hi Philip,
    Thanks!
    Mikki
    With spectramatte or boris FX (Boris FX provides third party plugins for Avid) there are some spill controls so you can refine the key a bit. To be honest with you, I'm not 100% sure what the controls are on MC Firsts "RGBKeyer" effect but I might have the time to do a video screenshare with you one time to show you how SpectraMatte works. Let me know.
