Latest post Fri, Jan 7 2022 2:49 PM by Dale Gagne. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Nov 5 2021 5:41 PM
    • Dale Gagne
    • Joined on Mon, Oct 24 2011
    • Toronto, Ontario
    • Posts 184
    • Points 2,075
    UME Export giving offline media warning
    Every time i export my timeline using UME to proRes Proxy I get a warning that media is offline continue or abort. I check th timeline before hand and nothing is offline. I relinked regardless and it seems to think it is relinking something despite all media is showing as online. Yet still the error persists. There are some muted clips on tracks but not offline. Is this a bug or intended behavior as it isn't happening with 1 editor i work with but consistently with the other.
    Is there a way to remove any phantom media? Fixes?
    Avid MC 2021.6, Avid Mojo DX, Mac Pro, Mid 2012 (5,1), 2x2.4 ghz 6 CORE Intel Xeon, 64GB Ram, SSD Startup, 10.14.6, Radeon RX 580 8g[metal compatible 8gb... [view my complete system specs]
  • Fri, Nov 5 2021 6:05 PM In reply to
    Re: UME Export giving offline media warning
    If it's happening with some people and not others on the same sequences I'd try new user settings and see if it goes away.
    Media Composer 2022.4 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Fri, Nov 5 2021 7:15 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 184
    • Points 2,075
    I'll give it a try but it is different sequences with same user profile.
  • Fri, Nov 5 2021 8:40 PM In reply to
    Dale Gagne:
    Dale Gagne:
    Sorry for the confusion. The first line read like there were multiple users and only some of them were having the problem.
  • Fri, Nov 5 2021 9:41 PM In reply to
    If you have multicam/group clips, commit them before exporting. See if that fixes the issue.
    MC 2022, W10, MSI X299M, Intel 9940X, Gigabyte 3080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Big... [view my complete system specs]
  • Sat, Nov 6 2021 2:40 PM In reply to
    I've seen this, too...
    in my case, it was a project created in an previous version (of which I have many, but only this one generated the error). I'm not sure what about THIS sequence triggered it, and I didn't take the time to investigate...I just selected all the clips, moved them up one layer using the segment overwrite tool, then moved them back down and the problem went away.
    No idea what it was...
    Custom, i9-9900K, AMD Radeon VII 64 GB RAM, m.2 SSD, 8x 10GigE to Terrablock, BM SDI 4k, currently running Mac OS 12.2.1. MC Ultimate 2021.12-2 [view my complete system specs]
  • Mon, Nov 8 2021 2:50 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 184
    • Points 2,075
    Although the original bin is coming from 2021.2 and I am exporting from 2021.9 this fix didn't work. Still reporting offline media where there is nothing offline. Thanks though.
  • Tue, Nov 30 2021 10:19 PM In reply to
    • bravedog
    • Joined on Wed, Apr 30 2014
    • Posts 1
    • Points 15
    I am on 2021.9 and experiencing the same error message on every export.
  • Mon, Dec 6 2021 1:54 AM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,568
    • Points 64,850
      Moderator: MCA Mac
    Me too.  It started when I upgraded to 2021.9 while the rest of the team stayed on 2021.5.
  • Wed, Dec 8 2021 8:11 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 184
    • Points 2,075
    Commiting group clips didn't resolve the issue and we're now seeing it between the other assistant and editor that are both running 2021.9 . Nothing reports offline when >Bin Display>Show source and reference clips is enabled. And nothing appears offline in the actual timeline. Wondering if this is a bug with effects on filler tracks which was always okay before. Can't think of what else it might be.
  • Fri, Jan 7 2022 11:24 AM In reply to
    Dale Gagne:
    I saw this in 2021.9, too. There were a bunch of bugs in 2021.x relating to media showing offline. None of them described this specific scenario, but my gut feeling is they were similar enough that they may have been related.
    [edited to add] I sent a bunch of shows to network QC after seeing the 'media is offline' warning and none were rejected, so if you're in the situation where you see the warning but you're pretty sure all your media is online, I think you can ignore the warning.
    At any rate, it's fixed in 2021.12, and I haven't seen the problem pop up again.
  • Fri, Jan 7 2022 2:49 PM In reply to
    • Dale Gagne
    • Toronto, Ontario
    • Posts 184
    • Points 2,075
    I saw this particular bug was resolved in .12 as well however overall i started to experience really slow bin/timeline loading, overall app performance at app level actions seemed really slow. I did see improved speeds in bin creation, saving however.  I have actually rolled back to .6 as this also had no bugs and runs faster at all levels than .12 seems to unfortunately. Wait for the 2022 release I guess....hit and miss....
