Latest post Mon, Jan 24 2022 4:35 PM by Jasper Quispel. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Oct 11 2021 1:39 PM
    • insch
    • Posts 368
    • Points 4,330
    DISK_LOCKED errors and MC crashes
    I am getting sporadic DISK_LOCKED errors with my current project and then it crashes. Otherwise the project seems to be stable. I am not aware of any locked disks and I checked that none were running very full as I read that can be the cause of this error message sometimes. I am using a mixture of linked 4k and HD media from several drives and some transcoded media on the project. I'm using MC version 2021.9.
    Any thoughts/advice?
    Mac Pro, 3.7 GHz Quad-core, 64GB RAM, G-Tech G-RAID Studio 6TB and 10TB etc. [view my complete system specs]
  • Mon, Oct 11 2021 10:00 PM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,568
    • Points 64,850
      Moderator: MCA Mac
    Re: DISK_LOCKED errors and MC crashes
    Check permissions on the drive where your Project is located to make sure you have Read/Write access.
    Also, if you're running Mojave and you've installed Legacy Components you might need to change the permissions to Read/Write for Everyone on the Site Attributes file inside of Applications/Avid Media Composer/Settings.
    To change permissions, click on the file, Get Info (Cmd-I), unlock by clicking on the padlock in the lower left corner and change.
  • Wed, Oct 13 2021 8:12 AM In reply to
    • insch
    • Posts 368
    • Points 4,330
    hbrock:
    Thank you
    Top level of my Mac HD doesn't have me listed for permissions - see grab - and I can't add myself. But I do have permissions for my User folder where the Avid Projects folder resides. This DISK_LOCKED error comes and goes which is rather strange. Site Attributes has permissions for everyone. Any other thoughts?
  • Thu, Oct 14 2021 11:10 AM In reply to
    • insch
    • Posts 368
    • Points 4,330
    Still no joy with this issue. I am still getting the DISK-LOCKED error and sporadic crashes with my MC project. The disk that the project is hosted on is not locked and I have permissions to the relevant folders. The drive is also not full. Any advice on how to resolve this?
  • Thu, Oct 14 2021 12:03 PM In reply to
    Have you tried fixing permissions on the relevant drive? Macs can end up with orphaned permissions that aren't reflected in that top level permissions detail.
    T 07581 201248 | E pat@vet-training.co.uk | www.vet-training.co.uk|
  • Thu, Oct 14 2021 2:34 PM In reply to
    • insch
    • Posts 368
    • Points 4,330
    Pat Horridge:
    Thanks Pat. I am working with Big Sur. There no longer seems to be an option to fix permissions as a separate act but I booted into Recovery Mode and ran First Aid. Will that suffice?
  • Fri, Oct 15 2021 6:34 PM In reply to
    • insch
    • Posts 368
    • Points 4,330
    MC still crashing after disk first aid but not sure if I've seen the error. Some of crash report below:
    Process:               AvidMediaComposer [10170]
    Path:                  /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
    Identifier:            AvidMediaComposer
    Version:               21.9.0.55465 (21.9.0)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           AvidMediaComposer [10170]
    User ID:               501
    Date/Time:             2021-10-15 19:15:30.689 +0100
    OS Version:            macOS 11.6 (20G165)
    Report Version:        12
    Anonymous UUID:        D785EB87-0928-857B-A388-D48D9A7CC808
    Time Awake Since Boot: 40000 seconds
    System Integrity Protection: enabled
    Crashed Thread:        225  Dispatch queue: com.apple.audio.HALB_DQ.ClientNormalPrioritySerialQueue
    Exception Type:        EXC_CRASH (SIGABRT)
    Exception Codes:       0x0000000000000000, 0x0000000000000000
    Exception Note:        EXC_CORPSE_NOTIFY
    Application Specific Information:
    abort() called
    AvidMediaComposer(10170,0x700007ebb000) malloc: *** error for object 0xffffffff: pointer being freed was not allocated
  • Tue, Oct 19 2021 7:46 AM In reply to
    • insch
    • Posts 368
    • Points 4,330
    I am still getting the DISK_LOCKED error - intermittently, which is strange. I host my Avid Projects folder in my Dropbox folder on my Mac HD so I can easily work on projects across my different Macs. I have never had any problems working this way before. Could this now be causing an issue with MC and intermittent disk permissions issues? Obviously I have Read/Write permissions on my Dropbox folder. I have now moved my Avid Projects folder to an external drive outside of Dropbox to see if that makes a difference.
    Any thoughts?
  • Tue, Oct 19 2021 10:45 AM In reply to
    • insch
    • Posts 368
    • Points 4,330
    Moving Avid Projects folder to another location didn't fix it - not sure about whether a DISK_LOCKED error came up but I went out to walk the dog and came in to find the project had crashed again.
    Actually just saw in the crash report that DISK_LOCKED is still there - this is a new location on a different drive - neither of which are locked.
    Crashed Thread:        0  Main Thread  Dispatch queue: com.apple.main-thread
    terminating with uncaught exception of type XError: DISK_LOCKED
    abort() called
    Have now tried creating a new project and putting my bins in there.
  • Sat, Oct 30 2021 11:27 AM In reply to
    • insch
    • Posts 368
    • Points 4,330
    Anyone?
    This problem hasn't gone away - new Mac, new SSD, same problem with Media Composer crashes and DISK_LOCKED errors - below is latest crash report.
    Crash report:
    Process:               AvidMediaComposer [43771]
    Responsible:           AvidMediaComposer [43771]
    User ID:               501
    Date/Time:             2021-10-30 11:27:43.993 +0100
    Report Version:        12
    Bridge OS Version:     5.5 (18P4759a)
    Anonymous UUID:        B4D51BF7-CD96-FD4C-A2CB-01B0B2CCE4EC
    Time Awake Since Boot: 98000 seconds
    abort() called
    Thread 0 Crashed:: Main Thread  Dispatch queue: com.apple.main-thread
    0   libsystem_kernel.dylib            0x00007fff203b792e __pthread_kill + 10
    1   libsystem_pthread.dylib           0x00007fff203e65bd pthread_kill + 263
    2   libsystem_c.dylib                 0x00007fff2033b406 abort + 125
    3   com.avid.mediacomposer            0x0000000103bf1092 mcabort(int) + 74
    4   libsystem_platform.dylib          0x00007fff2042bd7d _sigtramp + 29
    5   ???                               0x00007ffeec0808d0 0 + 140732858370256
    6   libsystem_c.dylib                 0x00007fff2033b406 abort + 125
    7   libc++abi.dylib                   0x00007fff203a9ef2 abort_message + 241
    8   libc++abi.dylib                   0x00007fff2039b5e5 demangling_terminate_handler() + 242
    9   libobjc.A.dylib                   0x00007fff20294595 _objc_terminate() + 104
    10  libc++abi.dylib                   0x00007fff203a9307 std::__terminate(void (*)()) + 8
    11  libc++abi.dylib                   0x00007fff203a92a9 std::terminate() + 41
    12  com.avid.mediacomposer            0x0000000104ff755c BlipPlayer::PlayBlipField(BlipPlayUIMonPane&, int, int, int, videoField_t, int) + 918
    13  com.avid.mediacomposer            0x000000010508bc91 ObsoleteHighLevelPlayer::CropAndPlayBlipField(bool, BlipPlayUIMonPane&, int, int, int, videoField_t, int) + 173
    14  com.avid.mediacomposer            0x0000000105068b74 MonPane::PlayBlipOnscreen(int, unsigned char, AvRect*, AvRect*, unsigned char, unsigned char) + 728
    15  com.avid.mediacomposer            0x000000010500095d AMonitorPane::PlayBlip(int, unsigned char, AvRect*, unsigned char) + 1029
    16  com.avid.mediacomposer            0x0000000104fe89e6 MonViewPane::DrawVideoFrame(int, AvRect*, unsigned char, unsigned char, unsigned char) + 246
    17  com.avid.mediacomposer            0x0000000104fe8564 MonViewPane::DrawWithAudio(AvRect*, unsigned char, unsigned char) + 2172
    18  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    19  libUIshell.dylib                  0x00000001213a1a49 APane::DrawDetail(AvRect*, AvRGBColor, void*) + 1007
    20  libUIshell.dylib                  0x00000001213a13a8 APane::DrawInterior(AvRect*, void*) + 540
    21  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    22  libUIshell.dylib                  0x00000001213a1a49 APane::DrawDetail(AvRect*, AvRGBColor, void*) + 1007
    23  libUIshell.dylib                  0x00000001213a13a8 APane::DrawInterior(AvRect*, void*) + 540
    24  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    25  libUIshell.dylib                  0x00000001213a1a49 APane::DrawDetail(AvRect*, AvRGBColor, void*) + 1007
    26  libUIshell.dylib                  0x00000001213a13a8 APane::DrawInterior(AvRect*, void*) + 540
    27  libUIshell.dylib                  0x00000001213a0714 APane::Draw(AvRect*, void*) + 214
    28  libUIshell.dylib                  0x0000000121394102 AWindow::Update(void*, Mac2Qt::EventRecord*, int, int) + 454
    29  libUIshell.dylib                  0x000000012139785a AWindow::DoWindowMsg(windowMsgID_t, void*, Mac2Qt::EventRecord*, int, int, int) + 112
    30  com.avid.mediacomposer            0x00000001045cd0ba ComposerWindow::DoWindowMsg(windowMsgID_t, void*, Mac2Qt::EventRecord*, int, int, int) + 164
    31  libUIshell.dylib                  0x0000000121392e0e AWindow::SendMsg(windowMsgID_t, Mac2Qt::EventRecord*, int, int, int) + 188
    32  libUIshell.dylib                  0x00000001213ba9fd AApplication::HandleEvent(Mac2Qt::EventRecord*) + 1105
    33  com.avid.mediacomposer            0x0000000103bf792a MediaComposerApp::HandleEvent(Mac2Qt::EventRecord*) + 100
    34  libUIshell.dylib                  0x00000001213bb09c AApplication::ProcessCurrentEventImpl(bool, bool, bool*) + 510
    35  libUIshell.dylib                  0x00000001213c17f6 AApplication::CarbonEventHandlerProc(Mac2Qt::Private::EventHandlerCall*, Mac2Qt::Private::EventQueueItem*, void*) + 410
    36  com.avid.Mac2Qt                   0x0000000126d01220 Mac2Qt::Private::EventHandlerCall::invokeNextHandler() + 278
    37  com.avid.Mac2Qt                   0x0000000126d00fa1 Mac2Qt::Private::DispatchEventToCallbacks(Mac2Qt::Private::EventQueueItemSmartPtr const&) + 324
    38  com.avid.Mac2Qt                   0x0000000126d030a8 Mac2Qt::Private::Mac2QtEventWaiter::eventFilter(QObject*, QEvent*) + 132
    39  org.qt-project.QtCore             0x0000000108027bb1 QCoreApplicationPrivate::sendThroughApplicationEventFilters(QObject*, QEvent*) + 193
    40  org.qt-project.QtWidgets          0x00000001091ecc62 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 66
    41  org.qt-project.QtWidgets          0x00000001091ee0f7 QApplication::notify(QObject*, QEvent*) + 471
    42  com.avid.Mac2Qt                   0x0000000126d10bbe Mac2Qt::AQtApplication::notify(QObject*, QEvent*) + 406
    43  org.qt-project.QtCore             0x0000000108027a24 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
    44  org.qt-project.QtCore             0x0000000108028a32 QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 402
    45  libqcocoa.dylib                   0x0000000130611712 QCocoaEventDispatcherPrivate::processPostedEvents() + 322
    46  libqcocoa.dylib                   0x0000000130611e28 QCocoaEventDispatcherPrivate::postedEventsSourceCallback(void*) + 40
    47  com.apple.CoreFoundation          0x00007fff204de2bc __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
    48  com.apple.CoreFoundation          0x00007fff204de224 __CFRunLoopDoSource0 + 180
    49  com.apple.CoreFoundation          0x00007fff204ddfa4 __CFRunLoopDoSources0 + 242
    50  com.apple.CoreFoundation          0x00007fff204dc9cc __CFRunLoopRun + 893
    51  com.apple.CoreFoundation          0x00007fff204dbf8c CFRunLoopRunSpecific + 563
    52  com.apple.HIToolbox               0x00007fff287241f3 RunCurrentEventLoopInMode + 292
    53  com.apple.HIToolbox               0x00007fff28723f55 ReceiveNextEventCommon + 587
    54  com.apple.HIToolbox               0x00007fff28723cf3 _BlockUntilNextEventMatchingListInModeWithFilter + 70
    55  com.apple.AppKit                  0x00007fff22ce5172 _DPSNextEvent + 864
    56  com.apple.AppKit                  0x00007fff22ce3945 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1364
    57  com.apple.AppKit                  0x00007fff22cd5c69 -[NSApplication run] + 586
    58  libqcocoa.dylib                   0x0000000130610c2c QCocoaEventDispatcher::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 2652
    59  org.qt-project.QtCore             0x0000000108023b9f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
    60  org.qt-project.QtCore             0x0000000108027fb2 QCoreApplication::exec() + 130
    61  com.avid.Mac2Qt                   0x0000000126d0223b Mac2Qt::Private::Mac2QtEventWaiter::RunApplicationEventLoop() + 73
    62  com.avid.Mac2Qt                   0x0000000126cf7959 Mac2Qt::RunApplicationEventLoop() + 29
    63  libUIshell.dylib                  0x00000001213ba3c7 AApplication::Run() + 9
    64  libUIshell.dylib                  0x00000001213b7718 AApplication::Go() + 98
    65  com.avid.mediacomposer            0x0000000103be1570 main + 738
    66  libdyld.dylib                     0x00007fff20401f3d start + 1
    Thread 1:: com.apple.NSEventThread
    0   libsystem_kernel.dylib            0x00007fff203b12ba mach_msg_trap + 10
    1   libsystem_kernel.dylib            0x00007fff203b162c mach_msg + 60
    2   com.apple.CoreFoundation          0x00007fff204de49f __CFRunLoopServiceMachPort + 316
    3   com.apple.CoreFoundation          0x00007fff204dcb7f __CFRunLoopRun + 1328
    4   com.apple.CoreFoundation          0x00007fff204dbf8c CFRunLoopRunSpecific + 563
    5   com.apple.AppKit                  0x00007fff22e6b23a _NSEventThread + 124
    6   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    7   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 2:
    2   com.googlecode.google-breakpad    0x000000011f5ec6d1 google_breakpad::ExceptionHandler::WaitForMessage(void*) + 231
    3   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    4   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 3:: MTThreadCoreThreads
    0   libsystem_kernel.dylib            0x00007fff203b12f6 semaphore_wait_trap + 10
    1   libdispatch.dylib                 0x00007fff2023cc9b _dispatch_sema4_wait + 16
    2   libdispatch.dylib                 0x00007fff2023d16d _dispatch_semaphore_wait_slow + 98
    3   com.avid.AvidCoreThreads          0x000000011f17f31e Threads::SemaRepNative::Decrement(char const*, long) + 214
    4   com.avid.AvidCore                 0x0000000120286a7c MTSemaphoreCoreThreads::Decrement(unsigned long, unsigned int) + 124
    5   com.avid.AvidStorageAPI           0x000000012bf813ce StorageAPI::CommandProcessor::Body(StorageAPI::MTThread*) + 70
    6   com.avid.AvidStorageAPI           0x000000012bf829e9 StorageAPI::MTThread::Run() + 27
    7   com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    8   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    9   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 4:: MTThreadCoreThreads
    Thread 5:: MTThreadCoreThreads
    Thread 6:: MTThreadCoreThreads
    Thread 7:: MTThreadCoreThreads
    Thread 8:: MTThreadCoreThreads
    Thread 9:
    0   libsystem_kernel.dylib            0x00007fff203b3cde __psynch_cvwait + 10
    1   libsystem_pthread.dylib           0x00007fff203e6e49 _pthread_cond_wait + 1298
    2   com.avid.AvidCoreThreads          0x000000011f185b0a Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long, int, void**) + 59
    3   com.avid.AvidCoreThreads          0x000000011f186be2 CoreThreadsMessageQueue::RemoveNext(Threads::Message**, long*, bool*, Threads::Message**, long*, bool*, long, int, void**, bool (*)(Threads::Message const*)) + 130
    4   com.avid.AvidCoreThreads          0x000000011f182896 Threads::ThreadImp::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 880
    5   com.avid.AvidCoreThreads          0x000000011f17c486 Threads::Messaging::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 90
    6   com.avid.AvidCoreThreads          0x000000011f17f9e9 Threads::Body::ThreadBody() + 33
    Thread 10:
    5   com.apple.CoreFoundation          0x00007fff205628b2 CFRunLoopRun + 40
    6   com.apple.AVCVideoServices        0x0000000273d46596 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 129
    7   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    8   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 11:: FlamethrowerThreadedLinkManagerRep::m_pLinkManagerThread
    6   com.avid.macflamethrowerohci      0x0000000273c2a45f (anonymous namespace)::FlamethrowerThreadedLinkManagerThread::ThreadBody() + 177
    Thread 12:: Pyromaniac DIO FireBOBEventThread
    Thread 13:: Pyromaniac DIO DevicePortBusResetThread
    Thread 14:: *PMDIO_IOManagerRep::IOThread
    6   com.apple.diopyromaniacohci       0x000000027392be72 PMDIO_IOThreadBody::ThreadBody() + 74
    Thread 15:: PMDIO_InputModeRep::AudioInCBThread
    Thread 16:: PMDIO_OutputModeRep::VideoCBThread
    Thread 17:: *PMDIO_OutputModeRep::AudioCBThread
    Thread 18:: AVCReceiverThread
    6   com.apple.diopyromaniacohci       0x000000027393c95e PMDIODeviceControlRep::AVCReceiverThread() + 96
    7   com.apple.diopyromaniacohci       0x000000027393c8fe AVCReceiverThreadJacket(void*) + 9
    8   com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    9   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    10  libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 19:: AMEParameterControlManager::ConsolidateThreadBody
    6   libameLibrary.dylib               0x00000001222f84c9 AMEParameterControlManager::ConsolidateThreadBody() + 99
    Thread 20:: QThread
    0   libsystem_kernel.dylib            0x00007fff203b79ca poll + 10
    1   org.qt-project.QtCore             0x0000000108088060 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 480
    2   org.qt-project.QtCore             0x00000001080897c2 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 978
    3   org.qt-project.QtCore             0x0000000108023b9f QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 431
    4   org.qt-project.QtCore             0x0000000107e45593 QThread::exec() + 131
    5   org.qt-project.QtCore             0x0000000107e464b9 QThreadPrivate::start(void*) + 329
    Thread 21:: Qt bearer thread
    Thread 22:: QNetworkAccessManager thread
    Thread 23:: NDIVideoThread
    2   com.avid.AvidCoreThreads          0x000000011f185ba0 Threads::NativeCondWait(_opaque_pthread_cond_t*, _opaque_pthread_mutex_t*, long, int, void**) + 209
    3   com.avid.AvidCoreThreads          0x000000011f17df50 RealTimeMessageQueueCondWait::WaitForMessageQueueSignal(long, int, void**) + 144
    4   com.avid.AvidCoreThreads          0x000000011f17ddce Threads::RealTimeMessageQueue::RemoveNext(Threads::Message**, long*, bool*, Threads::Message**, long*, bool*, long, int, void**, bool (*)(Threads::Message const*)) + 116
    5   com.avid.AvidCoreThreads          0x000000011f182896 Threads::ThreadImp::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 880
    6   com.avid.AvidCoreThreads          0x000000011f17c486 Threads::Messaging::WaitForThreadMessage(Threads::Message**, long, bool (*)(Threads::Message const*), int, void**) + 90
    7   com.Avid.OpenIO-NDI               0x000000027d78c636 ThreadBase::DoWaitThreadMessage(long long, Threads::Message**) const + 22
    8   com.Avid.OpenIO-NDI               0x000000027d783dee NDI_PlayThread::DoProcess() + 332
    9   com.Avid.OpenIO-NDI               0x000000027d78bf7f ThreadBase::ThreadBody() + 99
    10  com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    11  libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    12  libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 24:: HWSDK Audio Events
    7   com.Avid.HWSDK                    0x000000027dd92a8b HWSDK::AudioSignal::ThreadBody() + 573
    Thread 25:: Waveform Cache Thread
    Thread 26:: Waveform Cache Thread
    Thread 27:: Waveform Cache Thread
    Thread 28:: Waveform Cache Thread
    Thread 29:
    2   libc++.1.dylib                    0x00007fff2034fe03 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93
    3   com.paceap.eden.WrapPersist       0x0000000297424bc2 0x29722e000 + 2059202
    4   com.paceap.eden.WrapPersist       0x000000029742c37d 0x29722e000 + 2089853
    5   com.paceap.eden.WrapPersist       0x000000029742c304 0x29722e000 + 2089732
    6   com.paceap.eden.WrapPersist       0x000000029742c1d9 0x29722e000 + 2089433
    Thread 30:: Tsk_ManagerImpl #0
    1   com.digidesign.framework.PlatformSupport    0x000000029066e90b CSyncPrim_Semaphore_MachImp::Acquire(unsigned long long) + 87
    2   com.digidesign.framework.MoreFoundation    0x000000029198c9a4 Tsk_ManagerImpl::Thread_WorkerFn(Tsk_ManagerImpl::ThreadCtx*) + 66
    3   com.digidesign.framework.MoreFoundation    0x000000029198c923 Tsk_ManagerImpl::Thread_WorkerFn_Static(void*, IPSThread*) + 73
    4   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    5   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    6   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 31:: Tsk_ManagerImpl #1
    Thread 32:: Tsk_ManagerImpl #2
    Thread 33:: Tsk_ManagerImpl #3
    Thread 34:: High Latency Thread
    2   com.avid.framework.AAE            0x0000000292528b3a CSimpleThread::Wait() + 26
    3   com.avid.framework.AAE            0x00000002924f4d2d CHighLatencyThread::Exec() + 35
    4   com.avid.framework.AAE            0x000000029252877f CSimpleThread::StaticThreadProc(void*, IPSThread*) + 15
    5   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    Thread 35:: LL Thread 0
    2   com.digidesign.framework.CoreFoundation    0x00000002916af6cf Sys_SpinningSemaphore::Acquire(bool, bool*) + 159
    3   com.avid.framework.AAE            0x00000002924950fa avid::aae::CHostWorkerEngineThreadingPolicy::Wait(CProcessingThread*, bool const&, bool, CProcessorExecutionTimer*, bool&, bool&, InterruptProfiler*) + 180
    4   com.avid.framework.AAE            0x000000029255c570 avid::aae::CHostWorkerEngineProcessingThreadPool::ProcessLoop(CProcessingThread*) + 182
    5   com.avid.framework.AAE            0x000000029252877f CSimpleThread::StaticThreadProc(void*, IPSThread*) + 15
    6   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    Thread 36:: LL Thread 1
    Thread 37:: LL Thread 2
    Thread 38:: LL Thread 3
    Thread 39:: LL Thread 4
    Thread 40:: LL Thread 5
    Thread 41:: LL Thread 6
    Thread 42:: LL Thread 7
    Thread 43:: LL Thread 8
    Thread 44:: LL Thread 9
    Thread 45:: LL Thread 10
    Thread 46:: LL Thread 11
    Thread 47:: LL Thread 12
    Thread 48:: LL Thread 13
    Thread 49:: LL Thread 14
    Thread 50:: LL Thread 15
    Thread 51:: LL Thread 16
    Thread 52:: LL Thread 17
    Thread 53:: LL Thread 18
    Thread 54:: LL Thread 19
    Thread 55:: LL Thread 20
    Thread 56:: LL Thread 21
    Thread 57:: LL Thread 22
    Thread 58:: LL Thread 23
    Thread 59:: HBL Thread 0
    Thread 60:: HBL Thread 1
    Thread 61:: HBL Thread 2
    Thread 62:: HBL Thread 3
    Thread 63:: HBL Thread 4
    Thread 64:: HBL Thread 5
    Thread 65:: HBL Thread 6
    Thread 66:: HBL Thread 7
    Thread 67:: HBL Thread 8
    Thread 68:: HBL Thread 9
    Thread 69:: HBL Thread 10
    Thread 70:: HBL Thread 11
    Thread 71:: HBL Thread 12
    Thread 72:: HBL Thread 13
    Thread 73:: HBL Thread 14
    Thread 74:: HBL Thread 15
    Thread 75:: HBL Thread 16
    Thread 76:: HBL Thread 17
    Thread 77:: HBL Thread 18
    Thread 78:: HBL Thread 19
    Thread 79:: HBL Thread 20
    Thread 80:: HBL Thread 21
    Thread 81:: HBL Thread 22
    Thread 82:: HBL Thread 23
    Thread 83:: HL Thread 0
    Thread 84:: HL Thread 1
    Thread 85:: HL Thread 2
    Thread 86:: HL Thread 3
    Thread 87:: HL Thread 4
    Thread 88:: HL Thread 5
    Thread 89:: HL Thread 6
    Thread 90:: HL Thread 7
    Thread 91:: HL Thread 8
    Thread 92:: HL Thread 9
    Thread 93:: HL Thread 10
    Thread 94:: HL Thread 11
    Thread 95:: HL Thread 12
    Thread 96:: HL Thread 13
    Thread 97:: HL Thread 14
    Thread 98:: HL Thread 15
    Thread 99:: HL Thread 16
    Thread 100:: HL Thread 17
    Thread 101:: HL Thread 18
    Thread 102:: HL Thread 19
    Thread 103:: HL Thread 20
    Thread 104:: HL Thread 21
    Thread 105:: HL Thread 22
    Thread 106:: HL Thread 23
    Thread 107:: AAXH PluginIdleTask
    0   libsystem_kernel.dylib            0x00007fff203b130e semaphore_timedwait_trap + 10
    1   com.digidesign.framework.PlatformSupport    0x000000029066e8fc CSyncPrim_Semaphore_MachImp::Acquire(unsigned long long) + 72
    2   com.digidesign.framework.PlatformSupport    0x000000029067889b CSyncPrim_AutoResetEvent_Imp::Acquire(unsigned long long) + 19
    3   com.digidesign.framework.CoreFoundation    0x0000000291697c7d Sys_BlockingTimer_PS::WaitOnTimer() + 183
    4   com.digidesign.framework.CoreFoundation    0x0000000291682d04 Sys_RawThreadTimerTask::Exec() + 132
    5   com.digidesign.framework.CoreFoundation    0x0000000291682885 Sys_RawThreadTask::Run() + 45
    6   com.digidesign.framework.CoreFoundation    0x0000000291697f01 Sys_RawThread_PS::ThreadMethod(IPSThread*) + 13
    7   com.digidesign.framework.CoreFoundation    0x0000000291697f21 non-virtual thunk to Sys_RawThread_PS::ThreadMethod(IPSThread*) + 13
    8   com.digidesign.framework.PlatformSupport    0x000000029066f655 CTask_Imp::MacOSXMasterThreadProc(void*) + 95
    Thread 108:: AAXH PluginComponentBackground
    Thread 109:
    5   com.digidesign.framework.CoreFoundation    0x00000002916dcaaf Sys_FolderWatchMacOS::ThreadMethod() const + 117
    6   com.digidesign.framework.CoreFoundation    0x00000002916dc776 Sys_FolderWatchMacOS::ThreadMethod_Static(void*, IPSThread*) + 10
    7   com.digidesign.framework.PlatformSupport    0x000000029066f669 CTask_Imp::MacOSXMasterThreadProc(void*) + 115
    Thread 110:: AudioSuiteThread
    6   libAMPIHost.dylib                 0x000000011f610a92 AMPIAudioSuiteManagerRep::AudioSuiteThreadBody() + 78
    Thread 111:: AMCP Logging Spool
    1   com.apple.audio.caulk             0x00007fff284a38da caulk::mach::semaphore::wait_or_error() + 16
    2   com.apple.audio.caulk             0x00007fff28490836 caulk::semaphore::timed_wait(double) + 110
    3   com.apple.audio.caulk             0x00007fff28490784 caulk::concurrent::details::worker_thread::run() + 30
    4   com.apple.audio.caulk             0x00007fff28490502 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
    Thread 112:: MVP_Host_Processing
    Thread 113:: MSP_Host_Processing
    Thread 114:
    2   libc++.1.dylib                    0x00007fff2034fd72 std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18
    3   com.avid.LEPCore                  0x00000002967f30bb LEP::Event::Wait(unsigned int) + 187
    4   com.avid.LEPCore                  0x0000000296822b41 LEP::Logger::ThreadFunc() + 193
    5   com.avid.LEPCore                  0x00000002968234e1 std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::Logger::*)(), LEP::Logger*> >::__execute() + 49
    6   com.avid.LEPCore                  0x00000002968235c1 void* std::__1::__thread_proxy<std::__1::tuple<void (std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::Logger::*)(), LEP::Logger*> >::*)(), std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::Logger::*)(), LEP::Logger*> >*> >(void*) + 113
    Thread 115:
    4   com.avid.LEPCore                  0x00000002967f46e0 LEP::ExecutionPool::DispatcherEntry() + 208
    5   com.avid.LEPCore                  0x00000002967f70c1 std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::__execute() + 49
    6   com.avid.LEPCore                  0x00000002967f7271 void* std::__1::__thread_proxy<std::__1::tuple<void (std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::*)(), std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >*> >(void*) + 113
    Thread 116:
    3   com.avid.LEPCore                  0x00000002967f3550 std::__1::cv_status std::__1::condition_variable::wait_until<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::steady_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > > const&) + 128
    4   com.avid.LEPCore                  0x00000002967f3073 LEP::Event::Wait(unsigned int) + 115
    5   com.avid.LEPCore                  0x00000002967f4f97 LEP::ExecutionPool::WorkerEntry() + 807
    6   com.avid.LEPCore                  0x00000002967f70c1 std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::__execute() + 49
    7   com.avid.LEPCore                  0x00000002967f7271 void* std::__1::__thread_proxy<std::__1::tuple<void (std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >::*)(), std::__1::__async_assoc_state<int, std::__1::__async_func<int (LEP::ExecutionPool::*)(), LEP::ExecutionPool*> >*> >(void*) + 113
    Thread 117:
    1   com.apple.CoreServices.CarbonCore    0x00007fff228ba320 MPWaitOnSemaphore + 74
    2   REDR3D.dylib                      0x000000029c35ec87 0x29c217000 + 1342599
    3   REDR3D.dylib                      0x000000029c315e02 0x29c217000 + 1043970
    4   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    5   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 118:
    2   REDR3D.dylib                      0x000000029c35f807 0x29c217000 + 1345543
    Thread 119:
    Thread 120:
    Thread 121:
    Thread 122:
    Thread 123:
    Thread 124:
    Thread 125:
    Thread 126:
    Thread 127:
    Thread 128:
    Thread 129:
    Thread 130:
    Thread 131:
    Thread 132:
    Thread 133:
    Thread 134:
    Thread 135:
    Thread 136:
    Thread 137:
    Thread 138:
    Thread 139:
    Thread 140:
    Thread 141:
    Thread 142:
    6   com.avid.AMADeviceMonitor         0x000000029da302e4 AMA::Impl::CAMADeviceMonitor::ThreadMain(void*) + 164
    Thread 143:
    2   mt.dylib                          0x00000001263e9deb CMTSingleTaskThread::ThreadFunctionImplementation() + 155
    3   mt.dylib                          0x00000001263e96ba CMTThreadImpl::Entry_point(void*) + 10
    Thread 144:
    2   ilgpu.dylib                       0x000000027b8061bd siilgpu::CommandProcessor::Execute() + 477
    3   mt.dylib                          0x00000001263e9d88 CMTSingleTaskThread::ThreadFunctionImplementation() + 56
    4   mt.dylib                          0x00000001263e96ba CMTThreadImpl::Entry_point(void*) + 10
    Thread 145:: Viewer Worker Thread
    6   com.avid.AvidCore                 0x0000000120366422 Viewer::ViewerThreadBody::ThreadBody() + 98
    Thread 146:: Viewer Worker Thread
    Thread 147:: Viewer Worker Thread
    Thread 148:: Viewer Worker Thread
    Thread 149:: Viewer Worker Thread
    Thread 150:: Viewer Worker Thread
    Thread 151:: Viewer Worker Thread
    Thread 152:: Viewer Worker Thread
    Thread 153:: Viewer Worker Thread
    Thread 154:: Viewer Worker Thread
    Thread 155:: Viewer Worker Thread
    Thread 156:: Viewer Worker Thread
    Thread 157:: Viewer Worker Thread
    Thread 158:: Viewer Worker Thread
    Thread 159:: Viewer Worker Thread
    Thread 160:: Viewer Worker Thread
    Thread 161:: Viewer Worker Thread
    Thread 162:: Viewer Worker Thread
    Thread 163:: Viewer Worker Thread
    Thread 164:: Viewer Worker Thread
    Thread 165:: Viewer Worker Thread
    Thread 166:: Viewer Worker Thread
    Thread 167:: Viewer Worker Thread
    Thread 168:: Viewer Worker Thread
    Thread 169:: Viewer Worker Thread
    Thread 170:: Viewer Worker Thread
    Thread 171:: Viewer Worker Thread
    Thread 172:: Viewer Worker Thread
    Thread 173:: Viewer Worker Thread
    Thread 174:: Viewer Worker Thread
    Thread 175:: Viewer Worker Thread
    Thread 176:: Viewer Worker Thread
    Thread 177:
    1   libtbb.dylib                      0x000000012bfb361a tbb::internal::rml::private_worker::thread_routine(void*) + 362
    2   libsystem_pthread.dylib           0x00007fff203e68fc _pthread_start + 224
    3   libsystem_pthread.dylib           0x00007fff203e2443 thread_start + 15
    Thread 178:
    Thread 179:
    Thread 180:
    Thread 181:
    Thread 182:
    Thread 183:
    Thread 184:
    Thread 185:
    Thread 186:
    Thread 187:
    Thread 188:
    Thread 189:
    Thread 190:
    Thread 191:
    Thread 192:
    Thread 193:
    Thread 194:
    Thread 195:
    Thread 196:
    Thread 197:
    Thread 198:
    Thread 199:
    Thread 200:
    Thread 201:
    Thread 202:
    Thread 203:
    Thread 204:
    Thread 205:
    Thread 206:
    Thread 207:
    Thread 208:
    Thread 209:
    Thread 210:
    Thread 211:
    Thread 212:
    Thread 213:
    3   com.avid.CodecToolkit.CTSharedResourceHandling    0x00000002a1ccb36f 0x2a1cbd000 + 58223
    4   com.avid.CodecToolkit.CTSharedResourceHandling    0x00000002a1ccbd0b 0x2a1cbd000 + 60683
    Thread 214:
    Thread 215:
    Thread 216:
    Thread 217:
    Thread 218:
    Thread 219:
    Thread 220:
    Thread 221:
    Thread 222:
    Thread 223:
    Thread 224:
    Thread 225:
    Thread 226:
    Thread 227:
    Thread 228:
    Thread 229:
    Thread 230:
    Thread 231:
    Thread 232:
    Thread 233:
    Thread 234:
    Thread 235:
    Thread 236:
    Thread 237:
    2   com.apple.audio.midi.CoreMIDI     0x00007fff34e0bbd6 XServerMachPort::ReceiveMessage(int&, void*, int&) + 94
    3   com.apple.audio.midi.CoreMIDI     0x00007fff34e3c473 MIDIProcess::MIDIInPortThread::Run() + 111
    4   com.apple.audio.midi.CoreMIDI     0x00007fff34e224e2 XThread::RunHelper(void*) + 10
    5   com.apple.audio.midi.CoreMIDI     0x00007fff34e2365b CAPThread::Entry(CAPThread*) + 77
    Thread 238:: AsyncRead
    6   com.avid.mediacomposer            0x0000000104669352 OSXSerialIO::AsyncReadThread() + 442
    7   com.avid.mediacomposer            0x0000000104667a76 AsyncReadThreadJacket(void*) + 47
    Thread 239:: AsyncWrite
    6   com.avid.mediacomposer            0x000000010466940a OSXSerialIO::AsyncWriteThread() + 122
    7   com.avid.mediacomposer            0x0000000104667acb AsyncWriteThreadJacket(void*) + 47
    Thread 240:: AsyncRead
    Thread 241:: AsyncWrite
    Thread 242:: Viewer Worker Thread
    Thread 243:: Viewer Worker Thread
    Thread 244:: Viewer Worker Thread
    Thread 245:: Viewer Worker Thread
    Thread 246:: Viewer Worker Thread
    Thread 247:: Viewer Worker Thread
    Thread 248:: Viewer Worker Thread
    Thread 249:: Viewer Worker Thread
    Thread 250:: Viewer Worker Thread
    Thread 251:: Viewer Worker Thread
    Thread 252:: Chron
    6   com.avid.AvidCore                 0x0000000120279130 ChronBody::ThreadBody() + 354
    Thread 253:: ProgressBarOpenGLRender
    1   org.qt-project.QtCore             0x0000000108087ef0 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 112
    Thread 254:: QThread
    Thread 255:: AsyncRead
    Thread 256:: AsyncWrite
    Thread 257:: Viewer Worker Thread
    Thread 258:: QThread
    Thread 259:: QThread
    Thread 260:: ThreadedPeriodicTimer kExtraHighPriority Thread
    4   com.avid.AvidCore                 0x000000012033bdcc ThreadedPeriodicTimer::ProcessCallbacks() + 296
    5   com.avid.AvidCoreThreads          0x000000011f1818e0 Threads::ThreadImp::StarterFluid(void*) + 258
    Thread 261:: com.apple.CFSocket.private
    0   libsystem_kernel.dylib            0x00007fff203b9656 __select + 10
    1   com.apple.CoreFoundation          0x00007fff20504a03 __CFSocketManager + 630
    Thread 262:: PendingMediaHelper
    Thread 263:: QThread
    Thread 264:: PHTBody
    6   libameLibrary.dylib               0x00000001222130d5 PHT::PlayerHostThread::ThreadBody() + 85
    Thread 265:: AMEDeferredTaskExecutor 00
    4   com.avid.AvidCore                 0x00000001202411d3 AMEDeferredTaskExecutor::ThreadBody() + 1215
    Thread 266:: AMEDeferredTaskExecutor 00
    Thread 267:: AMEDeferredTaskExecutor 01
    Thread 268:: AMEDeferredTaskExecutor 02
    Thread 269:: AMEDeferredTaskExecutor 03
    Thread 270:: AMEDeferredTaskExecutor 04
    Thread 271:: AMEDeferredTaskExecutor 05
    Thread 272:: AMEDeferredTaskExecutor 06
    Thread 273:: AMEDeferredTaskExecutor 07
    Thread 274:: AMEDeferredTaskExecutor 08
    Thread 275:: AMEDeferredTaskExecutor 09
    Thread 276:: AMEDeferredTaskExecutor 10
    Thread 277:: AMEDeferredTaskExecutor 11
    Thread 278:: AMEDeferredTaskExecutor 12
    Thread 279:: AMEDeferredTaskExecutor 13
    Thread 280:: AMEDeferredTaskExecutor 14
    Thread 281:: AMEDeferredTaskExecutor 15
    Thread 282:: AMEDeferredTaskExecutor 16
    Thread 283:: AMEDeferredTaskExecutor 17
    Thread 284:: AMEDeferredTaskExecutor 18
    Thread 285:: AMEDeferredTaskExecutor 19
    Thread 286:: AMEDeferredTaskExecutor 20
    Thread 287:: AMEDeferredTaskExecutor 21
    Thread 288:: AMEDeferredTaskExecutor 22
    Thread 289:: AMEDeferredTaskExecutor 23
    Thread 290:: AMEDeferredTaskExecutor 00
    Thread 291:: AMEDeferredTaskExecutor 01
    Thread 292:: AMEDeferredTaskExecutor 02
    Thread 293:: AMEDeferredTaskExecutor 03
    Thread 294:: AMEDeferredTaskExecutor 04
    Thread 295:: AMEDeferredTaskExecutor 05
    Thread 296:: AMEDeferredTaskExecutor 06
    Thread 297:: AMEDeferredTaskExecutor 07
    Thread 298:: AMEDeferredTaskExecutor 08
    Thread 299:: AMEDeferredTaskExecutor 09
    Thread 300:: AMEDeferredTaskExecutor 10
    Thread 301:: AMEDeferredTaskExecutor 11
    Thread 302:: AMEDeferredTaskExecutor 12
    Thread 303:: AMEDeferredTaskExecutor 13
    Thread 304:: AMEDeferredTaskExecutor 14
    Thread 305:: AMEDeferredTaskExecutor 15
    Thread 306:: AMEDeferredTaskExecutor 16
    Thread 307:: AMEDeferredTaskExecutor 17
    Thread 308:: AMEDeferredTaskExecutor 18
    Thread 309:: AMEDeferredTaskExecutor 19
    Thread 310:: AMEDeferredTaskExecutor 20
    Thread 311:: AMEDeferredTaskExecutor 21
    Thread 312:: AMEDeferredTaskExecutor 22
    Thread 313:: AMEDeferredTaskExecutor 23
    Thread 314:: AMEDeferredTaskExecutor 00
    Thread 315:: AMEDeferredTaskExecutor 01
    Thread 316:: AMEDeferredTaskExecutor 02
    Thread 317:: AMEDeferredTaskExecutor 03
    Thread 318:: AMEDeferredTaskExecutor 04
    Thread 319:: AMEDeferredTaskExecutor 05
    Thread 320:: AMEDeferredTaskExecutor 06
    Thread 321:: AMEDeferredTaskExecutor 07
    Thread 322:: AMEDeferredTaskExecutor 08
    Thread 323:: AMEDeferredTaskExecutor 09
    Thread 324:: AMEDeferredTaskExecutor 10
    Thread 325:: AMEDeferredTaskExecutor 11
    Thread 326:: AMEDeferredTaskExecutor 12
    Thread 327:: AMEDeferredTaskExecutor 13
    Thread 328:: AMEDeferredTaskExecutor 14
    Thread 329:: AMEDeferredTaskExecutor 15
    Thread 330:: Background Bin Save Worker
    6   com.avid.AvidCore                 0x000000012027a1dd Threads::MCThreadBody::ThreadBody() + 33
    Thread 331:: Viewer Worker Thread
    Thread 332:: SbStatusChecker Thread
    Thread 333:
    0   libsystem_pthread.dylib           0x00007fff203e2420 start_wqthread + 0
    Thread 334:
    Thread 335:
    Thread 336:: QThread
    Thread 337:: QNetworkAccessManager thread
    Thread 338:: Thread (pooled)
    2   org.qt-project.QtCore             0x0000000107e4e1b0 QWaitConditionPrivate::wait_relative(QDeadlineTimer) + 256
    3   org.qt-project.QtCore             0x0000000107e4df1e QWaitConditionPrivate::wait(QDeadlineTimer) + 94
    4   org.qt-project.QtCore             0x0000000107e4de93 QWaitCondition::wait(QMutex*, QDeadlineTimer) + 83
    5   org.qt-project.QtCore             0x0000000107e4a8ad QThreadPoolThread::run() + 621
    6   org.qt-project.QtCore             0x0000000107e464b9 QThreadPrivate::start(void*) + 329
    Thread 339:: PlayLoopThread
    6   libameLibrary.dylib               0x0000000121b3148d PlayLoopThread::ThreadBody() + 181
    Thread 340:: schedulerThread
    6   libameLibrary.dylib               0x0000000121b9c119 ThreadWrapper(void*) + 47
    Thread 341:: PlayLoopThread
    Thread 342:: schedulerThread
    Thread 343:
    1   libdispatch.dylib                 0x00007fff2023cd15 _dispatch_sema4_timedwait + 72
    2   libdispatch.dylib                 0x00007fff2023d145 _dispatch_semaphore_wait_slow + 58
    3   libdispatch.dylib                 0x00007fff2024b656 _dispatch_worker_thread + 284
    Thread 344:
    Thread 345:: AsyncMSMRescan
    Thread 346:
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000000  rbx: 0x0000000109d94e00  rcx: 0x00007ffeec080788  rdx: 0x0000000000000000
      rdi: 0x0000000000000103  rsi: 0x0000000000000006  rbp: 0x00007ffeec0807b0  rsp: 0x00007ffeec080788
       r8: 0x0000000000007fff   r9: 0x0000000000008000  r10: 0x0000000000000000  r11: 0x0000000000000246
      r12: 0x0000000000000103  r13: 0x0000003000000008  r14: 0x0000000000000006  r15: 0x0000000000000016
      rip: 0x00007fff203b792e  rfl: 0x0000000000000246  cr2: 0x0000000105472670
    Logical CPU:     0
    Error Code:      0x02000148
    Trap Number:     133
    Thread 0 instruction stream:
      9a 0e 0b 00 39 c8 89 85-64 ff ff ff 8b 85 64 ff  ....9...d.....d.
      ff ff 89 c1 c1 c1 1c 81-e1 1e 1e 1e 1e 89 c2 81  ................
      e2 00 00 00 10 89 c6 c1-c6 04 81 e6 e1 e1 e1 e1  ................
      09 ce 89 f1 c1 e9 02 8d-0c 91 81 e1 66 66 66 66  ............ffff
      c1 e8 1a 83 e0 01 81 e6-66 66 66 26 8d 04 b0 09  ........fff&....
      c8 89 45 9c eb 13 b8 0a-c8 00 00 b8 b3 cc 00 00  ..E.............
     [c3]c3 c3 c3 c3 c3 c3 c3-c3 49 81 f7 6b 7d 4e 69  .........I..k}Ni    <==
      48 85 c8 49 85 c9 49 81-f7 6b 7d 4e 69 e8 34 00  H..I..I..k}Ni.4.
      00 00 48 31 ca 48 31 d1-48 81 fa e6 3d ff 72 48  ..H1.H1.H...=.rH
      31 ca 48 01 ca 48 29 d1-49 85 ca 48 f7 d9 49 83  1.H..H).I..H..I.
      f2 ff 4d 8d 52 01 49 81-f8 93 be 29 7f 49 f7 da  ..M.R.I....).I..
      48 29 ca bb a5 ab 48 8b-14 24 48 81 f9 69 e6 39  H)....H..$H..i.9
    Thread 0 last branch register state not available.
    Binary Images:
           0x103b7b000 -        0x106598fff +com.avid.mediacomposer (21.9.0.55465 - 21.9.0) <A2CDC49A-1453-3E1E-B8DA-B4A3D7588A23> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidMediaComposer
           0x107e25000 -        0x108393fff +org.qt-project.QtCore (5.15 - 5.15.3) <E8141AA0-A4E7-3AA0-8EB3-18BC389A193B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
           0x108667000 -        0x108b4ffff +org.qt-project.QtGui (5.15 - 5.15.3) <9C781A63-6079-32E8-A9B5-469AAF9879EB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
           0x108ec8000 -        0x108efcfff +org.qt-project.QtXml (5.15 - 5.15.3) <960E2264-3A82-3F01-93F4-B25BA45A3C64> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
           0x108f36000 -        0x108f6bfff +org.qt-project.QtSvg (5.15 - 5.15.3) <3C8F5CEB-BBAA-3D5D-98AB-5328BF61BECB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSvg.framework/Versions/5/QtSvg
           0x108fac000 -        0x1090bdfff +org.qt-project.QtNetwork (5.15 - 5.15.3) <1D4031B2-E454-3C5F-89AB-A43D24CA8519> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
           0x1091dc000 -        0x10960bfff +org.qt-project.QtWidgets (5.15 - 5.15.3) <6DEEBD2D-5A89-3A96-9D99-4BCC8D8BF4E2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
           0x10999e000 -        0x1099c8fff +org.qt-project.QtPrintSupport (5.15 - 5.15.3) <AB225F28-05DC-3E18-8C7B-8089A973DC2D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
           0x109a0d000 -        0x109a73fff +com.SafeNet.SuperPro (SuperPro version 6.6.0 - 6.6.0) /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SuperPro.framework/Versions/A/SuperPro
           0x109a8e000 -        0x109bd0fff +libicuucAvid.62.1.dylib (0) <D6901B2C-A48C-39D0-AE61-645F7ECC9E67> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuucAvid.62.1.dylib
           0x109c44000 -        0x109c4cfff +libicuioAvid.62.1.dylib (0) <C8C51C88-D0F4-3DD6-BCB6-04044BCFBB66> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicuioAvid.62.1.dylib
           0x109c58000 -        0x109c73fff +org.qt-project.QtWebSockets (5.15 - 5.15.3) <BBEC651A-CF4D-342D-AF57-C6C5977DA4C1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebSockets.framework/Versions/5/QtWebSockets
           0x109ca6000 -        0x109cb3fff +libjpegV4.dylib (1) <0B49A8C3-09BB-9697-D719-F60621D279E0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libjpegV4.dylib
           0x109cbd000 -        0x109d58fff  dyld (852.2) <0CC19410-FD43-39AE-A32A-50273F8303A4> /usr/lib/dyld
           0x109dd5000 -        0x109fabfff +libicui18nAvid.62.1.dylib (0) <B35B55DC-BCA9-37E2-AAFB-FFA6DDA94D40> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicui18nAvid.62.1.dylib
           0x10a0a7000 -        0x10ba3ffff +libicudataAvid.62.1.dylib (0) <13FECFE0-CF5B-3F16-90E4-ECE130A25540> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libicudataAvid.62.1.dylib
           0x10ba78000 -        0x10baadfff +org.qt-project.QtOpenGL (5.15 - 5.15.3) <22C9786D-3921-3D8B-BB2E-F69DB92AD8D6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtOpenGL.framework/Versions/5/QtOpenGL
           0x10baf9000 -        0x113fa4fff +org.qt-project.Qt.QtWebEngineCore (5.15 - 5.15.3) <2A32157F-3DC3-30B1-982F-79733556E4FB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngineCore.framework/Versions/5/QtWebEngineCore
           0x11d894000 -        0x11d8c6fff +org.qt-project.QtWebEngine (5.15 - 5.15.3) <BA6A9346-9427-33BB-BA83-E84893181150> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngine.framework/Versions/5/QtWebEngine
           0x11d941000 -        0x11d964fff +org.qt-project.QtWebEngineWidgets (5.15 - 5.15.3) <F3CAE531-CC48-3B60-9A80-3815FFE8EB20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebEngineWidgets.framework/Versions/5/QtWebEngineWidgets
           0x11d9b6000 -        0x11d9cffff +org.qt-project.QtWebChannel (5.15 - 5.15.3) <78459777-FDC0-38D7-AC2F-4B99827ABA31> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtWebChannel.framework/Versions/5/QtWebChannel
           0x11d9f1000 -        0x11d9f9fff +org.qt-project.QtMacExtras (5.15 - 5.15.3) <B9C72465-8363-3E5E-B9D7-6703C7CA07DF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
           0x11da09000 -        0x11da2afff +org.qt-project.QtSql (5.15 - 5.15.3) <D6A6841E-FAF6-38C1-AED6-222F3ADFE767> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtSql.framework/Versions/5/QtSql
           0x11da5a000 -        0x11dd3dfff +org.qt-project.QtXmlPatterns (5.15 - 5.15.3) <B38DC1EE-B7E9-3F89-8A99-5124A76A383D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/5/QtXmlPatterns
           0x11e077000 -        0x11e423fff +org.qt-project.QtDesigner (5.15 - 5.15.3) <EDDAAFB5-8F25-3048-A7DF-1830084A177F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtDesigner.framework/Versions/5/QtDesigner
           0x11e661000 -        0x11ec13fff +libELF_libc++_xcode.dylib (0) <56D76E1C-E201-34D9-AACB-2BE80977A0D4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libELF_libc++_xcode.dylib
           0x11ec56000 -        0x11eed9fff +com.avid.FTF (1.9.0 - 1.9.0) <12990F82-2CB0-3FAF-A088-794C59762BF7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/FTF.framework/Versions/A/FTF
           0x11efb6000 -        0x11f103fff +gk.dylib (0) <BC8B9FE8-0733-3ABB-88E5-EA5E36EAFE0B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/gk.dylib
           0x11f17a000 -        0x11f190fff +com.avid.AvidCoreThreads (20.1.0d242591 - 20.1.0) <0AF1678F-E834-3F7B-9181-A54DBB9885F1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreThreads.framework/Versions/A/AvidCoreThreads
           0x11f1c2000 -        0x11f1c7fff +com.avid.AvidCoreUtils (20.1.0d242591 - 20.1.0) <BBCBEC48-3F88-395A-9E79-459728E0FDB9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreUtils.framework/Versions/A/AvidCoreUtils
           0x11f1db000 -        0x11f1fdfff +com.avid.AvidCoreServices (20.1.0d242591 - 20.1.0) <1C8F32F1-C7D4-30C6-848B-DEA2A067357F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCoreServices.framework/Versions/A/AvidCoreServices
           0x11f251000 -        0x11f279fff +libHwControl.dylib (0) <512CEE75-8CBC-3A66-BEDE-1B69FB5166D8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libHwControl.dylib
           0x11f2cb000 -        0x11f3bdfff +libimf_orchestrator.dylib (0) <15635C69-1426-389B-A4A9-4D4E90F0C2C8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libimf_orchestrator.dylib
           0x11f417000 -        0x11f46dfff +libMediaComposerUI.dylib (0) <245A7F17-691D-3D27-85E7-8C0B37F9E47F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMediaComposerUI.dylib
           0x11f4e4000 -        0x11f551fff +com.avid.MCCloud (1.0 - 1) <1330D6EA-A906-3F33-931D-5DC57596150C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/MCCloud.framework/Versions/A/MCCloud
           0x11f5ea000 -        0x11f5f3fff +com.googlecode.google-breakpad (1.0) <68E4677B-AF8A-349C-9B9E-21C8F4F3CD96> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
           0x11f609000 -        0x11f669fff +libAMPIHost.dylib (0) <C8A3C756-BA8D-3F1B-87E4-C4C145C6173F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMPIHost.dylib
           0x11f734000 -        0x11f789fff +com.avid.DMF (1.0 - 1) <8B24988F-B532-3F47-90F2-55E1D275FED3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DMF.framework/Versions/A/DMF
           0x11f7e3000 -        0x11fad6fff +com.avid.UIShellQt (1.0 - 1.0) <B8CAEBEE-37ED-31DA-A443-B3AC08B791A4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/UIShellQt.framework/Versions/A/UIShellQt
           0x11fd13000 -        0x11fd18fff +com.avid.backgroundqueue (1.0 - 1) <0826701F-7F8B-35FE-A3C2-88516F3F6563> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/BackgroundQueue.framework/Versions/A/BackgroundQueue
           0x11fd33000 -        0x11fe1dfff +libAed.dylib (0) <87832FBC-4D59-31EB-AD33-1853EE964916> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAed.dylib
           0x11ffd0000 -        0x1200affff +libAeu.dylib (0) <7C8DF54A-C389-3C80-B521-CB38F19F5F38> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAeu.dylib
           0x12020d000 -        0x12021bfff +libAut.dylib (0) <1F131C11-D38D-3EBE-8F9F-B70FCBA03A69> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAut.dylib
           0x120236000 -        0x120620fff +com.avid.AvidCore (5.12.0 - 5.12.0) <1B424626-A1CA-3691-A44E-F09FE85B6498> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidCore.framework/Versions/A/AvidCore
           0x120987000 -        0x1209a2fff +com.avid.DigitalIO (5.12.0 - 5.12.0) <36A3AEC1-43EC-3C04-BD7F-F1ECA5161AB4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidDigitalIO.framework/Versions/A/AvidDigitalIO
           0x1209f2000 -        0x120a36fff +libACME.dylib (0) <174FEB81-CC60-3363-8AFC-EB4B4310C7FB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libACME.dylib
           0x120a99000 -        0x120aedfff +com.avid.AMI (1.0.0 - 1.0.0) <A7D1056F-5F48-3F3D-83F8-26D4882C2C1A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Ami.framework/Versions/A/Ami
           0x120bb6000 -        0x120c9afff +libAuiCore.dylib (0) <951A20FF-7BE7-325C-B3EA-97C9F4648EA8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAuiCore.dylib
           0x120df6000 -        0x120e48fff +libMVCore.dylib (0) <CE74FBCB-6C24-3799-9F95-1C2F3A7C37D9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMVCore.dylib
           0x120efd000 -        0x120f08fff +com.avid.RPE (1.0.0 - 1.0.0) <14E30788-9631-393A-A1C5-92A83D5F6338> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/RPE.framework/Versions/A/RPE
           0x120f2a000 -        0x120fdafff +libAMI_Mob.dylib (0) <E0BC7BD5-2A69-3E45-A7D1-7BE088C936A0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMI_Mob.dylib
           0x1210ef000 -        0x12113dfff +libLegacyVideoEffects.dylib (0) <6A9CD478-6F9F-300F-B653-DB7045C6D5E0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libLegacyVideoEffects.dylib
           0x12118d000 -        0x121219fff +libClassicEffects.dylib (0) <FF359582-33D0-33B8-950E-E595D45A928C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libClassicEffects.dylib
           0x1212ec000 -        0x121323fff +AVX2PluginHost.dylib (1.3) <3C435BC7-63D1-325D-92CD-74277E240A79> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AVX2PluginHost.dylib
           0x12135e000 -        0x12147afff +libUIshell.dylib (0) <D3305A6A-2305-3B02-98A4-FFC8EF7CF038> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libUIshell.dylib
           0x121670000 -        0x1229b9fff +libameLibrary.dylib (0) <B9227FDB-7530-3685-90F5-163E0E2B6A85> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameLibrary.dylib
           0x124128000 -        0x12445ffff +libameImportExport.dylib (0) <B2260A5B-9F8C-3418-976B-E7773E79B681> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameImportExport.dylib
           0x124640000 -        0x124646fff +libDynViewUIShell.dylib (0) <688A52C8-F0C5-3C9A-B198-C1C6257E96A9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDynViewUIShell.dylib
           0x12466a000 -        0x12467cfff +libameQuickTime.dylib (0) <895ED1EE-6DEE-3DBA-9BEF-C1663C3E3D4E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameQuickTime.dylib
           0x1246bb000 -        0x1246e1fff +libADMCommon.dylib (0) <4EB10154-4C05-3DA5-ADFA-9562135D5B3E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libADMCommon.dylib
           0x12471e000 -        0x124786fff +libADMDevices.dylib (0) <89C306A1-59A5-32AC-9898-DDD06EA935D3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libADMDevices.dylib
           0x124804000 -        0x12480efff +AVXLibrary.dylib (0) <41AAD027-3F6C-34C1-8283-3BA365A84991> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AVXLibrary.dylib
           0x12483c000 -        0x12493cfff +libQM.dylib (0) <A95DB9FF-97AE-32EF-AFD7-E4D44AB6F8DB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libQM.dylib
           0x1249c9000 -        0x124a9cfff +com.avid.LavaFlow (5.12.0d61826 - 5.12.0) <46285AEF-BDF9-33DD-BEF7-830193E3FF87> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/lavaFlow.framework/Versions/A/lavaFlow
           0x124b41000 -        0x124b45fff +libMultiTouchSurfaceControl.dylib (0) <D0FD8CE7-4730-3307-9EE1-6FD511BE1BE1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMultiTouchSurfaceControl.dylib
           0x124b58000 -        0x124b78fff +libConfigClient.dylib (0) <D0D3A56B-4BC5-38E2-914C-276B7457BE87> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libConfigClient.dylib
           0x124bb7000 -        0x125c61fff +il.dylib (0) <E7CA2558-3ACA-35C0-89D2-C81B2D7F3F62> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/il.dylib
           0x1263e0000 -        0x1263ecfff +mt.dylib (0) <D50BE64F-6157-3BEA-972F-4680E79A88DB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/mt.dylib
           0x1263fa000 -        0x126830fff +ml.dylib (0) <A9624B6A-CAA6-32BE-B618-473E41213D00> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/ml.dylib
           0x126937000 -        0x126a9bfff +libmesa.dylib (0) <8ADCDDF9-B1D5-365F-917E-A38035365127> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libmesa.dylib
           0x126bbe000 -        0x126c6ffff +com.avid.AvidSwrtFx (5.12.0 - 5.12.0) <90E77960-25A0-3BC7-8E20-02217E256167> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidSwrtFx.framework/Versions/A/AvidSwrtFx
           0x126ce4000 -        0x126d87fff +com.avid.Mac2Qt (1.0 - 1.0) <EFAD6671-6F02-34BE-ACE4-1CC81F8A2271> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Mac2Qt.framework/Versions/A/Mac2Qt
           0x126e52000 -        0x126e8afff +libameWaveformEngine.dylib (0) <CE3E20DB-DC01-3E3D-97B4-A9F2F83B266F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libameWaveformEngine.dylib
           0x126ef1000 -        0x126ef5fff +com.avid.TaskScheduler (5.0.0.0 - 5.0.0.0) <682AE0BC-AA77-37F8-B225-28A1B0D66C7D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TaskScheduler.framework/Versions/A/TaskScheduler
           0x126f04000 -        0x12714dfff +libDMSClientLib.dylib (0) <832960CB-78D1-3483-B1DA-A4ECAB77886B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDMSClientLib.dylib
           0x12724c000 -        0x12724efff +com.avid.AvidBSMClient (1.0.1 - 1) <0299FE64-1C7F-3D55-ABEC-C0567C7F3042> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidBSMClient.framework/Versions/A/AvidBSMClient
           0x12725a000 -        0x12727cfff +libHiip_Library.dylib (0) <B4E02EC1-36E6-3554-B85E-2C7F60F5CCA6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libHiip_Library.dylib
           0x1272ac000 -        0x127506fff +com.avid.CaptionManager (1.0 - 1) <466688EF-0556-3DF4-8DC4-55CB4941D7FF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/CaptionManager.framework/Versions/A/CaptionManager
           0x127612000 -        0x1294aafff +libDolbyVisionSupport.dylib (0) <2F3A5BCA-FC65-39F4-85B5-2F028C11F6C3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libDolbyVisionSupport.dylib
           0x12951c000 -        0x129859fff +org.qt-project.QtQuick (5.15 - 5.15.3) <2F585777-E664-3997-BFB1-37BD4BFBFAD9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQuick.framework/Versions/5/QtQuick
           0x129c62000 -        0x129cbafff +org.qt-project.QtQmlModels (5.15 - 5.15.3) <5902BD07-F290-3B8F-8FFC-B57EE37D0589> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQmlModels.framework/Versions/5/QtQmlModels
           0x129d2d000 -        0x12a092fff +org.qt-project.QtQml (5.15 - 5.15.3) <D6113FE4-6954-31CB-A250-99D298522C21> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQml.framework/Versions/5/QtQml
           0x12a387000 -        0x12a3eafff +org.qt-project.QtPositioning (5.15 - 5.15.3) <3AB0043F-7319-3263-8C96-C220A0215D84> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtPositioning.framework/Versions/5/QtPositioning
           0x12a47a000 -        0x12a486fff +org.qt-project.QtQuickWidgets (5.15 - 5.15.3) <2A3D513D-9B8A-3F92-8FCC-5CE9773CA5B0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtQuickWidgets.framework/Versions/5/QtQuickWidgets
           0x12a49c000 -        0x12a573fff +libIMF_SDK_1.1.8.dylib (0) <8EBF10F5-A87E-39A5-852F-8C28BC1E966D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libIMF_SDK_1.1.8.dylib
           0x12a5de000 -        0x12a622fff +liblog4cplusU-1.1.7.dylib (0) <C84A7BE0-5EF8-3032-8BF3-DAD5C2B92D04> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/liblog4cplusU-1.1.7.dylib
           0x12a65f000 -        0x12a978fff +libcom-api.dylib (0) <E69861A1-2DF7-34AC-B8E7-FFE687BA616A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libcom-api.dylib
           0x12ac9a000 -        0x12acf4fff +libAssetRegistry.dylib (0) <02C29082-BC66-33B3-98BB-BCD9612D6134> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAssetRegistry.dylib
           0x12ad72000 -        0x12ad75fff +libboost_chrono-clang-darwin73-mt-x64-1_70.dylib (0) <0D01FE78-7195-3A2F-84B1-7E916E62B0BC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_chrono-clang-darwin73-mt-x64-1_70.dylib
           0x12ad80000 -        0x12ad84fff +libboost_date_time-clang-darwin73-mt-x64-1_70.dylib (0) <B52F3313-E0D0-3638-8181-9CE3E546308F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_date_time-clang-darwin73-mt-x64-1_70.dylib
           0x12ad92000 -        0x12ada1fff +libboost_filesystem-clang-darwin73-mt-x64-1_70.dylib (0) <F0A708CC-EF3E-32FB-A69A-E18850AF82D6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_filesystem-clang-darwin73-mt-x64-1_70.dylib
           0x12adb0000 -        0x12adb0fff +libboost_system-clang-darwin73-mt-x64-1_70.dylib (0) <9DFEE551-F414-3DFD-9911-4901AB966ACA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_system-clang-darwin73-mt-x64-1_70.dylib
           0x12adb6000 -        0x12adc3fff +libboost_thread-clang-darwin73-mt-x64-1_70.dylib (0) <C1928A5D-572B-3346-BEB1-43E691552757> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_thread-clang-darwin73-mt-x64-1_70.dylib
           0x12add7000 -        0x12b0f1fff +libAvidMXF_SDK_4.7.8.dylib (0) <D110A71E-D44C-3C06-900F-1071C44816E7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidMXF_SDK_4.7.8.dylib
           0x12b339000 -        0x12b563fff +libxerces-c-clang-703-3.1.dylib (0) <6FF2C6DA-8F6C-3A3A-93E0-36994B4D6F55> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxerces-c-clang-703-3.1.dylib
           0x12b7d7000 -        0x12b99afff +libxalan-c-clang-703-111.0.dylib (0) <91AD40D2-8519-35B1-A965-0117071E27C6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxalan-c-clang-703-111.0.dylib
           0x12bb11000 -        0x12be0afff +libxqilla-clang-703-3.dylib (0) <A82D71E5-AD96-3083-9446-48F1283B4728> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxqilla-clang-703-3.dylib
           0x12bf6a000 -        0x12bf6ffff +libxalanMsg-clang-703-111.0.dylib (0) <FBBB70A8-0091-3DAF-8EBB-2D585335E0FA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libxalanMsg-clang-703-111.0.dylib
           0x12bf79000 -        0x12bf8afff +com.avid.AvidStorageAPI (20.4.0d113580 - 20.4.0) <FA05B665-C906-35AE-90F2-A1D5B90C7F2B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidStorageAPI.framework/Versions/A/AvidStorageAPI
           0x12bfa4000 -        0x12bfd6fff +libtbb.dylib (0) <6B3D5E03-E6EC-3A5B-9834-D7D749343DB3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libtbb.dylib
           0x12c00c000 -        0x12c033fff +libtbbmalloc.dylib (0) <C83A878A-540B-3872-9C1F-9128493A53B2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libtbbmalloc.dylib
           0x12c067000 -        0x12c076fff +breakpadUtilities.dylib (0) <EB9CF81E-EBB5-3D88-A024-8C35C48B1E95> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
           0x12c088000 -        0x12c09afff +HWcommon (1.0 - 1.0) <3D8FF19D-29B7-3108-9692-F390034AAF46> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/HWcommon.framework/Versions/A/HWcommon
           0x12c0b4000 -        0x12c0f9fff +com.avid.AvidMPEG2Parser (5.12.0 - 5.12.0) <27CE4177-5A15-392B-A6CF-A4F3D9338FBD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidMPEG2Parser.framework/Versions/A/AvidMPEG2Parser
           0x12c145000 -        0x12ca87fff +libmi-client-dynamic.dylib (0) <7A47139F-B7BB-34A7-AA06-5F2503C5BB5B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libmi-client-dynamic.dylib
           0x12d854000 -        0x12d854fff +libMvInt.dylib (0) <A1671832-3305-3DF7-A418-9542DA515239> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libMvInt.dylib
           0x12d85c000 -        0x12db23fff +com.avid.AmiMDK (1.0.0 - 1.0.0) <4F79D6D9-02A6-3D73-8F41-8A1893F13151> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AmiMDK.framework/Versions/A/AmiMDK
           0x12dea6000 -        0x12dea6fff +libEvents.dylib (0) <1B89AB53-2170-3F04-AC34-A7B68E35BA5B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libEvents.dylib
           0x1302e0000 -        0x1302e0fff +libAvidVidSatInterface.dylib (0) <1DAF3249-44EA-31B9-A169-0493488BC412> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidVidSatInterface.dylib
           0x1302e9000 -        0x130323fff +libAvidVideoSlave.dylib (0) <9D20C431-A1DB-3274-92DD-1F4159378CE3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAvidVideoSlave.dylib
           0x13035b000 -        0x1303acfff +com.digidesign.framework.SystemLink (20.0.10.203 - 20.0.10d203) <59846870-7DEF-38EF-B879-8D5890300735> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SatelliteLink.framework/Versions/A/SatelliteLink
           0x130423000 -        0x130436fff +com.digidesign.framework.TCPE (20.0.10.203 - 20.0.10d203) <85CD5944-31AC-3466-B70B-9BF8DD2536B5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TCPE.framework/Versions/A/TCPE
           0x1305ca000 -        0x1305cdfff  com.apple.textencoding.unicode (7.0 - 7.0) <649ADC36-F7A2-3D2D-9FB6-AD05523FDDDA> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
           0x1305da000 -        0x130738fff +libqcocoa.dylib (0) <218F8207-F1A1-3162-9A26-FA7ABCB9E8A4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/platforms/libqcocoa.dylib
           0x1314cc000 -        0x1314dbfff  libobjc-trampolines.dylib (824) <C1B6BD90-D6AA-388B-B692-D66D512630AA> /usr/lib/libobjc-trampolines.dylib
           0x131622000 -        0x131775fff  com.apple.AMDRadeonX6000GLDriver (4.6.20 - 4.0.6) <AA0EE593-B96A-313F-ABE1-27DA165D8213> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
           0x13237a000 -        0x13239efff +libqmacstyle.dylib (0) <FABD1395-CD38-377B-984F-3512ECD92303> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/styles/libqmacstyle.dylib
           0x1323c0000 -        0x1323c7fff +libqgif.dylib (0) <FD081424-7350-3E5A-93D6-7F6C6F2F23CB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqgif.dylib
           0x1323d2000 -        0x1323d9fff +libqicns.dylib (0) <18527A73-F9A5-303C-BED3-B614F4C4264D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqicns.dylib
           0x1323e5000 -        0x1323eafff +libqico.dylib (0) <EDF7BEAA-D591-3815-8399-C0BE5FA22023> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqico.dylib
           0x1323f5000 -        0x132457fff +libqjpeg.dylib (0) <3A889470-8A53-3326-8B38-A38E1C374908> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqjpeg.dylib
           0x132472000 -        0x132478fff +libqmacheif.dylib (0) <B0E2E81D-D3EF-3D59-A867-3B03DC264792> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqmacheif.dylib
           0x132484000 -        0x132489fff +libqmacjp2.dylib (0) <B2D8269C-3BEC-3059-914A-D20694119C59> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqmacjp2.dylib
           0x132495000 -        0x13249afff +libqpdf.dylib (0) <3294F771-605A-31FB-BFB3-8893DE6C3F47> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqpdf.dylib
           0x1324a5000 -        0x132accfff +org.qt-project.QtPdf (5.15 - 5.15.3) <95449D5A-F4BA-3A67-B918-7952FAB03061> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/QtPdf.framework/Versions/5/QtPdf
           0x132db8000 -        0x132dbdfff +libqsvg.dylib (0) <F7827D92-13FD-305A-8D03-83710E50B464> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqsvg.dylib
           0x132dc8000 -        0x132dccfff +libqtga.dylib (0) <51B489AF-8DC2-361A-A088-A3929216E5E2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqtga.dylib
           0x132dd7000 -        0x132e3dfff +libqtiff.dylib (0) <7F92CD6C-FB32-3BCF-8887-B2D302F59F2C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqtiff.dylib
           0x132e67000 -        0x132e6bfff +libqwbmp.dylib (0) <982772A1-D08F-3EAF-AF6F-7FDB602E56D5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqwbmp.dylib
           0x132e75000 -        0x132f0ffff +libqwebp.dylib (0) <B35D7622-EEA2-323F-8877-2BE1232BBBC7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/imageformats/libqwebp.dylib
           0x133dd6000 -        0x133dd6fff +libboost_chrono-clang-darwin42-mt-1_61.dylib (0) <FBB5DC70-ACF9-39EF-8FAE-82CCD94C5A64> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_chrono-clang-darwin42-mt-1_61.dylib
           0x133dde000 -        0x133ddffff +libboost_system-clang-darwin42-mt-1_61.dylib (0) <285DA50F-E6EB-313A-B52C-9AD3F364C73F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_system-clang-darwin42-mt-1_61.dylib
           0x135178000 -        0x13517bfff +com.avid.ByteBlock (19.1.0.24556 - 19.1.0) <5876DC34-19C8-36C9-9972-A3A4BDF885EC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/ByteBlock.avx/Contents/MacOS/ByteBlock
           0x273921000 -        0x2739a0fff  com.apple.diopyromaniacohci (5.12.0 - 5.12.0) <00B0C586-84D0-3D03-A265-E151C0425C01> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/DIOPyromaniacOHCI_v001_MC.bundle/Contents/MacOS/DIOPyromaniacOHCI_v001_MC
           0x273c07000 -        0x273c3dfff +com.avid.macflamethrowerohci (5.12.0 - 5.12.0) <36B7B4E8-9D71-315B-B726-0F62F3E1B329> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/MacFlamethrowerOHCI_MC.bundle/Contents/MacOS/MacFlamethrowerOHCI_MC
           0x273d36000 -        0x273d69fff  com.apple.AVCVideoServices (1.0 - 42) <AF3D72EF-4DA9-E884-50FF-26366EEB1257> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
           0x273da1000 -        0x273e05fff +avx2 (1.3.0 - 1.3.0) <9A32C2B9-4225-3259-89FD-DB0FCEB72A16> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/avx2.bundle/Contents/MacOS/avx2
           0x273e7a000 -        0x273f1bfff +com.avid.MSP_MediaProcessor (1.0.57.10056 - ???) <63D22228-604A-3EF2-AD01-3511B3D4A707> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/MSP_MediaProcessor
           0x273f6e000 -        0x2745affff +libMediaProcessor.4.6.0.dylib (0) <FD3488AA-76AB-3DF2-BD12-68373521C9D1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libMediaProcessor.4.6.0.dylib
           0x274f4f000 -        0x274f9dfff +libcurl.4.dylib (0) <AAB1C444-C820-3982-AA46-D368D07FFDAA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libcurl.4.dylib
           0x274faf000 -        0x27556ffff +libGenericHelper-14.2.53.0.dylib (0) <BCC6E76F-4153-3C78-88D7-D0A5B042D2D2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libGenericHelper-14.2.53.0.dylib
           0x2757c7000 -        0x276871fff +il.dylib (0) <E7CA2558-3ACA-35C0-89D2-C81B2D7F3F62> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/il.dylib
           0x276ff0000 -        0x277032fff +libIMEHost.dylib (0) <86B84BEE-F308-3A42-B639-56931AD148AB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libIMEHost.dylib
           0x2770a4000 -        0x2770dcfff +libIMEX.dylib (0) <A113D260-0A3D-351B-9378-CD6ED0DD723E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libIMEX.dylib
           0x27713b000 -        0x27720efff +libIMF_SDK_1.1.7.dylib (0) <03845116-A898-367A-BB75-FF52E71746F2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libIMF_SDK_1.1.7.dylib
           0x27727b000 -        0x2772ecfff +libturbojpeg-1.5.2.dylib (0) <D43BF906-FF1E-3059-831A-9D3918D925C5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libturbojpeg-1.5.2.dylib
           0x277302000 -        0x27732afff +libpicco_1.0.0.54.dylib (0) <4DF17F08-3D6E-39A2-812B-195130369417> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libpicco_1.0.0.54.dylib
           0x27735d000 -        0x2773fefff +libAvOmfToolkit.dylib (0) <D8F6E0ED-BB22-32C1-AD73-D95AAF717FFA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MSP_MediaProcessor.avx/Contents/MacOS/libAvOmfToolkit.dylib
           0x277421000 -        0x2774c8fff +com.avid.acfpluginhost (1.3.0 - 1.3.0) <BED824E7-B420-3780-BA17-4C3CC947B8AD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/ACFPluginHost.framework/Versions/A/ACFPluginHost
           0x27756b000 -        0x27759ffff +com.avid.DefaultCaptionDecoder (1.0.5 - 1.0.5) <02D59B86-0354-3F3B-B687-B209600EE876> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DefaultCaptionDecoder.acf/Contents/MacOS/DefaultCaptionDecoder
           0x2775dc000 -        0x2775eafff +com.avid.MediaDialogs (1.0 - 1.0) <CCDAB45D-BDB7-3D27-A9F8-FCF216FAE760> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/MediaDialogs.acf/Contents/MacOS/MediaDialogs
           0x277619000 -        0x2777e6fff +com.avid.pxf.plugin (2.4.2.13225 - 2.4.2) <EA99E234-DC68-31FA-8A1E-5B809E8C37CF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/PXFPlugin.avx/Contents/MacOS/PXFPlugin
           0x2778a7000 -        0x277bc1fff +libAvidMXF_SDK_4.7.3.dylib (0) <792E978C-3994-3E01-B585-62FD461587A4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/PXFPlugin.avx/Contents/MacOS/libAvidMXF_SDK_4.7.3.dylib
           0x277e02000 -        0x2780d5fff +libxerces-c-clang-900-3.2.dylib (0) <4C1DDC67-058E-385B-A7F1-C52A9A99AE07> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/PXFPlugin.avx/Contents/MacOS/libxerces-c-clang-900-3.2.dylib
           0x2782c7000 -        0x2787bafff +libxqilla-clang-900-3.dylib (0) <93B99360-5C5C-3243-B27B-8BF767E410DD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/PXFPlugin.avx/Contents/MacOS/libxqilla-clang-900-3.dylib
           0x2789b1000 -        0x2789befff +libboost_filesystem-clang-darwin42-mt-1_61.dylib (0) <3F0D4805-7CEC-372A-9613-EC7742AE3D32> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_filesystem-clang-darwin42-mt-1_61.dylib
           0x2789cd000 -        0x2789dafff +libboost_thread-clang-darwin42-mt-1_61.dylib (0) <56B973F6-0B25-32B0-B01A-9C242D9A053B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libboost_thread-clang-darwin42-mt-1_61.dylib
           0x2789f2000 -        0x27a0d7fff +libnexidia.9.0.dylib (9) <28E5AC04-E141-3318-9755-CEAE0359EC73> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libnexidia.9.0.dylib
           0x27a731000 -        0x27ae65fff +libnxmediaaccessor.9.0.dylib (9) <A61B18C7-CFFB-33CA-B631-34BF1915C63C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libnxmediaaccessor.9.0.dylib
           0x27b001000 -        0x27b03ffff +com.avid.RemoteAssetsPlugin (1.0 - 1.0) <26356FD7-28B2-38C0-9CB5-8F4B85204AF7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/RemoteAssetsPlugin.avx/Contents/MacOS/RemoteAssetsPlugin
           0x27b0d4000 -        0x27b558fff +com.avid.mpi.imeamahost (1.0 - 1) <0CF4C2E6-CACA-36F0-8EA6-C60CAE0BC2DC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Utils/AAFProcessor.avx/Contents/MacOS/AAFProcessor
           0x27b74f000 -        0x27b75bfff +com.avid.RestClient (1.0 - 1.0) <9BA4A2E0-3BA5-3F0A-B720-06DA9FED7B38> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/RestClient.acf/Contents/MacOS/RestClient
           0x27b77a000 -        0x27b782fff +com.avid.VDM.bridge (4.6.4 - 4.6.4) <4C64C33F-115B-3E5D-81E3-88C1F8508495> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AvidVDM.acf/Contents/MacOS/AvidVDM
           0x27b792000 -        0x27b8effff +ilgpu.dylib (0) <7DD84754-FF14-3014-86F1-F3E66363594C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/ilgpu.dylib
           0x27b99e000 -        0x27ba4ffff +com.avid.amfPlayer ( version 1.0 - 1.0) <8D7A2AC1-1E78-30DD-AFB7-380DCB60A35F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/amfPlayer.avx/Contents/MacOS/amfPlayer
           0x27bbee000 -        0x27d3d4fff +com.absoft.NeatVideo5-MC (Neat Video v5.2.6 Pro plug-in for Media Composer - 5.2.6) <85F9B013-08CB-32BC-91D1-4C06AC5F556C> /Library/Application Support/Avid/*/NeatVideo5
           0x27d77f000 -        0x27d7a6fff +com.Avid.OpenIO-NDI (1.0.0 - 1.0.0) <E905F28E-D8BC-341C-AA7F-AC8860A891D6> /Library/Application Support/Avid/*/OpenIO_NDI
           0x27d7ef000 -        0x27dbbafff +libndi.4.dylib (0) <B6AB38DE-044F-38EC-AEBD-C4B3A0DA0C4F> /Library/Application Support/Avid/*/libndi.4.dylib
           0x27dd07000 -        0x27dd0efff +libqgenericbearer.dylib (0) <DEC411B3-8E45-3984-8286-C87D8FD33A03> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/bearer/libqgenericbearer.dylib
           0x27dd20000 -        0x27dd24fff +com.avid.HWcommon_ACF (19.4.0d236307 - 19.4.0) <16EEE557-C939-3C53-AB0B-695F19E813D7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/HWcommon_ACF.acf/Contents/MacOS/HWcommon_ACF
           0x27dd37000 -        0x27ddb6fff +com.Avid.HWSDK (1.0 - 1) <895DB82E-B376-3A1A-87E2-713B71C0A2E7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/HWSDK.acf/Contents/MacOS/HWSDK
           0x27de9d000 -        0x27dea4fff +HWcommon_Basics (0) <40E1DE51-04A5-35BC-8219-9AB36D064538> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/HWcommon_Basics.framework/Versions/A/HWcommon_Basics
           0x27deb3000 -        0x27dec8fff +com.Avid.OpenIO_Manifold (1.0 - 1) <FF91EBA3-D371-3DFF-9251-9B7C41AC0F00> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/OpenIO_Manifold.acf/Contents/MacOS/OpenIO_Manifold
           0x27df00000 -        0x27df0cfff +com.Avid.OpenIO_VirtIO (1.0 - 1) <4976F424-15E9-3A6C-824E-5562A1866A25> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/OpenIO_VirtIO.acf/Contents/MacOS/OpenIO_VirtIO
           0x27df32000 -        0x27df4cfff +com.avid.ACFString ( version 1.1.0 - 1.0) <4D18598C-CA0F-3389-B397-E5A24AEA0547> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/ACFString.avx/Contents/MacOS/ACFString
           0x290074000 -        0x2900e8fff +acpl_main (???) <85C760FB-8C6C-393F-B354-58417031088B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_main.acf/Contents/MacOS/acpl_main
           0x29013d000 -        0x2901f6fff +acpl_cpu (???) <8A1CEDD9-4B37-3EFB-8FEC-F6C75978C54B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_cpu.acf/Contents/MacOS/acpl_cpu
           0x29027c000 -        0x2902e7fff +acpl_gpu (???) <78A429A5-B5ED-3957-A983-0B0A656798A0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_gpu.acf/Contents/MacOS/acpl_gpu
           0x290347000 -        0x2904befff +libqsqlite.dylib (0) <D2033E59-54AB-37BA-BCA0-4CFCFFFBC888> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/PlugIns/sqldrivers/libqsqlite.dylib
           0x29050b000 -        0x290590fff +com.digidesign.AMPIPluginDSM (20.0.10.203 - 20.0.10d203) <30AE232A-714D-3DE2-B96B-F9E7D2FEF988> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/Private_Plug-Ins/AMPIPluginDSM.avx/Contents/MacOS/AMPIPluginDSM
           0x290625000 -        0x29063ffff +com.digidesign.framework.AudioFoundation (20.0.10.203 - 20.0.10d203) <20DEC885-FC2E-3DD1-BB47-F2D7E12CBD9A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AFnd.framework/Versions/A/AFnd
           0x290664000 -        0x290686fff +com.digidesign.framework.PlatformSupport (20.0.10.203 - 20.0.10d203) <C001A1CB-CCBB-3487-B57A-3C8C0CA4A8FD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport
           0x2908c2000 -        0x290e98fff +com.digidesign.framework.FileFormat (20.0.10.203 - 20.0.10d203) <F94076CC-3E97-3E45-AD8B-AFCDDBBD46D4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt
           0x2915d3000 -        0x29183cfff +com.digidesign.framework.CoreFoundation (20.0.10.203 - 20.0.10d203) <18E69C31-7C49-3838-B91B-B91EF7AF16D7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/CFnd.framework/Versions/A/CFnd
           0x291941000 -        0x291afafff +com.digidesign.framework.MoreFoundation (20.0.10.203 - 20.0.10d203) <FD428BD1-05F2-3DED-B8EB-2662ACC73642> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/MFnd.framework/Versions/A/MFnd
           0x291be6000 -        0x291e49fff +com.digidesign.framework.SMgr (20.0.10.203 - 20.0.10d203) <5403F226-61C5-3D53-BC05-5EE188E1F13B> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SMgr.framework/Versions/A/SMgr
           0x292490000 -        0x292625fff +com.avid.framework.AAE (20.0.10.203 - 20.0.10d203) <3B007CEF-0E76-3BDC-934C-67280E125655> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AAE.framework/Versions/A/AAE
           0x292c27000 -        0x292dbefff +com.avid.framework.ClipFX (20.0.10.203 - 20.0.10d203) <6764A05E-FA5A-35EB-9AD2-43E9B08C06B8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/ClipFX.framework/Versions/A/ClipFX
           0x292e36000 -        0x292eb3fff +taglib.dylib (0) <D71C6855-93C6-3ED3-9294-9B01FE7BE416> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/taglib.dylib
           0x292ef6000 -        0x2932a1fff +com.digidesign.framework.DSI (20.0.10.203 - 20.0.10d203) <46009ECD-49BC-3212-A186-261D347542EB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DSI.framework/Versions/A/DSI
           0x2933fe000 -        0x2936e0fff +com.digidesign.framework.DFW (20.0.10.203 - 20.0.10d203) <C53C0D6F-7A38-318C-B27A-8DBD82F41AEC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DFW.framework/Versions/A/DFW
           0x2938cc000 -        0x293927fff +com.digidesign.framework.DHS (20.0.10.203 - 20.0.10d203) <67E82154-0052-3FB9-996C-1953C83D7337> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DHS.framework/Versions/A/DHS
           0x293983000 -        0x2939aafff +com.digidesign.framework.Mdis (20.0.10.203 - 20.0.10d203) <E9F9DDDC-C7CA-31D9-899B-89312BDA1188> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/mdis.framework/Versions/A/Mdis
           0x2939dd000 -        0x293b88fff +com.avid.framework.AAXHost (20.0.10.203 - 20.0.10d203) <28108BF2-143D-394C-A97E-E72791804CD0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AAXHost.framework/Versions/A/AAXHost
           0x293c0e000 -        0x293c3cfff +com.digidesign.framework.Mdid (20.0.10.203 - 20.0.10d203) <7C83BFA7-420F-3F1A-A870-979608B23EAE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/mdid.framework/Versions/A/Mdid
           0x293c5b000 -        0x293c82fff +com.digidesign.framework.Mdie (20.0.10.203 - 20.0.10d203) <76B1E697-3AE3-3C65-BF4C-9555847F2328> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/mdie.framework/Versions/A/Mdie
           0x293cb7000 -        0x293cbafff +com.digidesign.framework.TISys (20.0.10.203 - 20.0.10d203) <C5DF5AEB-449B-3258-9551-D4AB943E1EBF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TISys.framework/Versions/A/TISys
           0x293cc4000 -        0x293cedfff +com.digidesign.framework.DSK (20.0.10.203 - 20.0.10d203) <81EA2AEC-1B7C-3337-92EA-39564EB70994> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DSK.framework/Versions/A/DSK
           0x293d0f000 -        0x293d28fff +com.digidesign.framework.TIDSPMgr (20.0.10.203 - 20.0.10d203) <54CE3F47-DE1B-3F67-863D-82241F4423B9> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TIDspMgr.framework/Versions/A/TIDspMgr
           0x293d3b000 -        0x293d47fff +com.digidesign.framework.AAXShared (20.0.10.203 - 20.0.10d203) <C83803D2-2D6B-3B4A-A0F4-CEF045BF09AD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AAXShared.framework/Versions/A/AAXShared
           0x293d5b000 -        0x293d63fff +com.digidesign.framework.DUI (20.0.10.203 - 20.0.10d203) <E9A2F56F-1975-3578-A650-88927074C60D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DUI.framework/Versions/A/DUI
           0x293d7a000 -        0x294044fff +com.avid.framework.TIShellMgr (20.0.10x203 - 20.0.10d203) <514D373F-5439-34FA-8D40-4565BD5C4CA7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/TIShellMgr.framework/Versions/A/TIShellMgr
           0x294591000 -        0x2945aafff +com.digidesign.framework.CDS (20.0.10.203 - 20.0.10d203) <062717CB-EBC5-34A5-824F-DA4EE7F611B2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/CDS.framework/Versions/A/CDS
           0x2945bd000 -        0x295f55fff +libicudata.62.1.dylib (0) <C88B8077-24F5-379D-B8D4-72E4A38F2472> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libicudata.62.1.dylib
           0x295f8e000 -        0x29615bfff +libicui18n.62.1.dylib (0) <34647193-387C-374F-91A5-29B787FB2134> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libicui18n.62.1.dylib
           0x29625e000 -        0x29639cfff +libicuuc.62.1.dylib (0) <DFAB255E-63B6-311E-B86E-C86033D25CD6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/libicuuc.62.1.dylib
           0x296414000 -        0x296427fff +com.digidesign.framework.digitrace (20.0.10.203 - 20.0.10d203) <A0D53839-D9E4-3064-9812-2B3B93680434> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/DigiTrace.framework/Versions/A/Digitrace
           0x29643a000 -        0x296479fff +InnerProcessDictionary.dylib (0) <8A1B3FE5-EC39-3227-B954-B3EEDC85C417> /Library/Application Support/Waves/*/InnerProcessDictionary.dylib
           0x2964d9000 -        0x2965f8fff +com.WavesAudio.WavesLicenseEngine.2.0.0 (2.0.0 - 2.0.0.2) <A8C67476-2D40-3527-8FFB-C5140655CAB8> /Library/Application Support/Waves/*/WavesLicenseEngine.bundle/Contents/MacOS/WavesLicenseEngine
           0x29666f000 -        0x296676fff  com.apple.audio.AppleGFXHDAHALPlugIn (100.1.433 - 100.1.433) <2065ABB8-5CB8-32F8-9A0B-DB8E3A39E897> /System/Library/Extensions/AppleGFXHDA.kext/Contents/PlugIns/AppleGFXHDAHALPlugIn.bundle/Contents/MacOS/AppleGFXHDAHALPlugIn
           0x296683000 -        0x296694fff +libAMAUtilLib20.dylib (0) <786D039D-C60F-3F57-8C28-3D6DAD7DDFA3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/libAMAUtilLib20.dylib
           0x2966a7000 -        0x2966b6fff +com.avid.AMALogger (3.5.4.10016 - ???) <1E15EF52-B6EE-3A56-9909-67AD2444041E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMALogger.avx/Contents/MacOS/AMALogger
           0x2966ca000 -        0x296783fff +com.avid.MSP_Q7 (3.6.18.693 - ???) <5042CFE9-9001-32F5-815A-615A762C3314> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/MSP_Q7.avx/Contents/MacOS/MSP_Q7
           0x2967e0000 -        0x296a75fff +com.avid.LEPCore (18.5.0.565 - ???) <9B3FC741-2104-375D-96B3-293DED24629E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/LEPCore.acf/Contents/MacOS/LEPCore
           0x296d10000 -        0x296d1dfff +com.avid.FeederFactory (18.5.0.565 - ???) <CE54A77F-47F7-3836-9368-E131C7F53364> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/FeederFactory.acf/Contents/MacOS/FeederFactory
           0x296d35000 -        0x296e16fff +com.avid.MSP_AVCHD (1.6.1.342 - ???) <999D4957-46F5-3C4C-B6AE-4832518C78B6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MSP_AVCHD.avx/Contents/MacOS/MSP_AVCHD
           0x296e6c000 -        0x296ea0fff +com.avid.TSParser (2.7.9.10007 - ???) <DE0A60D8-6A2C-347B-A521-020F05C46B20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/TSParser.acf/Contents/MacOS/TSParser
           0x296ec8000 -        0x296ef6fff +com.avid.AMASampleProviderSupport (3.5.4.10016 - ???) <CA0F0954-870A-3AE1-A319-B00649A2439F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMASampleProviderSupport.avx/Contents/MacOS/AMASampleProviderSupport
           0x296f19000 -        0x296fc1fff +com.avid.MVP_AVCHD (1.6.1.342 - ???) <27EDAAB1-0C2E-330E-B260-9E88CAADE062> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_AVCHD.avx/Contents/MacOS/MVP_AVCHD
           0x297002000 -        0x2970cafff +libIMF_SDK_1.0.7.dylib (0) <B59AB745-C9A7-349F-84DF-A6A7F7775C64> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/libIMF_SDK_1.0.7.dylib
           0x29712a000 -        0x29712efff +libboost_date_time-clang-darwin42-mt-1_61.dylib (0) <FD972B1A-7796-396F-9A76-3B4691A330C4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/libboost_date_time-clang-darwin42-mt-1_61.dylib
           0x29713b000 -        0x297158fff +com.avid.MVP_MediaCollector (2.2.3.10170 - ???) <607B1457-CAD1-3A12-92CB-D0A3C25F7476> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_MediaCollector.avx/Contents/MacOS/MVP_MediaCollector
           0x297174000 -        0x2971fafff +com.gluetools.GT-PhantomCine-AMA (2.0.3031 - 2.0.3031) <9A4F30B3-3952-36D4-8712-ACE95CE1EC54> /Library/Application Support/Avid/*/GT_PhantomCine_AMA
           0x29722e000 -        0x297521fff +com.paceap.eden.WrapPersist (5.4.1 GM [b3455, 933b85fce7] - 5.4.1.3455) <B284E26C-A8EF-3361-B1BA-D7868EF7C908> /Library/Frameworks/PACEEdenExperience.framework/Versions/Current/WrapPersist.bundle/Contents/MacOS/WrapPersist
           0x297562000 -        0x297fccfff +com.WavesAudio.WaveShell1-AAX.11.0.0 (11.0.0 - 11.0.0127) <F1A65EF8-F56D-37AC-A43D-6B60A8D11E77> /Library/Application Support/Avid/*/WaveShell1-AAX
           0x29880a000 -        0x29929afff +com.WavesAudio.WaveShell1-AAX.12.7.0 (12.7.0 - 12.7.0209) <AD708086-394A-3E77-AB78-AC2D94123FA6> /Library/Application Support/Avid/*/WaveShell1-AAX
           0x299b5c000 -        0x299dd0fff +com.avid.AMA-Avid-IMF (1.0.2.10004 - ???) <FE18DDE1-CC66-3B5B-987F-8D306D211563> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/MVP_MSP_IMF
           0x29a00e000 -        0x29a328fff +libAvidMXF_SDK_4.6.45.dylib (0) <AD34DD8E-28CA-3F42-9D01-C6E4018A4099> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-ins/AMA/MVP_MSP_IMF.avx/Contents/MacOS/libAvidMXF_SDK_4.6.45.dylib
           0x29a565000 -        0x29a7bffff +com.avid.AMA-Avid-QuickTime (1.10.3.10210 - ???) <E2428480-916C-3633-AFDD-E19F0526FC73> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/MVP_MSP_QuickTime.avx/Contents/MacOS/MVP_MSP_QuickTime
           0x29a81c000 -        0x29aa49fff +com.avid.ama.autodetect (1.4.4.32 - ???) <E92D30B8-3311-3F90-BF0A-EF70383F2C5F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMAAutodetect.avx/Contents/MacOS/AMAAutodetect
           0x29ad11000 -        0x29afe7fff +com.avid.AMA-Avid-AS11 (1.9.6.10172 - ???) <25F8DDDD-96BC-3AE7-89B0-553DB1158622> /Library/Application Support/Avid/*/MSP_AS11
           0x29b183000 -        0x29b41efff +com.avid.AMA-Avid-MXF (1.22.11.10176 - ???) <1289D40B-57FE-3FC3-B50E-029FE09A3B0E> /Library/Application Support/Avid/*/MSP_MXF
           0x29b594000 -        0x29b67afff +com.avid.AMA-Avid-WaveAiff (1.8.7.10175 - ???) <6A2CF95E-95AD-341E-88FE-5737D7C8BA80> /Library/Application Support/Avid/*/MSP_WaveAiff
           0x29b6da000 -        0x29bc22fff +com.avid.AMA-Avid-AS02 (1.12.0.10177 - ???) <18BE4C58-F68D-346C-8E70-D105F49FAE38> /Library/Application Support/Avid/*/MVP_MSP_AS02
           0x29bfd8000 -        0x29c09bfff +com.avid.MVP_MSP_AvidImageSequencer (1.4.6.10174 - ???) <6B54E5E2-C73A-3E43-9EA2-855C7C3765F7> /Library/Application Support/Avid/*/MVP_MSP_AvidImageSequencer
           0x29c0ea000 -        0x29c1bafff +com.avid.AMA_Avid_REDR3D (1.19.21.10112 - ???) <30FA4512-11EA-38BE-BDCE-F6672292056B> /Library/Application Support/Avid/*/MVP_MSP_REDR3D
           0x29c217000 -        0x29c43afff +REDR3D.dylib (0) <3F88935C-39CB-3D8F-AA68-478BEF1CC694> /Library/Application Support/Avid/*/REDR3D.dylib
           0x29c466000 -        0x29c657fff +REDOpenCL.dylib (0) <D54DBEDF-8CEB-3FFF-9C86-D92670D10D66> /Library/Application Support/Avid/*/REDOpenCL.dylib
           0x29c6c0000 -        0x29c6e1fff +com.avid.AAC_ContainerHandler (9.0.20.10099 - ???) <F7EFCD6E-7137-3497-9348-44CBBBB65D1C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/AAC_ContainerHandler.acf/Contents/MacOS/AAC_ContainerHandler
           0x29c702000 -        0x29c72efff +com.avid.MP3_ContainerHandler (4.0.21.10041 - ???) <A0F5E73F-65D2-3832-9977-3344EA3FB8C6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/MP3_ContainerHandler.acf/Contents/MacOS/MP3_ContainerHandler
           0x29c754000 -        0x29cb9cfff +com.avid.QTFFContainerHandler (10.0.35.622 - ???) <F2E8D420-5100-32A6-96CB-8E44855ED801> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/QTFFContainerHandler.acf/Contents/MacOS/QTFFContainerHandler
           0x29cef7000 -        0x29cf66fff +com.avid.ImageSeq_ContainerHandler (1.2.4.154 - ???) <1516AB5A-C0D3-37AC-BA47-E48CBCFF2215> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/ImageSeq_ContainerHandler.acf/Contents/MacOS/ImageSeq_ContainerHandler
           0x29cfa9000 -        0x29d22ffff +com.avid.MXF_ContainerHandler (1.2.4.315 - ???) <4C19230B-9614-38C3-B3D1-50E5F271033D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/MXF_ContainerHandler.acf/Contents/MacOS/MXF_ContainerHandler
           0x29d421000 -        0x29d44ffff +com.avid.JPEGContainerHandler (9.0.17.10065 - ???) <D0299AAE-F211-3933-8E19-B5F5E3951B23> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/JPEGContainerHandler.acf/Contents/MacOS/JPEGContainerHandler
           0x29d476000 -        0x29d4fefff +com.avid.TiffContainerHandler (9.0.18.10071 - ???) <4335A679-C4E0-35FD-98D0-2FDBBA3B708F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMA-Avid-Q7/TiffContainerHandler.acf/Contents/MacOS/TiffContainerHandler
           0x29d533000 -        0x29d571fff +com.avid.DPX_ContainerHandler (1.0.14.52 - ???) <DC00D13A-8870-3B4A-B759-FE02D5623F6F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/DPX_ContainerHandler.acf/Contents/MacOS/DPX_ContainerHandler
           0x29d5a3000 -        0x29d8a9fff +com.avid.OpenEXR_ContainerHandler (1.0.18.10031 - ???) <29EF194F-934F-30F9-A60D-2DE3E95732E3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/OpenEXR_ContainerHandler.acf/Contents/MacOS/OpenEXR_ContainerHandler
           0x29d937000 -        0x29d9aefff +com.avid.PNG_ContainerHandler (1.0.17.50 - ???) <79C4B4AB-89A6-33B0-9F7C-A7F637AF98A0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/PNG_ContainerHandler.acf/Contents/MacOS/PNG_ContainerHandler
           0x29d9e9000 -        0x29da09fff +com.avid.TGA_ContainerHandler (1.0.4.10009 - ???) <C28E0C1B-6288-3B67-B30A-12B3DAEBDBE7> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/UME/TGA_ContainerHandler.acf/Contents/MacOS/TGA_ContainerHandler
           0x29da2a000 -        0x29da40fff +com.avid.AMADeviceMonitor (3.5.4.10016 - ???) <83015949-F94D-39EC-AD37-6B321FFB735C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/AMADeviceMonitor.avx/Contents/MacOS/AMADeviceMonitor
           0x29dc79000 -        0x29dd60fff +com.avid.AvidTitlerPlus (1.0 - 1.0) <AB92DD7F-A4CE-3E09-A2D3-02E01FA380AC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AvidTitlerPlus.avx/Contents/MacOS/AvidTitlerPlus
           0x29de10000 -        0x29fd4ffff +DekoLibrary.dylib (0) <CB934FF7-AE93-3C96-B9B2-20DC19D09554> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/DekoLibrary.dylib
           0x2a0517000 -        0x2a055afff +acpl_processing (???) <710DBB19-416C-399C-A880-07AC61ADAA45> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_processing.acf/Contents/MacOS/acpl_processing
           0x2a05a9000 -        0x2a05c5fff +acpl_convert (???) <E431E5B0-B30F-32E6-AD2D-CDD4E3400557> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/acpl_convert.acf/Contents/MacOS/acpl_convert
           0x2a05ec000 -        0x2a06ebfff +com.avid.AcplEffects (1.0 - 1.0) <610D7FC0-26B6-334A-B840-B5966E558866> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AcplEffects.avx/Contents/MacOS/AcplEffects
           0x2a1c26000 -        0x2a1c8dfff +com.avid.CodecToolkit.CodecMaster (3.15.9.301 - 3.15.9.301) <713E3AB8-7AA2-3D08-B7A3-31327BE3B2AD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/codecmaster.acf/Contents/MacOS/CodecMaster
           0x2a1cbd000 -        0x2a1ce0fff +com.avid.CodecToolkit.CTSharedResourceHandling (3.15.9.301 - 3.15.9.301) <C60FC7C2-5FB3-3624-AE62-F6235BF78CDC> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTSharedResourceHandling.acf/Contents/MacOS/CTSharedResourceHandling
           0x303677000 -        0x30377ffff +com.avid.MCEffects (1.0 - 1.0) <D6247653-10BA-3DF4-BE77-DAFC935557EB> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/MCEffects.avx/Contents/MacOS/MCEffects
           0x32820b000 -        0x328524fff +libcom-api.dylib (0) <E69861A1-2DF7-34AC-B8E7-FFE687BA616A> /Library/Application Support/Avid/libcom-api.dylib
           0x328846000 -        0x3289b1fff  com.apple.CodecsManager (1.0.0 - 1.0.0) <FC164B4D-5A67-D658-631F-3CE78F2FA7C6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CodecManager.avx/Contents/MacOS/CodecManager
           0x3289f2000 -        0x328aa6fff +com.avid.codecs.10packed (2.0.0 - 2.0.0) <3AA088B8-0C1F-253C-14CB-2779EBDED635> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvid10PackerCodec.avx/Contents/MacOS/CMAvid10PackerCodec
           0x328ae8000 -        0x329094fff +com.yourcompany.CMAvidAVCIntraCodec (2.0.0 - 2.0.0) <AB556A57-44C7-CA5E-AD49-D74474009033> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidAVCIntraCodec.avx/Contents/MacOS/CMAvidAVCIntraCodec
           0x329226000 -        0x329511fff +com.avid.codecs.dv100 (2.0.0 - 2.0.0) <F063437D-AC2C-DA6D-4262-C0AFB4286D1D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidDV100Codec.avx/Contents/MacOS/CMAvidDV100Codec
           0x3295a7000 -        0x329901fff +com.avid.codecs.dv (2.0.0 - 2.0.0) <7E5EFFF1-E9BC-22B7-DE9D-D9615B4DE82C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidDVCodec.avx/Contents/MacOS/CMAvidDVCodec
           0x3299b3000 -        0x32a382fff  com.apple.carbonframeworktemplate (2.0.0 - 2.0.0) <6A2766B2-84D4-FA91-C3E0-54ECB7648B20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidH264IBPCodecD2.avx/Contents/MacOS/CMAvidH264IBPCodecD2
           0x32a479000 -        0x32a788fff +com.avid.avxplugin.CMAvidHDCodec (2.0.0 - 2.0.0) <E0167A90-3AA9-092F-53AA-FECF1174FCA0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidHDCodec.avx/Contents/MacOS/CMAvidHDCodec
           0x32a892000 -        0x32aca7fff +com.yourcompany.CMAvidJ2KCodec (2.0.0 - 2.0.0) <D47F76F0-DB76-A2EB-0297-FDF9DABE0DF2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidJ2KCodec.avx/Contents/MacOS/CMAvidJ2KCodec
           0x32adab000 -        0x32b09dfff +com.avid.codecs.jpeg (2.0.0 - 2.0.0) <05D4A8D1-3DAB-C54C-38F4-C7EC9C5A6609> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidJPEGCodec.avx/Contents/MacOS/CMAvidJPEGCodec
           0x32b126000 -        0x32b407fff +com.avid.codecs.MPEG2EncoderBridge (2.0.0 - 2.0.0) <A3A89169-4760-E6A4-1B0C-6526FCD4FE12> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2EncoderBridge.avx/Contents/MacOS/CMAvidMPEG2EncoderBridge
           0x32b493000 -        0x32b7b7fff +com.avid.codecs.mpeg2 (2.0.0 - 2.0.0) <5057BBA7-9B70-39FE-6BCB-5CDD3E3B3AB4> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IBPCodec.avx/Contents/MacOS/CMAvidMPEG2IBPCodec
           0x32b853000 -        0x32bb4dfff +com.avid.codecs.mpeg2iframe (2.0.0 - 2.0.0) <074A9CD4-14F9-B776-850B-2980F3A9A763> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IFrameCodec.avx/Contents/MacOS/CMAvidMPEG2IFrameCodec
           0x32bbe9000 -        0x32beddfff +com.avid.codecs.mpeg2imx (2.0.0 - 2.0.0) <00FA8613-7F4D-B199-7633-989274FED7D2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG2IMXCodec.avx/Contents/MacOS/CMAvidMPEG2IMXCodec
           0x32bf7b000 -        0x32c334fff +com.avid.codecs.mpeg4 (2.0.0 - 2.0.0) <4232160E-AB81-4B9E-5189-4C97A148A98D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidMPEG4Codec.avx/Contents/MacOS/CMAvidMPEG4Codec
           0x32c3d3000 -        0x32c714fff +com.avid.codecs.ProResCodec (2.0.0 - 2.0.0) <F126A6F9-ED6D-2EF1-27DE-E1AB88215E45> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidProResCodec.avx/Contents/MacOS/CMAvidProResCodec
           0x32c7f7000 -        0x32c883fff +com.avid.codecs.rgbpacker (2.0.0 - 2.0.0) <C22E052B-2267-B423-2543-F19BC085EC9A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidRGBPacker.avx/Contents/MacOS/CMAvidRGBPacker
           0x32c8d3000 -        0x32cbadfff +com.avid.codecs.rle (2.0.0 - 2.0.0) <1522F954-037F-7F62-CE65-8521E09BEFFE> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidRLECodec.avx/Contents/MacOS/CMAvidRLECodec
           0x32cc20000 -        0x32cc76fff  com.apple.uncompressed (2.0.0 - 2.0.0) <B3640907-14DF-A60E-C041-6139131C2C3D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/Codecs/CMAvidUncompressedCodec.avx/Contents/MacOS/CMAvidUncompressedCodec
           0x32cca1000 -        0x32cd14fff +com.avid.CodecToolkit.BasicFilters (3.15.9.301 - 3.15.9.301) <482698DE-1C15-39BB-AF0F-AE2DDE9F8C8E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/BasicFilters.acf/Contents/MacOS/BasicFilters
           0x32cd26000 -        0x32cd92fff +com.avid.CodecToolkit.CTSharedCoreClasses (3.15.9.301 - 3.15.9.301) <472A66BE-A7A8-3DC6-A9C0-6F7CB84F27C1> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTSharedCoreClasses.acf/Contents/MacOS/CTSharedCoreClasses
           0x32cda2000 -        0x32ce5afff +com.avid.CodecToolkit.CATAAC (3.15.9.301 - 3.15.9.301) <1DFBC6CF-4D84-350D-8F1C-6B5FE4CD21A5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATAAC.acf/Contents/MacOS/CATAAC
           0x32ce6a000 -        0x32ce9cfff +com.avid.CodecToolkit.CATALAC (3.15.9.301 - 3.15.9.301) <21148601-04F8-3F32-BDEA-DDFD8AEACEE8> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATALAC.acf/Contents/MacOS/CATALAC
           0x32cea8000 -        0x32d844fff +com.avid.CodecToolkit.CATAVC (3.15.9.301 - 3.15.9.301) <6090706B-A3F5-31B5-9343-55462CF3146A> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATAVC.acf/Contents/MacOS/CATAVC
           0x32e03c000 -        0x32e26cfff +com.avid.CodecToolkit.CATJ2K (3.15.9.301 - 3.15.9.301) <6D1888AA-DDE4-3B71-8678-3E66521B80E3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATJ2K.acf/Contents/MacOS/CATJ2K
           0x32e28f000 -        0x32e367fff +com.avid.CodecToolkit.CATMJPEG (3.15.9.301 - 3.15.9.301) <588A8F7C-A7DF-37FC-AEC2-8C9EB0032E7D> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMJPEG.acf/Contents/MacOS/CATMJPEG
           0x32e37a000 -        0x32e3d6fff +com.avid.CodecToolkit.CATMP2 (3.15.9.301 - 3.15.9.301) <7FF2C845-4A17-37F1-B176-D030E3D2F86F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMP2.acf/Contents/MacOS/CATMP2
           0x32e3e4000 -        0x32e4b6fff +com.avid.CodecToolkit.CATMP3 (3.15.9.301 - 3.15.9.301) <C6EE18A6-BA70-3AF3-A889-BEB4E0928B84> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMP3.acf/Contents/MacOS/CATMP3
           0x32e4e8000 -        0x32e986fff +com.avid.CodecToolkit.CATMPEG2 (3.15.9.301 - 3.15.9.301) <8A2BCA55-D6E5-361F-97A0-1D909044123E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CATMPEG2.acf/Contents/MacOS/CATMPEG2
           0x32f54e000 -        0x32f580fff +com.avid.CodecToolkit.CTAC3 (3.15.9.301 - 3.15.9.301) <F739739F-FC5C-316B-82CD-FF371EF0EE23> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTAC3.acf/Contents/MacOS/CTAC3
           0x32f58d000 -        0x32f919fff +com.avid.CodecToolkit.CTACES (3.15.9.301 - 3.15.9.301) <F76DA26F-7DB4-3D37-9019-4CE71C0006D5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTACES.acf/Contents/MacOS/CTACES
           0x32f93f000 -        0x32f966fff +com.avid.CodecToolkit.CTAES3 (3.15.9.301 - 3.15.9.301) <D0E6A358-85A1-3E94-B150-46DF1A1AD75F> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTAES3.acf/Contents/MacOS/CTAES3
           0x32f972000 -        0x32fc49fff +com.avid.CodecToolkit.CTDNxUncompressed (3.15.9.301 - 3.15.9.301) <939922BA-4B92-339E-9525-77FCDABF409C> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTDNxUncompressed.acf/Contents/MacOS/CTDNxUncompressed
           0x32fc9b000 -        0x32fcecfff +com.avid.CodecToolkit.CTDPX (3.15.9.301 - 3.15.9.301) <8BA1A74A-CE4B-332C-9963-B3B47215D343> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTDPX.acf/Contents/MacOS/CTDPX
           0x32fcfe000 -        0x330bf0fff +com.avid.CodecToolkit.CTHEVC (3.15.9.301 - 3.15.9.301) <2DFBEF88-AD28-3AE7-9AC2-B437E42FE533> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTHEVC.acf/Contents/MacOS/CTHEVC
           0x3317cb000 -        0x331c03fff +com.avid.CodecToolkit.CTMPEG4 (3.15.9.301 - 3.15.9.301) <7EDA6224-1E00-3A77-8CEA-EEA330F0302E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTMPEG4.acf/Contents/MacOS/CTMPEG4
           0x332798000 -        0x332b2efff +com.avid.CodecToolkit.CTOpenEXR (3.15.9.301 - 3.15.9.301) <D103B863-F8F4-3E2D-AF71-12A89F7F22E6> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTOpenEXR.acf/Contents/MacOS/CTOpenEXR
           0x332b54000 -        0x332bc3fff +com.avid.CodecToolkit.CTPNG (3.15.9.301 - 3.15.9.301) <1BEF423F-4539-33E6-B422-2D2945222D73> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTPNG.acf/Contents/MacOS/CTPNG
           0x332bd3000 -        0x332bf6fff +com.avid.CodecToolkit.CTProResDecoder (3.15.9.301 - 3.15.9.301) <B9973D46-AF72-3C45-9652-79156EC8D935> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTProResDecoder.acf/Contents/MacOS/CTProResDecoder
           0x332c00000 -        0x332cfcfff +com.avid.CodecToolkit.ProResDecoderCore (1.5.0.191 - 1.5.0.191) <F4F6BF7C-6804-3177-AA7C-4C52879ABE34> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/ProResDecoderCore.acf/Contents/MacOS/ProResDecoderCore
           0x332d09000 -        0x332d2ffff +com.avid.CodecToolkit.CTProResEncoder (3.15.9.301 - 3.15.9.301) <8B3CCB78-02EB-3787-B94E-1921C8508CCA> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTProResEncoder.acf/Contents/MacOS/CTProResEncoder
           0x332d39000 -        0x332e31fff +com.avid.CodecToolkit.ProResEncoderCore (1.5.0.191 - 1.5.0.191) <C2851EB0-4C35-3E79-BA6D-AC1553785FBF> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/ProResEncoderCore.acf/Contents/MacOS/ProResEncoderCore
           0x332e3e000 -        0x332e87fff +com.avid.CodecToolkit.CTProResRAW (3.15.9.301 - 3.15.9.301) <98E27054-44B2-3A13-8621-EC826B3883B5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTProResRAW.acf/Contents/MacOS/CTProResRAW
           0x332e99000 -        0x332ee0fff +com.avid.CodecToolkit.CTQTRle (3.15.9.301 - 3.15.9.301) <F16BD12B-9CB1-38FB-8398-64336C51A3C3> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTQTRle.acf/Contents/MacOS/CTQTRle
           0x332ef1000 -        0x332f22fff +com.avid.CodecToolkit.CTTGA (3.15.9.301 - 3.15.9.301) <96421700-A715-3C15-9247-C85C3C5C9DB2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTTGA.acf/Contents/MacOS/CTTGA
           0x332f31000 -        0x332fcdfff +com.avid.CodecToolkit.CTTIFF (3.15.9.301 - 3.15.9.301) <AD650988-E18E-391C-99BF-D8F844057D20> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTTIFF.acf/Contents/MacOS/CTTIFF
           0x332fe1000 -        0x33329dfff +com.avid.CodecToolkit.CATDNX (3.15.9.301 - 3.15.9.301) <DC17F88E-2170-3257-AFAF-6608D81BA5F5> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/catdnx.acf/Contents/MacOS/CATDNX
           0x3332ec000 -        0x333350fff +com.avid.CodecToolkit.CTExtra (3.15.9.301 - 3.15.9.301) <667D42CA-4BCA-3FE7-8C55-9164CC967484> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/CodecToolkit/CTExtra.acf/Contents/MacOS/CTExtra
           0x3d31f8000 -        0x3d3437fff +com.avid.XMLPlugin (3.5.4.10016 - ???) <B31F8D2D-A4E2-34B9-8DF4-D9CBEACE8A06> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/AMA/XMLPlugin.avx/Contents/MacOS/XMLPlugin
           0x3d36b4000 -        0x3d36b7fff +com.avid.DynViewLoader (1.0 - 1.0) <F6DFB81E-207E-37CD-9AF3-4DEB9DEC4D2E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DynViewLoader.acf/Contents/MacOS/DynViewLoader
           0x3d36c6000 -        0x3d36ccfff +com.avid.DynViewEngineQt4 (1.0 - 1.0) <964DA600-CFA2-35FC-8768-C3C5CEFFDC5E> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/DynViewEngineQT4.acf/Contents/MacOS/DynViewEngineQt4
           0x3d36e5000 -        0x3d373efff +com.avid.SearchUIPlugin (1.0 - 1) <DE53AB7B-AEE8-35C9-B386-A5071093E7A2> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/SearchUIPlugin.acf/Contents/MacOS/SearchUIPlugin
           0x3d37ae000 -        0x3d37c4fff +com.avid.amf_Search (1.0 - 1) <4FF336A5-4C99-381C-AB48-D140070EE335> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/SharedSupport/AVX2_Plug-Ins/amf_Search.acf/Contents/MacOS/amf_Search
           0x3d37ef000 -        0x3d3834fff +com.avid.searchsupport (1.0 - 1) <E0153D4D-391E-3D7E-B0BB-4A6314820DFD> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/SearchSupport.framework/Versions/A/SearchSupport
           0x3d3877000 -        0x3d3896fff +com.avid.searchdb (1.0 - 1) <F7268EE8-D029-3049-8871-0DACA05AA4C0> /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/Frameworks/AvidSearchDB.framework/Versions/A/AvidSearchDB
        0x7fff2011e000 -     0x7fff2011ffff  libsystem_blocks.dylib (79) <925E3B6D-184D-3E73-97B1-643C4ADB387A> /usr/lib/system/libsystem_blocks.dylib
        0x7fff20120000 -     0x7fff20155fff  libxpc.dylib (2038.120.1) <FFFB49D7-2CA6-3E1F-AE4E-5697B19B7D76> /usr/lib/system/libxpc.dylib
        0x7fff20156000 -     0x7fff2016dfff  libsystem_trace.dylib (1277.120.1) <7E800ECA-DFDB-3737-A3C5-FFDE37E65383> /usr/lib/system/libsystem_trace.dylib
        0x7fff2016e000 -     0x7fff2020bfff  libcorecrypto.dylib (1000.140.4) <D211160D-E22F-3440-8054-1F5824519C7F> /usr/lib/system/libcorecrypto.dylib
        0x7fff2020c000 -     0x7fff20238fff  libsystem_malloc.dylib (317.140.5) <050E37E1-1458-3F80-BFA3-F1488570169D> /usr/lib/system/libsystem_malloc.dylib
        0x7fff20239000 -     0x7fff2027dfff  libdispatch.dylib (1271.120.2) <8144B0BD-90D2-3EAE-999F-AB0D14082088> /usr/lib/system/libdispatch.dylib
        0x7fff2027e000 -     0x7fff202b7fff  libobjc.A.dylib (824) <8C7C49A1-4211-3E4C-BA3D-160D675EEE96> /usr/lib/libobjc.A.dylib
        0x7fff202b8000 -     0x7fff202bafff  libsystem_featureflags.dylib (28.60.1) <E5C43AE3-19E7-3DAB-8B5D-D79A4B68B5C0> /usr/lib/system/libsystem_featureflags.dylib
        0x7fff202bb000 -     0x7fff20343fff  libsystem_c.dylib (1439.141.1) <3C273899-4CBE-32D5-BB31-7A449743204F> /usr/lib/system/libsystem_c.dylib
        0x7fff20344000 -     0x7fff20399fff  libc++.1.dylib (905.6) <FD6DB1CB-B14B-3404-8BEB-B459C2F6C303> /usr/lib/libc++.1.dylib
        0x7fff2039a000 -     0x7fff203affff  libc++abi.dylib (905.6) <D0CDDF98-1C04-300F-B685-4A4C59C04C42> /usr/lib/libc++abi.dylib
        0x7fff203b0000 -     0x7fff203dffff  libsystem_kernel.dylib (7195.141.6) <78289AAE-61B5-339F-A485-8819BC2388F2> /usr/lib/system/libsystem_kernel.dylib
        0x7fff203e0000 -     0x7fff203ebfff  libsystem_pthread.dylib (454.120.2) <1268FF2D-A513-3B51-BA65-AF2FF5789DDB> /usr/lib/system/libsystem_pthread.dylib
        0x7fff203ec000 -     0x7fff20427fff  libdyld.dylib (852.2) <3DE0178A-0AEE-3D08-AE19-6C6403F69BA1> /usr/lib/system/libdyld.dylib
        0x7fff20428000 -     0x7fff20431fff  libsystem_platform.dylib (254.80.2) <EF52D569-09F5-32E1-B1B3-34E2CA55A017> /usr/lib/system/libsystem_platform.dylib
        0x7fff20432000 -     0x7fff2045dfff  libsystem_info.dylib (542.40.3) <55B39B7F-957B-3D99-A8DF-7CA80D38155D> /usr/lib/system/libsystem_info.dylib
        0x7fff2045e000 -     0x7fff208fbfff  com.apple.CoreFoundation (6.9 - 1778.101) <8CF9D741-ADFF-3D5E-ACDE-DC342701EE0D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff208fc000 -     0x7fff20b31fff  com.apple.LaunchServices (1122.44 - 1122.44) <C285E620-3D2F-3AD0-8A3D-BB1FC540FE44> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff20b32000 -     0x7fff20c06fff  com.apple.gpusw.MetalTools (1.0 - 1) <C41024C5-01E7-3A66-A1F8-D7BC767260D8> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
        0x7fff20c07000 -     0x7fff20e63fff  libBLAS.dylib (1336.140.1) <170AFA22-1234-3DE9-9D94-52B3BE18E34E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff20e64000 -     0x7fff20eb1fff  com.apple.Lexicon-framework (1.0 - 86.2) <B7047A55-806D-3B32-A2D6-885D824E54A6> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
        0x7fff20eb2000 -     0x7fff20f20fff  libSparse.dylib (106) <1E68BF64-7432-3509-BC85-5DE95379E901> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
        0x7fff20f21000 -     0x7fff20f9efff  com.apple.SystemConfiguration (1.20 - 1.20) <8FEB39D4-ACD6-39F2-8D1B-A57CACD5628F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff20f9f000 -     0x7fff20fd3fff  libCRFSuite.dylib (50) <BCDD0ED1-D2F4-3556-B218-4420C7EA47D2> /usr/lib/libCRFSuite.dylib
        0x7fff20fd4000 -     0x7fff2120cfff  libmecabra.dylib (929.10) <D780814D-2BB2-3D84-820E-12E4C23C590E> /usr/lib/libmecabra.dylib
        0x7fff2120d000 -     0x7fff2156bfff  com.apple.Foundation (6.9 - 1778.101) <7B7FB88B-01D3-38CE-8029-837DB094C545> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff2156c000 -     0x7fff21654fff  com.apple.LanguageModeling (1.0 - 247.3) <DBFAE8CF-36B2-30D8-9E82-6C412CD935B4> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
        0x7fff21655000 -     0x7fff2178bfff  com.apple.CoreDisplay (237.4 - 237.4) <556BADE0-D3B0-309C-9740-7FEFBD052B6B> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
        0x7fff2178c000 -     0x7fff219fcfff  com.apple.audio.AudioToolboxCore (1.0 - 1181.72) <5C3B84EE-B281-34C4-832F-78F00CC63B93> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
        0x7fff219fd000 -     0x7fff21be2fff  com.apple.CoreText (677.6.0.2 - 677.6.0.2) <10E1382E-7949-3F4E-8B15-A4BD31A75E91> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff21be3000 -     0x7fff22274fff  com.apple.audio.CoreAudio (5.0 - 5.0) <5EEA9225-4837-37F3-9105-941A5743169F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff22275000 -     0x7fff225ccfff  com.apple.security (7.0 - 59754.140.13) <A196C85A-DB28-3F5B-A415-5BE44AD81668> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff225cd000 -     0x7fff2282cfff  libicucore.A.dylib (66112) <AC994BC1-F9CC-359C-A7B5-F2821EAEF650> /usr/lib/libicucore.A.dylib
        0x7fff2282d000 -     0x7fff22836fff  libsystem_darwin.dylib (1439.141.1) <2C81A009-45BB-30D7-A4F7-4B2EEC691617> /usr/lib/system/libsystem_darwin.dylib
        0x7fff22837000 -     0x7fff22b22fff  com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) <2C65E0D8-A9C7-31D8-A3D3-3AC1A91C80A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff22b23000 -     0x7fff22b61fff  com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <3FC6073F-78E4-3D3B-8765-50E50512C5EB> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff22b62000 -     0x7fff22b9cfff  com.apple.CSStore (1122.44 - 1122.44) <C103DAAA-A966-359B-97F0-BA3BB56ECBF1> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
        0x7fff22b9d000 -     0x7fff22c4bfff  com.apple.framework.IOKit (2.0.2 - 1845.120.6) <720D9AE1-79D6-3E77-8D7A-47F8F6681050> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff22c4c000 -     0x7fff22c57fff  libsystem_notify.dylib (279.40.4) <2E40EA4A-B124-3010-8379-1B4D7082A08F> /usr/lib/system/libsystem_notify.dylib
        0x7fff22c58000 -     0x7fff22ca5fff  libsandbox.1.dylib (1441.141.4) <C291C059-F7E4-3C20-BCBF-60F7011F0718> /usr/lib/libsandbox.1.dylib
        0x7fff22ca6000 -     0x7fff239f1fff  com.apple.AppKit (6.9 - 2022.60.128) <02EC69A0-D634-341B-BE3D-840F496F5814> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff239f2000 -     0x7fff23c40fff  com.apple.UIFoundation (1.0 - 728.9) <C2E04F0F-AEAA-3B77-9BBA-1CF628341A56> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
        0x7fff23c41000 -     0x7fff23c53fff  com.apple.UniformTypeIdentifiers (637 - 637) <8FFD3B69-0840-34D6-83AD-7D521B1A2339> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
        0x7fff23c54000 -     0x7fff23ddefff  com.apple.desktopservices (1.21 - 1346.6.1) <F2C97567-5B56-3840-A384-2131E362083B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff23ddf000 -     0x7fff23df1fff  com.apple.metadata.SpotlightLinguistics (1.0 - 1) <BA448116-6C8C-3A4B-9F28-9D8CEAAD5769> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
        0x7fff23df2000 -     0x7fff24000fff  com.apple.CoreDuet (1.0 - 1) <BC29FC19-7BE1-3CC9-9668-39209F43C7F1> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
        0x7fff240be000 -     0x7fff24744fff  libnetwork.dylib (2288.140.7) <42825FCA-35A1-352F-AE68-19D8F695604B> /usr/lib/libnetwork.dylib
        0x7fff24745000 -     0x7fff24be3fff  com.apple.CFNetwork (1240.0.4 - 1240.0.4) <E4BF9BFF-798B-33FF-B37D-6D8175CA708A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff24be4000 -     0x7fff24bf2fff  libsystem_networkextension.dylib (1295.140.3) <83AA4425-2F1D-36EC-B77B-8D4F03CDDB68> /usr/lib/system/libsystem_networkextension.dylib
        0x7fff24bf3000 -     0x7fff24bf3fff  libenergytrace.dylib (22.100.1) <9E877E0A-5261-3F75-91A0-521423499AD0> /usr/lib/libenergytrace.dylib
        0x7fff24bf4000 -     0x7fff24c50fff  libMobileGestalt.dylib (978.140.1) <D1FF79C3-4B2F-32FB-BF25-9F0B9E160692> /usr/lib/libMobileGestalt.dylib
        0x7fff24c51000 -     0x7fff24c67fff  libsystem_asl.dylib (385) <8D324D65-EE16-3A1A-BD39-ACB1B3050D1F> /usr/lib/system/libsystem_asl.dylib
        0x7fff24c68000 -     0x7fff24c80fff  com.apple.TCC (1.0 - 1) <18F48712-FFF0-3B30-B2C4-8A93AEF86A34> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff24c81000 -     0x7fff24fe6fff  com.apple.SkyLight (1.600.0 - 588.7) <5F88F814-A3DF-3446-8B35-F0CDD8C1B302> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
        0x7fff24fe7000 -     0x7fff25670fff  com.apple.CoreGraphics (2.0 - 1463.17.3) <5EDF86BC-FFDE-3906-9674-142C113B34EF> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff25671000 -     0x7fff25767fff  com.apple.ColorSync (4.13.0 - 3473.4.3) <102C423C-E05F-317B-83AE-A2A6B77D653B> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff25768000 -     0x7fff257c3fff  com.apple.HIServices (1.22 - 716) <B2D34F3F-0CEB-35F1-9B32-E0806CF3FC91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff257c4000 -     0x7fff25802fff  libAWDSupport.dylib (951) <F10D0972-6D3C-325B-A977-48E0EC6B087D> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
        0x7fff25803000 -     0x7fff2585ffff  libprotobuf.dylib (4205) <25B06010-4F03-3B97-873E-94410285D572> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
        0x7fff25860000 -     0x7fff25871fff  libprotobuf-lite.dylib (4205) <035E309C-861F-393B-BB10-D8C42F63E6F6> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
        0x7fff25872000 -     0x7fff258b6fff  com.apple.awd (1.0 - 951) <950DBA92-CC7B-3355-BAEE-083FFFBDF500> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
        0x7fff258b7000 -     0x7fff25a77fff  com.apple.Montreal (1.0 - 142) <04ABAAAD-2C28-3AA5-90C9-BD4B7869042F> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
        0x7fff25a78000 -     0x7fff25b69fff  com.apple.NLP (1.0 - 210.2) <0D6A0E1B-1381-316E-B488-3025D5608B4D> /System/Library/PrivateFrameworks/NLP.framework/Versions/A/NLP
        0x7fff25b6a000 -     0x7fff25f89fff  com.apple.CoreData (120 - 1048) <33DE1B26-D4C6-3939-B12E-88897660BB38> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff25f8a000 -     0x7fff25f9ffff  com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <AEDEFF64-CA8A-365C-900F-3107383F91D9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
        0x7fff25fa0000 -     0x7fff26153fff  libsqlite3.dylib (321.3) <E7377C46-DA4F-3486-B935-0A35C3637215> /usr/lib/libsqlite3.dylib
        0x7fff26154000 -     0x7fff261d0fff  com.apple.Accounts (113 - 113) <2AD45648-B327-313A-ACF2-846FB345A96E> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
        0x7fff261d1000 -     0x7fff261e8fff  com.apple.commonutilities (8.0 - 900) <98B456F4-8F4F-387B-B3BB-D3919295AE1D> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
        0x7fff261e9000 -     0x7fff26268fff  com.apple.BaseBoard (526 - 526) <F9D85C3A-D0D6-351B-A6EE-5416CB90179D> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
        0x7fff26269000 -     0x7fff262b1fff  com.apple.RunningBoardServices (1.0 - 505.100.9) <2ED406CD-2253-33F0-B16A-694DB447CADC> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
        0x7fff262b2000 -     0x7fff26326fff  com.apple.AE (918.6 - 918.6) <C5130BB4-18E7-3804-A9D9-915D318426A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff26327000 -     0x7fff2632dfff  libdns_services.dylib (1310.140.1) <22BE5030-2F48-3ED6-9DF8-9D102CEF33FF> /usr/lib/libdns_services.dylib
        0x7fff2632e000 -     0x7fff26335fff  libsystem_symptoms.dylib (1431.140.1) <1B4D8837-C951-3B69-B079-85D477749E8B> /usr/lib/system/libsystem_symptoms.dylib
        0x7fff26336000 -     0x7fff264c1fff  com.apple.Network (1.0 - 1) <2155E1AA-2067-36CF-979E-2F96062D5CFE> /System/Library/Frameworks/Network.framework/Versions/A/Network
        0x7fff264c2000 -     0x7fff264f1fff  com.apple.analyticsd (1.0 - 1) <0DF60ECD-742C-39D1-964A-48EC3DEA6319> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
        0x7fff264f2000 -     0x7fff264f4fff  libDiagnosticMessagesClient.dylib (112) <A7EC7265-E13C-3C98-81EE-3EFB5CC65AB0> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff264f5000 -     0x7fff26541fff  com.apple.spotlight.metadata.utilities (1.0 - 2150.26) <F709AE5E-AF80-3C9B-A3D3-B779164FBA95> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
        0x7fff26542000 -     0x7fff265dcfff  com.apple.Metadata (10.7.0 - 2150.26) <D7CE41CA-DDE7-32BE-926C-0DC3048C5E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
        0x7fff265dd000 -     0x7fff265e3fff  com.apple.DiskArbitration (2.7 - 2.7) <8DF059B4-BE32-3171-8CC4-C5FA189FA718> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff265e4000 -     0x7fff26c4bfff  com.apple.vImage (8.1 - 544.4) <E62F9E4F-9A1D-3004-B7F4-6F83F71144C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
        0x7fff26c4c000 -     0x7fff26f29fff  com.apple.QuartzCore (1.11 - 927.24) <88794856-F1F1-3D23-BDDB-0AE28A1D6D6E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff26f2a000 -     0x7fff26f6bfff  libFontRegistry.dylib (309) <300F2208-7274-38F8-B88D-9237BA6B397E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff26f6c000 -     0x7fff270acfff  com.apple.coreui (2.1 - 692.1) <BC5D8EAA-7CE8-35F3-8EAD-075B18D9606C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff270ad000 -     0x7fff27198fff  com.apple.ViewBridge (553.1 - 553.1) <DF83EA6E-4DA9-3322-BE86-0B3207167451> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
        0x7fff27199000 -     0x7fff271a4fff  com.apple.PerformanceAnalysis (1.278.3 - 278.3) <6AF20F05-FF15-3174-A504-1AC16BA14729> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
        0x7fff271a5000 -     0x7fff271b4fff  com.apple.OpenDirectory (11.6 - 230.40.1) <84B2D11F-E6C4-3C29-9A9A-939DB906E2F5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff271b5000 -     0x7fff271d4fff  com.apple.CFOpenDirectory (11.6 - 230.40.1) <6BE3204F-2F86-34A7-AD79-4C88320F446F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff271d5000 -     0x7fff271e1fff  com.apple.CoreServices.FSEvents (1290.120.5 - 1290.120.5) <DC473A17-310F-3C16-B545-F75CE3F6D39D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
        0x7fff271e2000 -     0x7fff27206fff  com.apple.coreservices.SharedFileList (144 - 144) <A13B58B8-6D7A-3F1B-AFB5-E41E0A6B4B81> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
        0x7fff27207000 -     0x7fff27209fff  libapp_launch_measurement.dylib (14.1) <511EC2A9-6059-3A7D-9D2A-741189922D02> /usr/lib/libapp_launch_measurement.dylib
        0x7fff2720a000 -     0x7fff27251fff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <18113C8E-B54E-3DD3-A1AD-2A5FD949CE66> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
        0x7fff27252000 -     0x7fff27334fff  libxml2.2.dylib (34.10) <DD2093F0-F9B7-3F30-B46D-B028CE15E2B1> /usr/lib/libxml2.2.dylib
        0x7fff27335000 -     0x7fff27382fff  com.apple.CoreVideo (1.8 - 414.7) <EE991A40-DE38-3B13-891E-A51987D5CD70> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff27383000 -     0x7fff27385fff  com.apple.loginsupport (1.0 - 1) <4C358D8E-4BB8-3DD8-8A72-11BD80607BDE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
        0x7fff27386000 -     0x7fff273adfff  com.apple.aps.framework (4.0 - 4.0) <A76C4B82-24CD-3AF4-BADD-6135F6E7057A> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
        0x7fff273ae000 -     0x7fff273c9fff  com.apple.UserManagement (1.0 - 1) <FB298359-31F5-3DDD-B928-604C4B1ED1F3> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
        0x7fff273ca000 -     0x7fff2755bfff  com.apple.cloudkit.CloudKit (990 - 990) <A4ADF4E3-AC2D-322B-B76C-BC249AB27395> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
        0x7fff2755c000 -     0x7fff275ddfff  com.apple.CloudDocs (1.0 - 738.1) <86A6C439-BA71-321C-B330-A60BA4011C99> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
        0x7fff275de000 -     0x7fff2796dfff  com.apple.CoreML (1.0 - 1) <3845782D-F855-3DD4-ADD3-8CB08C2BCFE5> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
        0x7fff2796e000 -     0x7fff282bffff  libwebrtc.dylib (7611.3.10.1.6) <CBCA9241-7714-378B-97C6-5D404C6284A7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
        0x7fff282c0000 -     0x7fff2833cfff  com.apple.corelocation (2420.19.23 - 2420.19.23) <1BEB1A0D-4122-3F8C-AC1A-07A12C36C84F> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
        0x7fff2833d000 -     0x7fff2834dfff  libsystem_containermanager.dylib (318.100.4) <1139CD47-9CBA-356F-8694-1D00EB9F0C8F> /usr/lib/system/libsystem_containermanager.dylib
        0x7fff2834e000 -     0x7fff2835ffff  com.apple.IOSurface (290.8.1 - 290.8.1) <8B251196-DA38-38BF-8A91-45AC2B06014C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff28360000 -     0x7fff28369fff  com.apple.IOAccelerator (442.9 - 442.9) <F2C3DC87-49D7-3A67-8E6D-12D75D98EFDD> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
        0x7fff2836a000 -     0x7fff2848dfff  com.apple.Metal (244.303 - 244.303) <71B6039E-232E-3AD2-881F-DF8E73C75B99> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
        0x7fff2848e000 -     0x7fff284aafff  com.apple.audio.caulk (1.0 - 70) <F6A09FF3-1DC7-302C-86E3-B2DD9B7130A9> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
        0x7fff284ab000 -     0x7fff28595fff  com.apple.CoreMedia (1.0 - 2780.10) <6A003180-F8AA-3DFA-B095-61D8E859FE3F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff28596000 -     0x7fff286f2fff  libFontParser.dylib (305.6.0.4) <C3E552F6-72AD-3F3A-B217-E44A5C565240> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
        0x7fff286f3000 -     0x7fff289eefff  com.apple.HIToolbox (2.1.1 - 1062) <DEF01A0C-8B9D-359E-9FE7-B15D551888DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff289ef000 -     0x7fff28a02fff  com.apple.framework.DFRFoundation (1.0 - 267) <EBFDDB28-7661-3B50-BC15-736C5DF05AB3> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
        0x7fff28a03000 -     0x7fff28a06fff  com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <DD9E09C3-B658-3BD2-8229-E3E3C5D85552> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
        0x7fff28a07000 -     0x7fff28a30fff  com.apple.CoreSVG (1.0 - 149) <C4DC952A-9373-33E5-8A98-F008986B0420> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
        0x7fff28a31000 -     0x7fff28c6dfff  com.apple.ImageIO (3.3.0 - 2130.7.3) <28C6A501-2548-3187-A13B-9F314280BBB8> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff28c6e000 -     0x7fff28fe9fff  com.apple.CoreImage (16.3.0 - 1140.2) <3ED3F244-632C-383D-89B0-50F2E0FDBA40> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff28fea000 -     0x7fff29050fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <C12F8828-6D1E-3820-BBF7-80EEA978AE9C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
        0x7fff29051000 -     0x7fff29054fff  libsystem_configuration.dylib (1109.140.1) <02F3A5C9-6289-3012-8F5F-F1DB669ADB79> /usr/lib/system/libsystem_configuration.dylib
        0x7fff29055000 -     0x7fff29059fff  libsystem_sandbox.dylib (1441.141.4) <5471601B-5072-3E97-8926-804FF08DC4C0> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff2905a000 -     0x7fff2905bfff  com.apple.AggregateDictionary (1.0 - 1) <B25A1764-0BBC-388B-8FB4-A8FBB8F51C10> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
        0x7fff2905c000 -     0x7fff2905ffff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <4A803F86-CA61-3508-864A-302F032ADA70> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff29060000 -     0x7fff29061fff  liblangid.dylib (136) <F4019132-A63D-3A38-A8DB-974C6F1311ED> /usr/lib/liblangid.dylib
        0x7fff29062000 -     0x7fff29106fff  com.apple.CoreNLP (1.0 - 245.2) <203C6AB9-5B07-3370-A056-DA1F2C8A8419> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
        0x7fff29107000 -     0x7fff2910dfff  com.apple.LinguisticData (1.0 - 399) <AB85B59F-3047-37EC-AB9E-835D87BACF73> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
        0x7fff2910e000 -     0x7fff297b6fff  libBNNS.dylib (288.100.5) <4BB7A1B7-D1F2-3DC3-BFC7-D57CBD892719> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
        0x7fff297b7000 -     0x7fff29989fff  libvDSP.dylib (760.100.3) <DA809F3E-9391-3BE0-98C6-061CCACA809A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff2998a000 -     0x7fff2999bfff  com.apple.CoreEmoji (1.0 - 128.4) <8DB42230-A624-3C13-80F8-EC2CE89C0699> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
        0x7fff2999c000 -     0x7fff299a6fff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <195E20E7-33BD-3935-92ED-AA354180B7FA> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
        0x7fff299a7000 -     0x7fff29a79fff  com.apple.framework.CoreWLAN (16.0 - 1657) <0A58C97E-2ACD-3223-8585-FDA5DA4C38C5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff29a7a000 -     0x7fff29c7bfff  com.apple.CoreUtils (6.6 - 660.37) <0B1ED18A-B228-3840-A0F2-23AC2C37A6CA> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
        0x7fff29c7c000 -     0x7fff29c9efff  com.apple.MobileKeyBag (2.0 - 1.0) <19D8140C-CC92-35E8-AF78-B335567A7C24> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
        0x7fff29c9f000 -     0x7fff29caffff  com.apple.AssertionServices (1.0 - 505.100.9) <850AE031-A3B3-30C0-81A1-71FBCE620BC1> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
        0x7fff29cb0000 -     0x7fff29d3bfff  com.apple.securityfoundation (6.0 - 55240.40.4) <A7D05091-B54C-317A-81FE-4B174C968C5A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff29d3c000 -     0x7fff29d45fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <98B365F9-8E0C-32C7-AC5A-FFB9A4A0B30A> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
        0x7fff29d46000 -     0x7fff29d4afff  com.apple.xpc.ServiceManagement (1.0 - 1) <7D081389-0032-3521-A3D9-84B4667817FB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff29d4b000 -     0x7fff29d4dfff  libquarantine.dylib (119.40.2) <3244B57B-9FDF-373E-9F96-A7BAD7534F23> /usr/lib/system/libquarantine.dylib
        0x7fff29d4e000 -     0x7fff29d59fff  libCheckFix.dylib (31) <AAB549BA-1738-33FD-BBC4-C34B5070C309> /usr/lib/libCheckFix.dylib
        0x7fff29d5a000 -     0x7fff29d71fff  libcoretls.dylib (169.100.1) <FC2811AD-9D76-3403-B760-32A101D07638> /usr/lib/libcoretls.dylib
        0x7fff29d72000 -     0x7fff29d82fff  libbsm.0.dylib (68.40.1) <61577B7F-2C06-365C-9039-E00B0B5258D0> /usr/lib/libbsm.0.dylib
        0x7fff29d83000 -     0x7fff29dccfff  libmecab.dylib (929.10) <D60C5095-3A5F-3284-9699-08C76DA29CBD> /usr/lib/libmecab.dylib
        0x7fff29dcd000 -     0x7fff29dd2fff  libgermantok.dylib (24) <6F2B01E8-6077-3B72-91F3-AB6D0FCB15D6> /usr/lib/libgermantok.dylib
        0x7fff29dd3000 -     0x7fff29de8fff  libLinearAlgebra.dylib (1336.140.1) <A450756D-D3AC-342D-A802-ED6C554A494A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
        0x7fff29de9000 -     0x7fff2a007fff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <8AAFA6C5-1FBD-359A-8774-F1D1FBFCCFFE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
        0x7fff2a008000 -     0x7fff2a057fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <0C854684-1D62-35D1-83C1-9066DB158189> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
        0x7fff2a058000 -     0x7fff2a1b9fff  com.apple.MLCompute (1.0 - 1) <9255AB44-3AB5-3F3F-8FA2-77FEA1C7C221> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
        0x7fff2a1ba000 -     0x7fff2a1f0fff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <B7361691-334A-3A33-98E1-A9A623E5D26A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
        0x7fff2a1f1000 -     0x7fff2a247fff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <706E8171-48B3-33A3-B55B-35B5F86F3043> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
        0x7fff2a248000 -     0x7fff2a2d8fff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <3999E177-7A40-358A-BE89-1F20ADF13740> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
        0x7fff2a2d9000 -     0x7fff2a2e8fff  com.apple.AppleFSCompression (125 - 1.0) <F7163A3A-C4F0-3169-9501-B9AAB8CAE9CD> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
        0x7fff2a2e9000 -     0x7fff2a2f5fff  libbz2.1.0.dylib (44) <ECD22F5B-FD6C-39A5-884B-418C6B896263> /usr/lib/libbz2.1.0.dylib
        0x7fff2a2f6000 -     0x7fff2a2fafff  libsystem_coreservices.dylib (127.1) <619CCB6D-226C-35BD-98FB-04A18FD54792> /usr/lib/system/libsystem_coreservices.dylib
        0x7fff2a2fb000 -     0x7fff2a328fff  com.apple.CoreServices.OSServices (1122.44 - 1122.44) <C547575F-985F-31B8-A61C-79D3A673B8D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
        0x7fff2a329000 -     0x7fff2a458fff  com.apple.AuthKit (1.0 - 1) <C72D7981-A3B6-3883-A14F-43485DF54FC4> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
        0x7fff2a459000 -     0x7fff2a487fff  com.apple.UserNotifications (1.0 - 348.5) <36B03A58-F8A4-3671-9B0B-1B87FF9D3FA0> /System/Library/Frameworks/UserNotifications.framework/Versions/A/UserNotifications
        0x7fff2a488000 -     0x7fff2a4f6fff  com.apple.CoreSpotlight (1.0 - 2150.26) <4D4F3348-8920-3E95-80D5-304CCCAEF338> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
        0x7fff2a4f7000 -     0x7fff2a509fff  libz.1.dylib (76) <F805C1CB-1B80-33D0-994C-1D522D347A68> /usr/lib/libz.1.dylib
        0x7fff2a50a000 -     0x7fff2a551fff  libsystem_m.dylib (3186.100.3) <D61B56FE-649B-34A0-8446-25685B2BBBF2> /usr/lib/system/libsystem_m.dylib
        0x7fff2a552000 -     0x7fff2a552fff  libcharset.1.dylib (59) <363A6C40-7446-3A72-B5EA-4731843CFE2F> /usr/lib/libcharset.1.dylib
        0x7fff2a553000 -     0x7fff2a558fff  libmacho.dylib (980) <A4F4D532-7824-3E4E-8FB6-45617415E7DD> /usr/lib/system/libmacho.dylib
        0x7fff2a559000 -     0x7fff2a574fff  libkxld.dylib (7195.141.6) <1121F83B-5D42-368B-B440-100418CD4B23> /usr/lib/system/libkxld.dylib
        0x7fff2a575000 -     0x7fff2a580fff  libcommonCrypto.dylib (60178.120.3) <CF1E0E70-9F6C-3FAF-82B2-D55F7C9EBB03> /usr/lib/system/libcommonCrypto.dylib
        0x7fff2a581000 -     0x7fff2a58bfff  libunwind.dylib (201) <4602E909-C71A-3006-8140-BE616DA241EE> /usr/lib/system/libunwind.dylib
        0x7fff2a58c000 -     0x7fff2a593fff  liboah.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/liboah.dylib
        0x7fff2a594000 -     0x7fff2a59efff  libcopyfile.dylib (173.40.2) <B0F35A80-D5E3-33DD-A47D-ACBFE1300523> /usr/lib/system/libcopyfile.dylib
        0x7fff2a59f000 -     0x7fff2a5a6fff  libcompiler_rt.dylib (102.2) <1C049207-1719-39AC-A2A9-6E5BE28AA138> /usr/lib/system/libcompiler_rt.dylib
        0x7fff2a5a7000 -     0x7fff2a5a9fff  libsystem_collections.dylib (1439.141.1) <F2D775D9-AAEF-371F-AA54-CFB882B9B430> /usr/lib/system/libsystem_collections.dylib
        0x7fff2a5aa000 -     0x7fff2a5acfff  libsystem_secinit.dylib (87.60.1) <EB4516ED-1F8B-3E8A-8C4B-B209A33DCCEF> /usr/lib/system/libsystem_secinit.dylib
        0x7fff2a5ad000 -     0x7fff2a5affff  libremovefile.dylib (49.120.1) <1AEE3D84-32F9-35FB-8036-B178C9E27D20> /usr/lib/system/libremovefile.dylib
        0x7fff2a5b0000 -     0x7fff2a5b0fff  libkeymgr.dylib (31) <698AF6EE-08BB-36CF-B7AD-9EC16E36FA0B> /usr/lib/system/libkeymgr.dylib
        0x7fff2a5b1000 -     0x7fff2a5b8fff  libsystem_dnssd.dylib (1310.140.1) <0685BDB0-9A98-3ADD-B95A-11F221FD80D7> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff2a5b9000 -     0x7fff2a5befff  libcache.dylib (83) <B51FAB34-AA9C-38C5-95F1-E5E54B21EA67> /usr/lib/system/libcache.dylib
        0x7fff2a5bf000 -     0x7fff2a5c0fff  libSystem.B.dylib (1292.120.1) <DBD0A184-CD98-3225-8E9B-D5BFE0D30562> /usr/lib/libSystem.B.dylib
        0x7fff2a5c1000 -     0x7fff2a5c4fff  libfakelink.dylib (3) <BE0E6C60-675A-3739-A47A-67C650B1F790> /usr/lib/libfakelink.dylib
        0x7fff2a5c5000 -     0x7fff2a5c5fff  com.apple.SoftLinking (1.0 - 1) <9E4B6591-74E3-3B36-91C4-851FAA567DAA> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
        0x7fff2a5c6000 -     0x7fff2a5fdfff  libpcap.A.dylib (98.100.3) <6DD23455-C0CA-313E-89B5-A45F8CD71C20> /usr/lib/libpcap.A.dylib
        0x7fff2a5fe000 -     0x7fff2a6eefff  libiconv.2.dylib (59) <90F749E2-9D2D-3323-A018-31A1F95221A1> /usr/lib/libiconv.2.dylib
        0x7fff2a6ef000 -     0x7fff2a700fff  libcmph.dylib (8) <17871D7D-49C2-3343-AC30-C40E3AD5B2B6> /usr/lib/libcmph.dylib
        0x7fff2a701000 -     0x7fff2a772fff  libarchive.2.dylib (83.100.2) <5AF9560E-5683-33A5-8D60-A469193B94E3> /usr/lib/libarchive.2.dylib
        0x7fff2a773000 -     0x7fff2a7dafff  com.apple.SearchKit (1.4.1 - 1.4.1) <A45AE5BD-9242-351E-B621-3EB50F66AB30> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
        0x7fff2a7db000 -     0x7fff2a7dcfff  libThaiTokenizer.dylib (3) <7B40AC51-B945-3AF0-B349-5818050D37FB> /usr/lib/libThaiTokenizer.dylib
        0x7fff2a7dd000 -     0x7fff2a7fffff  com.apple.applesauce (1.0 - 16.28) <7D011403-38CD-37DA-B2C2-00D2D2273422> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
        0x7fff2a800000 -     0x7fff2a817fff  libapple_nghttp2.dylib (1.41) <E3FCBDB9-6671-3368-B371-B9CAC9BB1B45> /usr/lib/libapple_nghttp2.dylib
        0x7fff2a818000 -     0x7fff2a82efff  libSparseBLAS.dylib (1336.140.1) <78762464-084C-3743-BC56-A2AF5D010909> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
        0x7fff2a82f000 -     0x7fff2a830fff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <BD2B6B2B-E116-3B97-A25F-71B4AC7B2BA6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
        0x7fff2a831000 -     0x7fff2a835fff  libpam.2.dylib (28.40.1) <E73D1903-42B9-3FF9-AE5D-482672F015AC> /usr/lib/libpam.2.dylib
        0x7fff2a836000 -     0x7fff2a855fff  libcompression.dylib (96.120.1) <CFE780B4-AFB0-327C-BB68-A5565AA7C630> /usr/lib/libcompression.dylib
        0x7fff2a856000 -     0x7fff2a85bfff  libQuadrature.dylib (7) <9668C241-61D5-3AE9-9856-708ACDC27F12> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
        0x7fff2a85c000 -     0x7fff2abf9fff  libLAPACK.dylib (1336.140.1) <8B968A9A-8263-3639-A740-636387467C03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff2abfa000 -     0x7fff2ac49fff  com.apple.DictionaryServices (1.2 - 341) <617030DF-769F-3CE0-869F-7F5B9B5A3784> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff2ac4a000 -     0x7fff2ac62fff  liblzma.5.dylib (16) <6DE3F2AA-7140-3F6D-AD12-0DBA19BBBD54> /usr/lib/liblzma.5.dylib
        0x7fff2ac63000 -     0x7fff2ac64fff  libcoretls_cfhelpers.dylib (169.100.1) <0CF72D7A-0A39-3683-82ED-29A09761D6FF> /usr/lib/libcoretls_cfhelpers.dylib
        0x7fff2ac65000 -     0x7fff2ad60fff  com.apple.APFS (1677.141.2 - 1677.141.2) <F42A21D0-F8CE-3DDA-ACE6-C0AC9EE2FA6C> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
        0x7fff2ad61000 -     0x7fff2ad6efff  libxar.1.dylib (452) <0B0B68CC-D627-3BDC-AE01-007C6AD8E97B> /usr/lib/libxar.1.dylib
        0x7fff2ad6f000 -     0x7fff2ad72fff  libutil.dylib (58.40.2) <0EA3237C-B6E6-351B-AE27-8975D88602D6> /usr/lib/libutil.dylib
        0x7fff2ad73000 -     0x7fff2ad9bfff  libxslt.1.dylib (17.6) <300C3D2D-19B1-3D8E-B212-1D2EB6C8B80A> /usr/lib/libxslt.1.dylib
        0x7fff2ad9c000 -     0x7fff2ada6fff  libChineseTokenizer.dylib (37.1) <B4314553-EF8B-3CD4-A7D8-76CD7FC7142D> /usr/lib/libChineseTokenizer.dylib
        0x7fff2ada7000 -     0x7fff2ae64fff  libvMisc.dylib (760.100.3) <B8F30684-94D1-3A53-80BF-C78F424594AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff2ae65000 -     0x7fff2aefcfff  libate.dylib (3.0.6) <FA881406-28F3-33BD-B75D-40389CE2ADD1> /usr/lib/libate.dylib
        0x7fff2aefd000 -     0x7fff2af04fff  libIOReport.dylib (64.100.1) <4D638FAC-2FD8-359C-8159-1ED37CBB5704> /usr/lib/libIOReport.dylib
        0x7fff2af05000 -     0x7fff2af18fff  com.apple.CrashReporterSupport (10.13 - 15053.1) <B879B52A-5A65-3CB3-B271-15A032853A35> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
        0x7fff2af30000 -     0x7fff2afadfff  com.apple.CVNLP (1.0 - 119) <3604CA5C-2547-3C9A-99F5-3A7AB0DBE0B1> /System/Library/PrivateFrameworks/CVNLP.framework/Versions/A/CVNLP
        0x7fff2afcf000 -     0x7fff2b005fff  com.apple.pluginkit.framework (1.0 - 1) <84F2AE60-705A-3B37-B42E-13EF51B1FA1B> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
        0x7fff2b006000 -     0x7fff2b00dfff  libMatch.1.dylib (38) <85F66EF8-FC5E-385C-AF8F-79532C2AC988> /usr/lib/libMatch.1.dylib
        0x7fff2b00e000 -     0x7fff2b099fff  libCoreStorage.dylib (554.140.2) <249F3E03-6C96-3E20-999A-BBFE36AADECA> /usr/lib/libCoreStorage.dylib
        0x7fff2b09a000 -     0x7fff2b0edfff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <2CDA1194-F435-3B9C-94A2-220E26E40DE6> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff2b0ee000 -     0x7fff2b107fff  libexpat.1.dylib (26.141.1) <84DC54E5-9E75-3F64-9D7F-3CA641674ED8> /usr/lib/libexpat.1.dylib
        0x7fff2b108000 -     0x7fff2b111fff  libheimdal-asn1.dylib (597.140.2) <8D7B3A0D-A699-3947-9E8C-EEA4B4AD6408> /usr/lib/libheimdal-asn1.dylib
        0x7fff2b112000 -     0x7fff2b126fff  com.apple.IconFoundation (479.4 - 479.4) <6ED33568-2A1D-3918-9D32-D1E102002E48> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
        0x7fff2b127000 -     0x7fff2b193fff  com.apple.IconServices (479.4 - 479.4) <D94D5AF3-6EF6-30D8-A7F8-58A1A3E5641B> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
        0x7fff2b194000 -     0x7fff2b232fff  com.apple.MediaExperience (1.0 - 1) <245932F7-E76A-37A7-A033-7BB62F8ED190> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
        0x7fff2b233000 -     0x7fff2b25bfff  com.apple.persistentconnection (1.0 - 1.0) <90FBA2DD-E91A-3A9F-80C5-8F94950136A4> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
        0x7fff2b25c000 -     0x7fff2b26afff  com.apple.GraphVisualizer (1.0 - 100.1) <9538C368-5703-367B-ADAE-20EC5C3C5C41> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
        0x7fff2b26b000 -     0x7fff2b686fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <86110F21-96FE-325C-8D55-9385690C2386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
        0x7fff2b687000 -     0x7fff2b6cefff  com.apple.OTSVG (1.0 - 677.6.0.2) <34AD6D57-71B8-3859-94AF-DB856D8FD6BA> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
        0x7fff2b6cf000 -     0x7fff2b6d5fff  com.apple.xpc.AppServerSupport (1.0 - 2038.120.1) <AD03039F-3D12-31FE-A497-EC4A87097683> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
        0x7fff2b6d6000 -     0x7fff2b6e8fff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <B4F0CDA6-0332-3AB9-A0FB-8CD6EE316D30> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
        0x7fff2b6e9000 -     0x7fff2b6ebfff  libspindump.dylib (295.2) <8DE7E414-DCEC-30B8-87DC-511D362D49F3> /usr/lib/libspindump.dylib
        0x7fff2b6ec000 -     0x7fff2b7acfff  com.apple.Heimdal (4.0 - 2.0) <30D71BC9-C18F-35C7-B7E1-88E645D4D329> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff2b7ad000 -     0x7fff2b7c7fff  com.apple.login (3.0 - 3.0) <0690C64C-DE8C-3AA2-A4A5-BE3EFC3BDC62> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
        0x7fff2b7c8000 -     0x7fff2b89ffff  com.apple.corebrightness (1.0 - 1) <84C0971C-31BB-3E68-9EC1-0EF05986CEEA> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
        0x7fff2b948000 -     0x7fff2b94bfff  libodfde.dylib (26) <6436E5A0-CEF3-302F-86E7-E28C3EBE7A3A> /usr/lib/libodfde.dylib
        0x7fff2b94c000 -     0x7fff2b988fff  com.apple.bom (14.0 - 235) <E428566D-DFA2-33AC-AF3B-C68530D52522> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff2b989000 -     0x7fff2b9d2fff  com.apple.AppleJPEG (1.0 - 1) <15DCB33B-EB52-38A2-B02F-EC235DC85B52> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
        0x7fff2b9d3000 -     0x7fff2bab2fff  libJP2.dylib (2130.7.3) <20747AB5-CFA0-3C7A-BE41-BF4B54FD2038> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff2bab3000 -     0x7fff2bab6fff  com.apple.WatchdogClient.framework (1.0 - 98.120.2) <0A097C25-405B-38CD-B6E2-57F51AD77AF0> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
        0x7fff2bab7000 -     0x7fff2baedfff  com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <0DF955E2-E57C-3C1B-96BD-5B81DAD43BC7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
        0x7fff2baee000 -     0x7fff2bc4cfff  com.apple.VideoToolbox (1.0 - 2780.10) <4FF9A4C0-FFB4-3F68-9A84-949B4DB0DB7A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff2bc4d000 -     0x7fff2bc80fff  libAudioToolboxUtility.dylib (1181.72) <9D9EA545-924D-342A-BF27-C19887850F05> /usr/lib/libAudioToolboxUtility.dylib
        0x7fff2bc81000 -     0x7fff2bca1fff  libPng.dylib (2130.7.3) <29756FE6-34E9-3760-9B70-9FF6648BE7CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff2bca2000 -     0x7fff2bd01fff  libTIFF.dylib (2130.7.3) <692B9470-8F28-3C98-9C6A-DAE79FE0136F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff2bd02000 -     0x7fff2bd1efff  com.apple.IOPresentment (58 - 37) <A86E6181-E216-3691-A7FF-0264A927C8CC> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
        0x7fff2bd1f000 -     0x7fff2bd26fff  com.apple.GPUWrangler (6.3.5 - 6.3.5) <CC101DAE-349B-3C72-9554-6F569364841E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
        0x7fff2bd27000 -     0x7fff2bd2afff  libRadiance.dylib (2130.7.3) <1A759A2B-28E8-32C4-940D-BE0239558098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff2bd2b000 -     0x7fff2bd30fff  com.apple.DSExternalDisplay (3.1 - 380) <3FD5886F-5EDD-313D-9783-FF899E5F2650> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
        0x7fff2bd31000 -     0x7fff2bd55fff  libJPEG.dylib (2130.7.3) <C0903C97-523A-3822-ABE4-D1047D6785DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff2bd56000 -     0x7fff2bd85fff  com.apple.ATSUI (1.0 - 1) <F9BEFF92-E409-35B6-89CB-0F221D804D3C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
        0x7fff2bd86000 -     0x7fff2bd8afff  libGIF.dylib (2130.7.3) <E92A145C-2B76-39D1-B481-B7C95ACBF989> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff2bd8b000 -     0x7fff2bd94fff  com.apple.CMCaptureCore (1.0 - 82.6) <E0EAD649-4C7A-384E-999B-4D82AA9CDA52> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
        0x7fff2bd95000 -     0x7fff2bddcfff  com.apple.print.framework.PrintCore (16.1 - 531.1) <035969B9-3323-3AF4-AC4C-1D5B941C7C62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff2bddd000 -     0x7fff2beaafff  com.apple.TextureIO (3.10.9 - 3.10.9) <4B778275-5F2D-36DA-A6AD-14C8E516E197> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
        0x7fff2beab000 -     0x7fff2beb3fff  com.apple.InternationalSupport (1.0 - 61.1) <56A6D4F8-FF5B-3F34-BD1A-249414F182E9> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
        0x7fff2beb4000 -     0x7fff2bf2efff  com.apple.datadetectorscore (8.0 - 674) <CDA8DABD-62A3-3E1C-9A76-B00E1E950254> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
        0x7fff2bf2f000 -     0x7fff2bf8cfff  com.apple.UserActivity (439 - 439) <C272F369-1086-317C-A4CF-AE2E1EC4FFB4> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
        0x7fff2bf8d000 -     0x7fff2c729fff  com.apple.MediaToolbox (1.0 - 2780.10) <AFB06F1B-22BA-3DB7-B6E4-3C55F0A4BECF> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff2cb6a000 -     0x7fff2cbd0fff  com.apple.imfoundation (10.0 - 1000) <1D902049-CAD5-3DE0-AE4A-9AACEBB586BE> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
        0x7fff2cbd1000 -     0x7fff2cbf9fff  com.apple.locationsupport (2420.19.23 - 2420.19.23) <9A015D62-2143-3199-AD14-ECA953A728D3> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
        0x7fff2cbfa000 -     0x7fff2cc2bfff  libSessionUtility.dylib (76.69) <400DF595-A30C-3AD3-A8BA-25260299ACE6> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
        0x7fff2cc2c000 -     0x7fff2cd60fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <93226BB9-165F-3A42-8EE3-9670394C4DC9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff2cd61000 -     0x7fff2cdc6fff  com.apple.audio.AudioSession (1.0 - 76.69) <ADC1C8FC-A444-3F15-A396-B4AB688BB326> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
        0x7fff2cdc7000 -     0x7fff2cdd9fff  libAudioStatistics.dylib (27.64) <74E8B615-03FE-327B-A8FB-EAC5EF117414> /usr/lib/libAudioStatistics.dylib
        0x7fff2cdda000 -     0x7fff2cde9fff  com.apple.speech.synthesis.framework (9.0.66 - 9.0.66) <CE36276F-23DD-32A3-9863-D3A5DDE5965E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff2cdea000 -     0x7fff2ce56fff  com.apple.ApplicationServices.ATS (377 - 516) <6E601872-2340-3675-9B6F-0C1DB991C54E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
        0x7fff2ce57000 -     0x7fff2ce6ffff  libresolv.9.dylib (68) <86A4BABF-3EFC-3113-BE8A-2D1AAAEF0194> /usr/lib/libresolv.9.dylib
        0x7fff2ce70000 -     0x7fff2ce83fff  libsasl2.2.dylib (214) <601780A9-26F4-36A4-83EA-864841219797> /usr/lib/libsasl2.2.dylib
        0x7fff2cef0000 -     0x7fff2cf23fff  com.apple.securityinterface (10.0 - 55149.120.1) <10A7DFC1-8C46-382C-AEF0-89B151767F50> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
        0x7fff2cf24000 -     0x7fff2cf3cfff  com.apple.CoreFollowUp-OSX (1.0 - 1) <752290D4-DC17-3A64-BC8C-47D8BF548C7B> /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/CoreFollowUp
        0x7fff2cf3d000 -     0x7fff2cfa1fff  com.apple.CoreMediaIO (1000.0 - 5325) <42F6129C-48E9-316A-9F30-2FA4D96F709F> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
        0x7fff2cfa2000 -     0x7fff2d081fff  libSMC.dylib (20) <CF88A94C-B5EE-306F-96A3-1442BA061C46> /usr/lib/libSMC.dylib
        0x7fff2d082000 -     0x7fff2d0e1fff  libcups.2.dylib (494.3) <2CE9752F-8763-3456-83CF-E4BCFB731153> /usr/lib/libcups.2.dylib
        0x7fff2d0e2000 -     0x7fff2d0f1fff  com.apple.LangAnalysis (1.7.0 - 254) <AB67008E-5986-3974-B986-FDBFAC018CAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff2d0f2000 -     0x7fff2d0fcfff  com.apple.NetAuth (6.2 - 6.2) <B5806BA7-9A6E-37A0-9AB9-6EC2D61844AC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff2d0fd000 -     0x7fff2d104fff  com.apple.ColorSyncLegacy (4.13.0 - 1) <86D9E9C9-C631-371E-824E-A203FE9E560A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
        0x7fff2d105000 -     0x7fff2d110fff  com.apple.QD (4.0 - 416) <1D8792FC-4A76-3B4F-82CF-3889C05768FE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
        0x7fff2d111000 -     0x7fff2d765fff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <C97CD66B-8267-3C39-B025-789864237928> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
        0x7fff2d766000 -     0x7fff2d771fff  com.apple.perfdata (1.0 - 67.40.1) <10E2B0C5-83A4-368A-B972-7AFA40D5338C> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
        0x7fff2d772000 -     0x7fff2d780fff  libperfcheck.dylib (41) <A2D0E1A8-A98F-3DAA-B9FC-C033FC4CD9E0> /usr/lib/libperfcheck.dylib
        0x7fff2d781000 -     0x7fff2d790fff  com.apple.Kerberos (3.0 - 1) <0074E20F-E7D8-31F5-AF41-0D7BF370CD50> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff2d791000 -     0x7fff2d7e1fff  com.apple.GSS (4.0 - 2.0) <D546E52C-295F-3CCD-9925-03632FE72ECB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff2d7e2000 -     0x7fff2d7f2fff  com.apple.CommonAuth (4.0 - 2.0) <DF20551B-1514-39B3-A52E-681A2E5F0D1C> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff2d7f3000 -     0x7fff2d81afff  com.apple.MobileAssets (1.0 - 659.100.21) <14EB0135-6B08-37A0-A517-E23997BAD7D5> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
        0x7fff2d81b000 -     0x7fff2d847fff  com.apple.CacheDelete (1.0 - 1) <FB1E1322-C50B-38DD-86CE-9AEC925628A3> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
        0x7fff2d848000 -     0x7fff2d867fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <C48DA26A-6A69-3497-B94D-43332354162B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
        0x7fff2d868000 -     0x7fff2d870fff  com.apple.CorePhoneNumbers (1.0 - 1) <9F49D632-C5F4-37F5-A2A8-2830A7560138> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
        0x7fff2d871000 -     0x7fff2d8fafff  libTelephonyUtilDynamic.dylib (5359.1) <DDF9B2A1-D071-3180-9BC6-A143D6D9E713> /usr/lib/libTelephonyUtilDynamic.dylib
        0x7fff2d9c3000 -     0x7fff2d9c3fff  liblaunch.dylib (2038.120.1) <4A353070-A560-3A98-8869-28C92435C6B2> /usr/lib/system/liblaunch.dylib
        0x7fff2dcbc000 -     0x7fff2df47fff  com.apple.NetworkExtension (1.0 - 1) <727B66BE-EED5-324A-8FDC-14E91844B92E> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
        0x7fff2df48000 -     0x7fff2e049fff  com.apple.ids (10.0 - 1000) <F30AC7B8-FACA-3B37-914D-C7AFA47A9DAE> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
        0x7fff2e04a000 -     0x7fff2e1a4fff  com.apple.idsfoundation (10.0 - 1000) <3EAAA079-B3EE-3A12-B181-3267029FB4B0> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
        0x7fff2e1a5000 -     0x7fff2e2f0fff  com.apple.Sharing (1630 - 1630) <CE657A48-7BDD-34D7-9CBC-B1D6AD94B2B2> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
        0x7fff2e2f1000 -     0x7fff2e412fff  com.apple.Bluetooth (8.0.5 - 8.0.5d7) <D011494A-287B-3487-B817-2329843C2486> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
        0x7fff2e413000 -     0x7fff2e427fff  com.apple.AppContainer (4.0 - 509.140.3) <85EE3606-0190-3428-9C49-D32A01706439> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
        0x7fff2e428000 -     0x7fff2e42bfff  com.apple.SecCodeWrapper (4.0 - 509.140.3) <1BB9A761-4DE0-34AF-87A6-CB5BF9322F62> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
        0x7fff2e42c000 -     0x7fff2e485fff  com.apple.ProtectedCloudStorage (1.0 - 1) <EA0958A6-8296-3E23-81BE-297473A6E17E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
        0x7fff2e486000 -     0x7fff2e4e5fff  com.apple.QuickLookFramework (5.0 - 928.4) <C7DA2119-94CA-320B-9FBE-9AB4F9F384DA> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff2e4e6000 -     0x7fff2e501fff  com.apple.MetalKit (147.1 - 147.1) <F9EF05E2-2410-30A4-B9E0-8E19621D3434> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
        0x7fff2e6e5000 -     0x7fff2fbe0fff  com.apple.GeoServices (1.0 - 1757.26.6.2.2) <1A271F08-3D05-36BF-A136-7D48B4418CD6> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
        0x7fff2fbe1000 -     0x7fff2fbecfff  com.apple.DirectoryService.Framework (11.6 - 230.40.1) <A0B99619-47BD-3D1C-8CAA-EE25139753F6> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
        0x7fff2fbed000 -     0x7fff2fc14fff  com.apple.RemoteViewServices (2.0 - 163) <7DBF2A51-CE8E-352E-9426-B83DC370ADDD> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
        0x7fff2fc15000 -     0x7fff2fc24fff  com.apple.SpeechRecognitionCore (6.1.25 - 6.1.25) <076E6A5F-4FEE-378B-9DCD-AFFA1348C64F> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
        0x7fff2fc25000 -     0x7fff2fc2cfff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <DB80BAB9-5E83-32DB-A424-05BB19044665> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
        0x7fff2fc2d000 -     0x7fff2fc3dfff  com.apple.AppleLDAP (11.6 - 54) <1195DAE2-7082-32B1-B45A-ABE4B9A75D28> /System/Library/PrivateFrameworks/AppleLDAP.framework/Versions/A/AppleLDAP
        0x7fff2fe5a000 -     0x7fff2fe5afff  libsystem_product_info_filter.dylib (8.40.1) <78928329-DD98-3799-989D-870DF92FE8D5> /usr/lib/system/libsystem_product_info_filter.dylib
        0x7fff2fed2000 -     0x7fff2fee9fff  libnetworkextension.dylib (1295.140.3) <70743C15-3A7D-308C-9238-7E20FBF73199> /usr/lib/libnetworkextension.dylib
        0x7fff2ff32000 -     0x7fff2ff32fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <CDB56324-715E-3223-903F-EEC1D4E57F14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff2ff58000 -     0x7fff2ff58fff  com.apple.CoreServices (1122.44 - 1122.44) <104E1757-7D8A-32D3-9B38-B23B1A8EAB17> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff30114000 -     0x7fff30114fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <28463942-495F-3231-9348-32ABC601A1F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff30155000 -     0x7fff30160fff  com.apple.MediaAccessibility (1.0 - 130) <677557AF-6AC1-3860-B7C4-772B8DA9957B> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
        0x7fff30161000 -     0x7fff30180fff  com.apple.networking.AlgosScoreFramework (1.0 - 1) <BFF296BB-6E78-3213-B453-31AA58FC13E0> /System/Library/PrivateFrameworks/AlgosScoreFramework.framework/Versions/A/AlgosScoreFramework
        0x7fff30181000 -     0x7fff30185fff  com.apple.AppleSRP (5.0 - 1) <A8B167C6-9E49-3ED9-AD87-36BEA98F6E20> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
        0x7fff30186000 -     0x7fff30191fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <6873367E-2879-3C96-A766-AD6DFD69F36A> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
        0x7fff30192000 -     0x7fff301c9fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <84CB0B6A-46C1-3A8E-81D4-CC44DF0AFF83> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
        0x7fff301ca000 -     0x7fff304a2fff  com.apple.VN (4.3.1 - 4.3.1) <0856C3F0-BF95-30DB-BFFC-BE4ABFDA04B7> /System/Library/Frameworks/Vision.framework/Versions/A/Vision
        0x7fff305fc000 -     0x7fff3067ffff  com.apple.AddressBook.ContactsFoundation (8.0 - 1151.2) <BEBEC756-57B8-3DBA-B0B8-5B9197ECC5A3> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
        0x7fff30680000 -     0x7fff306c2fff  com.apple.contacts.ContactsPersistence (1.0 - 3497.5) <DEE423F8-36EB-3E69-9680-E93FA6F8F241> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
        0x7fff306c3000 -     0x7fff307f9fff  com.apple.AddressBook.core (1.0 - 2452.7) <721D6700-131B-323E-9FE9-4AAEBECDA243> /System/Library/PrivateFrameworks/AddressBookCore.framework/Versions/A/AddressBookCore
        0x7fff307fa000 -     0x7fff3092efff  com.apple.contacts (1.0 - 3497.5) <73891206-8D41-3206-A10B-118B90EB4C86> /System/Library/Frameworks/Contacts.framework/Versions/A/Contacts
        0x7fff3092f000 -     0x7fff3093cfff  com.apple.PersonaKit (1.0 - 1) <B8FE29A2-D6A5-3AE0-BC97-1AA21755455A> /System/Library/PrivateFrameworks/PersonaKit.framework/Versions/A/PersonaKit
        0x7fff30942000 -     0x7fff30955fff  com.apple.FamilyCircle (1.0 - 113.0.0.10) <32DE900C-77C7-325C-B487-67D46CEEEA19> /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle
        0x7fff30956000 -     0x7fff309bbfff  com.apple.CoreBluetooth (1.0 - 1) <32288DE3-BD59-35A6-9165-73176E074499> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
        0x7fff309bc000 -     0x7fff309c5fff  com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <9A1589E7-0B3A-3DC5-967C-7A3D4C14ED1E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
        0x7fff309c6000 -     0x7fff309d8fff  com.apple.PowerLog (1.0 - 1) <7A3E3B4D-5DA4-3D01-9188-4FE8A6859D15> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
        0x7fff309d9000 -     0x7fff309e5fff  com.apple.AppleIDAuthSupport (1.0 - 1) <C391F5AD-7903-31AF-8608-7826C0EFB3C5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
        0x7fff309e6000 -     0x7fff30a8efff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <08A9AAA6-7057-3105-BDE1-DC7270C38774> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
        0x7fff30a8f000 -     0x7fff30ac2fff  com.apple.MediaKit (16 - 927.40.2) <86B948D3-5757-37A7-B2DA-F7C50778B108> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
        0x7fff30ac3000 -     0x7fff30baefff  com.apple.DiskManagement (14.0 - 1733.140.2) <CF6680B9-9799-3DE8-A600-094260672A4F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
        0x7fff30baf000 -     0x7fff30f69fff  com.apple.CoreAUC (326.2.0 - 326.2.0) <58430C09-401A-3B4C-806E-E87C46816939> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff30f6a000 -     0x7fff30f6dfff  com.apple.Mangrove (1.0 - 25) <0E9FF438-D4B3-3DF1-B8A7-64623282B9B3> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
        0x7fff30f6e000 -     0x7fff30f9bfff  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <80DEBCCB-A598-3CE5-B988-FFC5B81389CF> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
        0x7fff30f9c000 -     0x7fff310ebfff  com.apple.FileProvider (349.4.3 - 349.4.3) <E07C8909-299C-3696-BD84-5CF42EE64EE4> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
        0x7fff310ec000 -     0x7fff3110efff  com.apple.GenerationalStorage (2.0 - 323) <9E36AF92-10E2-382B-A07C-4E3270448690> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
        0x7fff31484000 -     0x7fff31552fff  com.apple.CoreTelephony (113 - 8260) <DFBE4145-7D80-3F7B-8C37-746D9D63DAC6> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
        0x7fff31553000 -     0x7fff31560fff  com.apple.AppSandbox (4.0 - 509.140.3) <FFB8B6E5-AC15-30EF-81A6-DB88ED9772C5> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
        0x7fff31577000 -     0x7fff3170bfff  com.apple.AVFCore (1.0 - 2020.10) <85D55F46-61B4-3A08-8B13-1A678B571D66> /System/Library/PrivateFrameworks/AVFCore.framework/Versions/A/AVFCore
        0x7fff3170c000 -     0x7fff3177bfff  com.apple.FrontBoardServices (703.16 - 703.16) <5088E177-3DF7-3F48-B340-7E6FF569C1E2> /System/Library/PrivateFrameworks/FrontBoardServices.framework/Versions/A/FrontBoardServices
        0x7fff3177c000 -     0x7fff317a5fff  com.apple.BoardServices (1.0 - 526) <9932480F-CA31-362C-B5BB-263998D63224> /System/Library/PrivateFrameworks/BoardServices.framework/Versions/A/BoardServices
        0x7fff317a6000 -     0x7fff317d1fff  com.apple.contacts.vCard (1.0 - 3497.5) <34200FAE-9D85-396E-95E1-BD7341334EBB> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
        0x7fff317e7000 -     0x7fff31802fff  com.apple.ExtensionKit (19.4 - 19.4) <D5A2BF7D-F72D-30D4-A12C-2B23A25C53FF> /System/Library/PrivateFrameworks/ExtensionKit.framework/Versions/A/ExtensionKit
        0x7fff31803000 -     0x7fff31809fff  com.apple.ExtensionFoundation (19.4 - 19.4) <911C2C6B-8D5E-301E-8845-ABE770077044> /System/Library/PrivateFrameworks/ExtensionFoundation.framework/Versions/A/ExtensionFoundation
        0x7fff3180a000 -     0x7fff3184ffff  com.apple.CryptoTokenKit (1.0 - 1) <85356F88-7E90-357C-A0CE-B580616C1CEF> /System/Library/Frameworks/CryptoTokenKit.framework/Versions/A/CryptoTokenKit
        0x7fff31850000 -     0x7fff31866fff  com.apple.LocalAuthentication (1.0 - 827.140.1) <D833E8C1-2038-3C12-9EEC-30D8F9F48702> /System/Library/Frameworks/LocalAuthentication.framework/Versions/A/LocalAuthentication
        0x7fff31867000 -     0x7fff31894fff  com.apple.CoreAuthentication.SharedUtils (1.0 - 827.140.1) <DCB4A9AE-4CE3-302E-8633-4F54DE1C1050> /System/Library/Frameworks/LocalAuthentication.framework/Support/SharedUtils.framework/Versions/A/SharedUtils
        0x7fff31909000 -     0x7fff3194afff  com.apple.CoreHaptics (1.0 - 1) <8B6CA9A4-26B2-31AD-A763-F905F126900D> /System/Library/Frameworks/CoreHaptics.framework/Versions/A/CoreHaptics
        0x7fff31958000 -     0x7fff31997fff  com.apple.AppleVPAFramework (3.26.1 - 3.26.1) <B7DF9782-C63B-32F0-A008-E83503C76E78> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
        0x7fff31a4a000 -     0x7fff31a85fff  com.apple.DebugSymbols (195.1 - 195.1) <7D2E32A0-DB93-36EE-AE9C-7974708CF4FC> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff31a86000 -     0x7fff31b3bfff  com.apple.CoreSymbolication (12.5 - 64544.81.1) <7215543C-E3B6-30A0-8B21-7FBDFB10F198> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
        0x7fff31b3c000 -     0x7fff31b45fff  com.apple.CoreTime (284.0.4) <DAEEF1D8-1C34-37AC-9691-C4540C92E9F9> /System/Library/PrivateFrameworks/CoreTime.framework/Versions/A/CoreTime
        0x7fff31b46000 -     0x7fff31bbbfff  com.apple.Rapport (2.6.0 - 260.3) <55CA4269-E06C-3E4E-BB3D-957469333D9C> /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
        0x7fff32490000 -     0x7fff324dcfff  com.apple.coreduetcontext (1.0 - 1) <F343EE71-43B3-366E-A3C3-7FC0DD79D70F> /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
        0x7fff324dd000 -     0x7fff32a49fff  com.apple.Intents (1.0 - 1) <CA14EA98-180D-3AEC-9900-8B6BE616DA5C> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
        0x7fff32a4a000 -     0x7fff32aadfff  com.apple.framework.Apple80211 (17.0 - 1728) <D89EA57A-D351-3BD1-A470-505C6D8BF4D6> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff32aae000 -     0x7fff32bfffff  com.apple.CoreWiFi (3.0 - 341) <0FE4018E-E199-3923-A56D-430E40F5EEB7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff32c00000 -     0x7fff32c1afff  com.apple.BackBoardServices (1.0 - 1.0) <C21E697A-AB8B-3353-9B92-7DB6C09DE34D> /System/Library/PrivateFrameworks/BackBoardServices.framework/Versions/A/BackBoardServices
        0x7fff32c1b000 -     0x7fff32c52fff  com.apple.LDAPFramework (2.4.28 - 194.5) <327E5362-4AA3-3610-B126-CAC243121EA8> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff32c53000 -     0x7fff32c54fff  com.apple.TrustEvaluationAgent (2.0 - 35) <CA7542A0-0CE3-39E9-9FF0-F827CC4633AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
        0x7fff32c55000 -     0x7fff32d5afff  libcrypto.44.dylib (56.60.2) <90125B07-6FE0-3D39-947D-0C39B9DF6C43> /usr/lib/libcrypto.44.dylib
        0x7fff32d5b000 -     0x7fff32d88fff  libssl.46.dylib (56.60.2) <53F0CF92-264C-3210-852F-B2B65885E675> /usr/lib/libssl.46.dylib
        0x7fff32d89000 -     0x7fff32e38fff  com.apple.DiskImagesFramework (595.140.1 - 595.140.1) <6A804C50-8819-39A1-AF4E-4E71C6BD8DAB> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
        0x7fff32e39000 -     0x7fff32e6ffff  com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <FE03407F-3251-30BD-AA64-8DE2940C0F57> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
        0x7fff32e70000 -     0x7fff32e7ffff  com.apple.RemoteServiceDiscovery (1.0 - 1.120.1) <8F0CFA90-78B8-3305-BCD3-6C28B7838CE0> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
        0x7fff32e98000 -     0x7fff32edcfff  com.apple.DataDetectorsNaturalLanguage (1.0 - 159.1) <234D2A46-5B69-3B18-8D45-6DD1F4293C73> /System/Library/PrivateFrameworks/DataDetectorsNaturalLanguage.framework/Versions/A/DataDetectorsNaturalLanguage
        0x7fff32edd000 -     0x7fff32ee0fff  com.apple.help (1.3.8 - 71) <CF14979A-CA27-32D1-A3E8-D99AD6C91464> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
        0x7fff32ee1000 -     0x7fff32ee8fff  com.apple.EFILogin (2.0 - 2) <77A5D3D5-3B8D-3B5D-A1BD-A7614C86AF67> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
        0x7fff32ee9000 -     0x7fff32ef4fff  libcsfde.dylib (554.140.2) <8B6A31B3-9421-3BAE-882B-8BEF5217E251> /usr/lib/libcsfde.dylib
        0x7fff32ef5000 -     0x7fff32f5bfff  libcurl.4.dylib (121.101.1) <8ACEDAF2-5907-3F4A-9595-F52681D0F470> /usr/lib/libcurl.4.dylib
        0x7fff32f5c000 -     0x7fff32f63fff  com.apple.LoginUICore (4.0 - 4.0) <F8CF5AD4-6A49-3EFC-B1FA-BD83B0095CBB> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
        0x7fff32f64000 -     0x7fff32fc6fff  com.apple.AppSupport (1.0.0 - 29) <7F288248-AB86-3AAC-9528-1A62E0E77528> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
        0x7fff33066000 -     0x7fff3312afff  com.apple.GameController (1.0 - 1) <68352436-3E7E-30BE-B804-E8EDE0658BB3> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
        0x7fff33133000 -     0x7fff33133fff  com.apple.ApplicationServices (48 - 50) <52BB5EB6-2C1B-34F9-8665-F50DD078E71B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff33134000 -     0x7fff33136fff  com.apple.InternationalTextSearch (1.0 - 1) <B6F39BE2-4D42-38BD-B8DD-53F4B7E9DA38> /System/Library/PrivateFrameworks/InternationalTextSearch.framework/Versions/A/InternationalTextSearch
        0x7fff33137000 -     0x7fff331affff  com.apple.ClassKit (1.2 - 146.6) <54D86FD1-568D-327F-82CA-B47A16E4CE80> /System/Library/Frameworks/ClassKit.framework/Versions/A/ClassKit
        0x7fff331b0000 -     0x7fff332f4fff  com.apple.AppleAccount (1.0 - 1.0) <B304AA07-C970-3195-B4BE-978E3CA2856F> /System/Library/PrivateFrameworks/AppleAccount.framework/Versions/A/AppleAccount
        0x7fff332f5000 -     0x7fff33334fff  com.apple.AppleIDSSOAuthentication (1.0 - 1) <AB9B31C6-653B-38AF-852A-10FB097BA818> /System/Library/PrivateFrameworks/AppleIDSSOAuthentication.framework/Versions/A/AppleIDSSOAuthentication
        0x7fff33335000 -     0x7fff3338cfff  com.apple.CorePrediction (1.0 - 1) <0858EE22-68F8-31C9-88A2-B94D225CEE9E> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
        0x7fff33448000 -     0x7fff33448fff  libHeimdalProxy.dylib (79) <A1B83B1E-006D-38A8-8878-FD6ECBBB9B1B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
        0x7fff334fb000 -     0x7fff334fbfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <0A5BB3A7-D9DC-346C-9FBB-FB075194E7AC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff3351f000 -     0x7fff33562fff  com.apple.StreamingZip (1.0 - 1) <DDE31BAA-F317-3EA3-AF44-7B05CDB95217> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
        0x7fff33563000 -     0x7fff33581fff  com.apple.DuetActivityScheduler (1.0 - 1) <AEA67F50-E42E-37A5-BF75-6666CD80C19C> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
        0x7fff33596000 -     0x7fff335a2fff  com.apple.IntentsFoundation (1.0 - 1) <90F93D25-8C0E-37FF-A480-0CC95E080E7C> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
        0x7fff335a3000 -     0x7fff335a8fff  com.apple.PushKit (1.0 - 1) <02EC6449-963F-376C-BE24-F9CC8083ABD3> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
        0x7fff335a9000 -     0x7fff335dcfff  com.apple.C2 (1.3 - 573) <1D8BCCDC-EFB0-3DF8-93A4-4D18388D7C11> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
        0x7fff335dd000 -     0x7fff3360dfff  com.apple.QuickLookThumbnailing (1.0 - 135.5) <7B9EC715-B18C-3194-B78C-24358F1BEEFE> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
        0x7fff3360e000 -     0x7fff33e0ffff  com.apple.vision.EspressoFramework (1.0 - 256.4.4) <46EB212E-0528-3D15-AAA4-207E8B197A75> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
        0x7fff33e10000 -     0x7fff33e27fff  com.apple.ANEServices (4.76 - 4.76) <E54FB6F5-CBF8-3ED2-A73B-47C6D87910A4> /System/Library/PrivateFrameworks/ANEServices.framework/Versions/A/ANEServices
        0x7fff33e28000 -     0x7fff33e8dfff  com.apple.proactive.support.ProactiveSupport (1.0 - 294.7) <3496B6A3-168D-3278-AFB1-14363A6FB4F6> /System/Library/PrivateFrameworks/ProactiveSupport.framework/Versions/A/ProactiveSupport
        0x7fff33e8e000 -     0x7fff33e98fff  com.apple.corerecents (1.0 - 1) <D8991907-F2CC-36AB-B5C6-769A08B4667F> /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/CoreRecents
        0x7fff33e99000 -     0x7fff33ecafff  com.apple.iCalendar (7.0 - 833) <632255EA-705A-3C44-80C2-1727D418745B> /System/Library/PrivateFrameworks/iCalendar.framework/Versions/A/iCalendar
        0x7fff33ecb000 -     0x7fff33f3bfff  com.apple.CalendarFoundation (8.0 - 1178.5.2) <2BE0FB9D-963E-3DC6-A60F-8A753EDB453A> /System/Library/PrivateFrameworks/CalendarFoundation.framework/Versions/A/CalendarFoundation
        0x7fff33f3c000 -     0x7fff33f3efff  com.apple.CoreDuetDebugLogging (1.0 - 1) <47F03D98-3BF5-3CAB-B83D-A30A59A5B068> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
        0x7fff33f3f000 -     0x7fff33f4bfff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <B6BADDAF-0F79-30B6-8CD4-83C8ACDB12D0> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
        0x7fff341df000 -     0x7fff344b2fff  com.apple.spotlight.index (10.7.0 - 2150.26) <D8CB9D18-8903-3E9F-A502-5896DC545BA5> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
        0x7fff344cb000 -     0x7fff3451bfff  com.apple.ChunkingLibrary (334.1 - 334.1) <2CD91198-1354-357F-8858-D58244526C15> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff34652000 -     0x7fff346a1fff  com.apple.CalDAV (8.0 - 795) <C0EAF392-62F0-382C-B832-96DBC6724472> /System/Library/PrivateFrameworks/CalDAV.framework/Versions/A/CalDAV
        0x7fff346a2000 -     0x7fff3473ffff  com.apple.CoreSuggestions (1.0 - 1115.519) <D781EA13-4252-334F-ADCC-F81AF8E6F2DE> /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/CoreSuggestions
        0x7fff34740000 -     0x7fff348cafff  com.apple.ical.EventKit (3.0 - 1414.5.1) <33EAD078-D1DC-3315-BB80-AE77EE7F52AF> /System/Library/Frameworks/EventKit.framework/Versions/A/EventKit
        0x7fff348cb000 -     0x7fff34b9cfff  com.apple.CalendarPersistence (8.0 - 1071.4.4) <0E5E778E-57BD-3D7C-B875-3AA044100A0F> /System/Library/PrivateFrameworks/CalendarPersistence.framework/Versions/A/CalendarPersistence
        0x7fff34b9d000 -     0x7fff34bc2fff  com.apple.CalendarAgentLink (8.0 - 250) <94D45C00-DDD4-3D08-94A7-5202003B1BAE> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
        0x7fff34bc3000 -     0x7fff34bcdfff  com.apple.RTCReporting (11.85.2 - 11.85.2) <4C416B6E-005D-3A43-BCB4-FCA93F149D74> /System/Library/PrivateFrameworks/RTCReporting.framework/Versions/A/RTCReporting
        0x7fff34bce000 -     0x7fff34d74fff  com.apple.WebKitLegacy (16611 - 16611.3.10.1.6) <D06037B8-003A-36DA-992F-62B478338C33> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
        0x7fff34d8f000 -     0x7fff34da4fff  com.apple.CoreML.AppleNeuralEngine (1.0 - 1) <C3AA92B0-9BF9-3806-A952-2A318AF1EEE4> /System/Library/PrivateFrameworks/AppleNeuralEngine.framework/Versions/A/AppleNeuralEngine
        0x7fff34dfa000 -     0x7fff34e65fff  com.apple.audio.midi.CoreMIDI (2.0 - 88) <741CCF53-3F51-39A5-B07A-3C14BED77D44> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
        0x7fff34e66000 -     0x7fff34e8ffff  com.apple.QTKit (1.0 - 5) <57142B0A-6D02-373B-9335-68AE3209BB4C> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff34f2b000 -     0x7fff34f2efff  com.apple.Cocoa (6.11 - 23) <237F7F6E-E7D1-363A-92AF-32B564728891> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff34f78000 -     0x7fff3536cfff  com.apple.AppleMediaServices (1.0 - 1) <0EBC0F6F-3763-3E66-A92C-CCA9453326FE> /System/Library/PrivateFrameworks/AppleMediaServices.framework/Versions/A/AppleMediaServices
        0x7fff353a4000 -     0x7fff3581cfff  com.apple.MediaRemote (1.0 - 1) <DEF1BED2-78C1-318C-8DB5-FD464941D48B> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
        0x7fff35b18000 -     0x7fff35b1ffff  com.apple.DisplayServicesFW (3.1 - 380) <F794066C-55D0-3CC6-9BCD-C27207746B97> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
        0x7fff36059000 -     0x7fff362edfff  libAWDSupportFramework.dylib (4205) <879C09AE-5344-3B02-A93F-8B3C46B39F17> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
        0x7fff36361000 -     0x7fff36391fff  libtidy.A.dylib (18.2) <1AF8A622-91F8-3193-BA3D-CB1A799565A8> /usr/lib/libtidy.A.dylib
        0x7fff36392000 -     0x7fff363b2fff  com.apple.MarkupUI (1.0 - 383.6) <7396A399-E8CE-31B6-8F56-CCCA5BF72669> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
        0x7fff363b3000 -     0x7fff363c6fff  com.apple.Engram (1.0 - 1) <AED2FFE9-3841-33B1-B552-A75B17A20A3A> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
        0x7fff363c7000 -     0x7fff363eafff  com.apple.openscripting (1.7 - 190) <A2516A00-ECC2-31F2-9157-90AF9A4C6F56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
        0x7fff363eb000 -     0x7fff363eefff  com.apple.securityhi (9.0 - 55008) <DDAD2F6D-2105-370E-9C96-63ABF95ABF00> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
        0x7fff363ef000 -     0x7fff363f2fff  com.apple.ink.framework (10.15 - 227) <6177BDED-F304-3EAD-B72E-23A050856753> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
        0x7fff363f3000 -     0x7fff363f6fff  com.apple.CommonPanels (1.2.6 - 101) <E6BB8219-34DB-3A11-A3C2-B17AD8E42414> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
        0x7fff363f7000 -     0x7fff363fefff  com.apple.ImageCapture (1711.5.2 - 1711.5.2) <E3871995-745C-35A8-8B48-647DAAF046E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
        0x7fff363ff000 -     0x7fff375effff  com.apple.JavaScriptCore (16611 - 16611.3.10.1.6) <E1A54760-8F75-3A78-89F7-232D9EC162E8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff3765b000 -     0x7fff3776dfff  com.apple.AVFCapture (1.0 - 82.6) <FA7F06F5-9F18-3DF3-BB00-EA019050812E> /System/Library/PrivateFrameworks/AVFCapture.framework/Versions/A/AVFCapture
        0x7fff3776e000 -     0x7fff37801fff  com.apple.Quagga (47 - 47) <A2CD23BB-59D9-31ED-B980-4CF5379CABDE> /System/Library/PrivateFrameworks/Quagga.framework/Versions/A/Quagga
        0x7fff37802000 -     0x7fff37a4cfff  com.apple.CMCapture (1.0 - 82.6) <DC0EAADD-A8F6-3ECE-8D10-354103DB7767> /System/Library/PrivateFrameworks/CMCapture.framework/Versions/A/CMCapture
        0x7fff37de8000 -     0x7fff37e95fff  com.apple.accounts.AccountsDaemon (113 - 113) <9D7CA3D9-01C2-3D59-9CC7-A37C63C18666> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
        0x7fff37e96000 -     0x7fff37e98fff  com.apple.OAuth (25 - 25) <44E3A1F3-08A5-36CB-BB3E-BB1A9BFDCD68> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
        0x7fff38448000 -     0x7fff38457fff  com.apple.HID (1.0 - 1) <2078CFB6-A410-3B7E-B012-AE2BF1A80887> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
        0x7fff38458000 -     0x7fff3857ffff  com.apple.QuickLookUIFramework (5.0 - 928.4) <6B0E42FA-C3F3-39CB-A7D0-D1172470B640> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
        0x7fff38952000 -     0x7fff389d8fff  com.apple.coredav (1.0.1 - 889) <1B9354FB-A21B-3DC3-B522-6EFC899BBC50> /System/Library/PrivateFrameworks/CoreDAV.framework/Versions/A/CoreDAV
        0x7fff389d9000 -     0x7fff38a2ffff  com.apple.ExchangeWebServices (8.0 - 814.100.1) <01A2D090-AB94-34BF-98E8-1B142DD7EB20> /System/Library/PrivateFrameworks/ExchangeWebServices.framework/Versions/A/ExchangeWebServices
        0x7fff38a30000 -     0x7fff38a70fff  com.apple.MediaServices (1.0 - 1) <F226324E-830D-38BE-A1ED-0EC6A2ED82BB> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
        0x7fff38b6c000 -     0x7fff38b6cfff  com.apple.marco (10.0 - 1000) <6E3E4EC3-3DD4-332D-8D0F-DC0F946269CB> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
        0x7fff38c3f000 -     0x7fff38cadfff  com.apple.Contacts.ContactsUICore (1.0 - 3419.1) <6D0C2E83-AB20-39DF-AA5F-C50AA3966435> /System/Library/PrivateFrameworks/ContactsUICore.framework/Versions/A/ContactsUICore
        0x7fff38d52000 -     0x7fff38d8afff  com.apple.contacts.ContactsAutocomplete (1.0 - 1152.4) <2A0FB524-152A-3539-8613-C04652BC54E0> /System/Library/PrivateFrameworks/ContactsAutocomplete.framework/Versions/A/ContactsAutocomplete
        0x7fff38d8b000 -     0x7fff38d97fff  com.apple.KerberosHelper (4.0 - 1.0) <1C287C65-8440-347F-A77A-E6D51262975D> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
        0x7fff38d98000 -     0x7fff38ddbfff  com.apple.ResponseKit (1.0 - 165.2) <21CE7F8C-F282-3788-80D3-28202C803AC8> /System/Library/PrivateFrameworks/ResponseKit.framework/Versions/A/ResponseKit
        0x7fff38ddc000 -     0x7fff38dfbfff  com.apple.proactive.support.ProactiveEventTracker (1.0 - 294.7) <7AC67187-F443-35EB-B4FF-B59F32DF3D3F> /System/Library/PrivateFrameworks/ProactiveEventTracker.framework/Versions/A/ProactiveEventTracker
        0x7fff3921f000 -     0x7fff3921ffff  com.apple.PhoneNumbers (1.0 - 1) <79C9AAE1-5FEC-3471-8E9D-D39881EDDB19> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
        0x7fff39220000 -     0x7fff39227fff  com.apple.URLFormatting (146 - 146.22) <05567C81-E57E-3201-8DB5-9DC03762E7E7> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
        0x7fff39228000 -     0x7fff39236fff  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <FF5E6B22-0BE8-36A1-90CB-44087715CCCB> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
        0x7fff39237000 -     0x7fff3924efff  libAccessibility.dylib (2885.49) <0F94A4D4-E4D0-3968-95AF-9A123C5A699E> /usr/lib/libAccessibility.dylib
        0x7fff3924f000 -     0x7fff3b999fff  com.apple.WebCore (16611 - 16611.3.10.1.6) <20CBDB85-8A66-3999-9C7C-45403F05958D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
        0x7fff3ba66000 -     0x7fff3ba75fff  com.apple.NetFS (6.0 - 4.0) <D628804B-CDCB-3093-A91C-58B0201B5AF1> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff3bc89000 -     0x7fff3bcabfff  com.apple.quicklook.QuickLookSupport (1.0 - 135.5) <CB82EDC5-2A69-3F7D-9A79-C4B186D6F807> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
        0x7fff3bcac000 -     0x7fff3bd43fff  com.apple.AirPlaySync (1.0 - 2780.10) <FE97137A-017E-392F-9457-1FF0ACB82681> /System/Library/PrivateFrameworks/AirPlaySync.framework/Versions/A/AirPlaySync
        0x7fff3bf73000 -     0x7fff3bf76fff  com.apple.ExceptionHandling (1.5 - 14) <2EBF4791-A234-3CE8-A17E-FD1818C2FDDB> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
        0x7fff3bf77000 -     0x7fff3bfc5fff  com.apple.Safari.SafeBrowsing (16611 - 16611.3.10.1.6) <5513EB53-B539-3D8D-801D-E64175D3A03C> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
        0x7fff3bfc6000 -     0x7fff3c7a5fff  com.apple.WebKit (16611 - 16611.3.10.1.6) <C2B252E6-5870-3B58-B918-03F8307F0729> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
        0x7fff3c8d4000 -     0x7fff3c957fff  com.apple.CorePDF (4.0 - 529) <C37DD615-4ABA-314C-985B-7E496184B997> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
        0x7fff3c958000 -     0x7fff3c95bfff  com.apple.print.framework.Print (15 - 271) <29E7EB03-0307-35D9-B56F-B9DCB5C5A4E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
        0x7fff3c95c000 -     0x7fff3c95ffff  com.apple.Carbon (160 - 164) <B86E3835-F4BE-3DCA-88C7-CEA01227DF58> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff3ca58000 -     0x7fff3ca58fff  com.apple.avfoundation (2.0 - 2020.10) <DF72C9C0-236F-326C-84C1-E4F25163310D> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
        0x7fff3cc12000 -     0x7fff3cc31fff  com.apple.private.SystemPolicy (1.0 - 1) <8BC55621-1E45-33B3-BCD6-C59F1F390695> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
        0x7fff3cdd5000 -     0x7fff3cdf2fff  com.apple.sidecar-core (1.0 - 231) <D0C9A506-6BF0-3D13-9D10-489BF305CB79> /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
        0x7fff3cdf3000 -     0x7fff3cdf6fff  com.apple.QuickLookNonBaseSystem (1.0 - 1) <6E5DDB55-9CD1-3245-939E-EA4081430444> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
        0x7fff3d209000 -     0x7fff3d20dfff  com.apple.CoreOptimization (1.0 - 1) <65BA73C7-2DEA-3AA9-B59D-750B505B54EA> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
        0x7fff3d20e000 -     0x7fff3d214fff  com.apple.FeatureFlagsSupport (1.0 - 28.60.1) <17CAEB39-7966-34B7-9E1B-55D64289BFAF> /System/Library/PrivateFrameworks/FeatureFlagsSupport.framework/Versions/A/FeatureFlagsSupport
        0x7fff3d385000 -     0x7fff3d39cfff  com.apple.SafariServices.framework (16611 - 16611.3.10.1.6) <4AC4AD2E-B214-3244-B148-200EFBCE6884> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
        0x7fff3d54f000 -     0x7fff3d55afff  com.apple.MallocStackLogging (1.0 - 1) <DF41452E-DA3E-3F74-9354-6F82BE363DB8> /System/Library/PrivateFrameworks/MallocStackLogging.framework/Versions/A/MallocStackLogging
        0x7fff3d56f000 -     0x7fff3d581fff  libmis.dylib (274.140.2) <570E2D9A-BC76-37F7-8CFC-E18AD5E81CE0> /usr/lib/libmis.dylib
        0x7fff3d59e000 -     0x7fff3d70dfff  com.apple.CoreHandwriting (161 - 1.2) <DF7F9BC6-ACE1-32CE-9E1E-5642832E10E9> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
        0x7fff3d70e000 -     0x7fff3d969fff  com.apple.imageKit (3.0 - 1100) <DFD1D9B4-41BE-30F1-A1B8-9925481B5DA2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
        0x7fff3d96a000 -     0x7fff3da80fff  com.apple.PencilKit (1.0 - 1) <924D651B-8645-3225-9DE4-BDAB27B1DED7> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
        0x7fff3da81000 -     0x7fff3da92fff  com.apple.sidecar-ui (1.0 - 231) <363E669A-2E00-3EAB-A7F1-E85836913057> /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
        0x7fff3da9e000 -     0x7fff3daa1fff  com.apple.WebInspectorUI (16611 - 16611.3.10.1.6) <D8D7C00F-BE02-3C77-9603-0ECB13AB881D> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
        0x7fff3e0b5000 -     0x7fff3e117fff  com.apple.ImageCaptureCore (1711.5.2 - 1711.5.2) <BC3B41E7-DC5A-3611-ACCA-F9827979CA03> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
        0x7fff3e118000 -     0x7fff3e13dfff  com.apple.quartzfilters (1.10.0 - 98) <B4874E51-0832-3240-8972-8375A13D372B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
        0x7fff3e13e000 -     0x7fff3e16afff  com.apple.IntlPreferences (2.0 - 332.3) <0C57D5EC-F963-33FB-A49F-43FE728EC9E5> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
        0x7fff3e16b000 -     0x7fff3e195fff  com.apple.ToneLibrary (1.0 - 1) <CFF9B577-DFDA-3856-B0F7-AC7B0E145914> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
        0x7fff3e389000 -     0x7fff3e4ebfff  com.apple.MediaPlayer (1.0 - 1.0) <C4577D13-9F8E-3AE5-9D3D-A292F2773A82> /System/Library/Frameworks/MediaPlayer.framework/Versions/A/MediaPlayer
        0x7fff3e4ec000 -     0x7fff3e7cdfff  com.apple.iTunesCloud (1.0 - 1) <CAD253D5-9CAC-368A-8EEB-8576B299256F> /System/Library/PrivateFrameworks/iTunesCloud.framework/Versions/A/iTunesCloud
        0x7fff3e7f9000 -     0x7fff3e925fff  com.apple.AnnotationKit (1.0 - 383.6) <D8726DE5-7A61-3562-9A43-5D2F5E861335> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
        0x7fff3e926000 -     0x7fff3edc6fff  com.apple.QuartzComposer (5.1 - 383) <7704093A-6C35-375F-AA17-756FABB66D1D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
        0x7fff3edc7000 -     0x7fff3eeaffff  com.apple.PDFKit (1.0 - 950.40.3) <0538C0CD-02D4-3684-BBD1-AD5C9F861276> /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
        0x7fff409b7000 -     0x7fff409c2fff  com.apple.CaptiveNetworkSupport (13.0 - 1) <B7F41903-09D2-3BED-A223-7D28603816E9> /System/Library/PrivateFrameworks/CaptiveNetwork.framework/Versions/A/CaptiveNetwork
        0x7fff40e0e000 -     0x7fff40e11fff  com.apple.quartzframework (1.5 - 25) <CB57120A-C7D9-3999-9BD4-EB214E8E3CF3> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff41236000 -     0x7fff41254fff  libCGInterfaces.dylib (544.4) <05A5B7E9-C79A-3FEA-AD6C-72FE168004C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
        0x7fff414cc000 -     0x7fff415e7fff  com.apple.AddressBook.framework (11.0 - 2452.7) <DB29F211-01A7-3C58-9E5E-DB4823738605> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
        0x7fff415e8000 -     0x7fff415fdfff  com.apple.ToneKit (1.0 - 1) <C1CA9DE4-AD93-30CB-B839-AD2C8FE13979> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
        0x7fff428d4000 -     0x7fff43634fff  libfaceCore.dylib (4.3.1) <8014C48B-E6BC-3AEB-BECE-808158C71EEE> /System/Library/Frameworks/Vision.framework/libfaceCore.dylib
        0x7fff43635000 -     0x7fff43748fff  com.apple.TextRecognition (1.0 - 157) <E100917D-A3D9-36B5-A4B0-C0E131045D87> /System/Library/PrivateFrameworks/TextRecognition.framework/Versions/A/TextRecognition
        0x7fff43749000 -     0x7fff43761fff  com.apple.Futhark (1.0 - 1) <ACB352CB-05F6-33DF-884F-97E73913C577> /System/Library/PrivateFrameworks/Futhark.framework/Versions/A/Futhark
        0x7fff437e3000 -     0x7fff43a56fff  com.apple.RawCamera.bundle (9.10.0 - 1450.3) <2F4C79D7-0A8A-3FE3-9A93-74F78774D0BC> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
        0x7fff442bf000 -     0x7fff442c3fff  com.apple.DAAPKit (1.0 - 1) <9947BB10-2335-3BB4-B884-9313DC160E59> /System/Library/PrivateFrameworks/DAAPKit.framework/Versions/A/DAAPKit
        0x7fff45c3a000 -     0x7fff45c3dfff  libpmenergy.dylib (227.140.1) <CFCE74A5-EEF8-36E2-9717-8E4B45F2663C> /usr/lib/libpmenergy.dylib
        0x7fff46329000 -     0x7fff46334fff  libGPUSupportMercury.dylib (18.5.9) <ABA75849-7AA3-30E5-A8FB-F440F3F3DAF0> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
        0x7fff4795f000 -     0x7fff4799ffff  com.apple.osanalytics.OSAnalytics (1.0 - 1) <19C9EC00-4A56-303C-9C22-47AF6222F1AF> /System/Library/PrivateFrameworks/OSAnalytics.framework/Versions/A/OSAnalytics
        0x7fff481ed000 -     0x7fff48208fff  com.apple.network.statistics.framework (1.2 - 1) <0AFE927D-702D-35F4-8938-BE33B1A95BF6> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistics
        0x7fff5161e000 -     0x7fff516bdfff  com.apple.Symbolication (12.5 - 64544.70.1) <262C27E9-D575-3209-8403-C314C534D1B0> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
        0x7fff518ad000 -     0x7fff518b0fff  libpmsample.dylib (227.140.1) <B2B85546-A9D2-3919-A396-63A26011ECAC> /usr/lib/libpmsample.dylib
        0x7fff53cc9000 -     0x7fff53cdefff  com.apple.ScriptingBridge (1.4 - 80) <DB811F94-A71E-3D96-80AC-39BAC84FC3D9> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
        0x7fff53f45000 -     0x7fff53f7bfff  com.apple.ReplayKit (1.0 - 1) <E308B8DB-49B7-3ACC-B8F3-F2338036684D> /System/Library/Frameworks/ReplayKit.framework/Versions/A/ReplayKit
        0x7fff55572000 -     0x7fff55575fff  com.apple.ForceFeedback (1.0.6 - 1.0.6) <63184EF1-A02C-3D64-A797-15190247C807> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
        0x7fff5e13d000 -     0x7fff5eba0fff  libSC.dylib (4.6.20) <C4EEC78B-6BC3-3324-9053-0A68F3F78FD4> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
        0x7fff6bab9000 -     0x7fff6babffff  libCoreFSCache.dylib (200.11) <3C96E791-3964-32EA-A84A-00DF3455B43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
        0x7fff6bac0000 -     0x7fff6bac4fff  libCoreVMClient.dylib (200.11) <966F49F6-D2D5-3ACB-9CFD-9F8D3C8C82F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff6bac5000 -     0x7fff6bad4fff  com.apple.opengl (18.5.9 - 18.5.9) <5C26B170-E22B-3AAD-BA33-61304FFA70B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff6bad5000 -     0x7fff6bad7fff  libCVMSPluginSupport.dylib (18.5.9) <435F258D-95B5-3015-BDAC-4B8EF8E89F1E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
        0x7fff6bad8000 -     0x7fff6bae0fff  libGFXShared.dylib (18.5.9) <851E0956-A16E-3F5D-B3BE-37B56C2BAA04> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff6bae1000 -     0x7fff6bb14fff  libGLImage.dylib (18.5.9) <687EBB15-1AB3-3815-A69D-58527655A92D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff6bb15000 -     0x7fff6bb51fff  libGLU.dylib (18.5.9) <29B7802C-F6E4-3DF1-B5D6-07B29C6D02B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff6bb52000 -     0x7fff6bce5fff  libGLProgrammability.dylib (18.5.9) <21D16379-6A2F-3F0A-97A8-8EEF7DC8B27B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
        0x7fff6bce6000 -     0x7fff6bcf0fff  libGL.dylib (18.5.9) <8A4ED04C-9171-3CE2-A52A-E7C4D76A6EDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff6bcf1000 -     0x7fff6be6efff  GLEngine (18.5.9) <7D972114-11BA-35EE-87DA-52C0693561FC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
        0x7fff6be6f000 -     0x7fff6be97fff  GLRendererFloat (18.5.9) <736F454D-9C9F-3391-87F7-2EC17581C926> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
        0x7fff6d130000 -     0x7fff6d188fff  com.apple.opencl (4.6 - 4.6) <713206B3-A335-3AC5-B342-4CE16BDF69F4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff6d189000 -     0x7fff6d191fff  libcldcpuengine.dylib (2.19) <3C4000BF-F1B6-329B-A698-942E632D9C14> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
        0x7fff6e0d2000 -     0x7fff6e121fff  ATIRadeonX6000SCLib.dylib (4.6.20) <91646484-7CB1-372B-9AC2-4EB20CE949C7> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/ATIRadeonX6000SCLib.dylib
        0x7fff6e232000 -     0x7fff6e239fff  com.apple.agl (3.3.4 - AGL-3.3.3) <EA70EE49-53F9-35B6-A94B-8819CDE98613> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
        0x7fff6e23a000 -     0x7fff6e321fff  com.apple.audio.AVFAudio (1.0 - 477.88) <5FBB7121-7190-317C-8796-4A64EBEE1629> /System/Library/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
        0x7fff6f8a3000 -     0x7fff6f8b5fff  com.apple.CMImaging (1.0 - 82.6) <91AA282D-81A1-34C3-AFF4-887ABA89CCAA> /System/Library/PrivateFrameworks/CMImaging.framework/Versions/A/CMImaging
        0x7fff73bb3000 -     0x7fff73bbefff  com.apple.SymptomAnalytics (1.0 - 1431.140.1) <0818E06C-B5D7-3AF4-AECD-D29EBD8CD508> /System/Library/PrivateFrameworks/Symptoms.framework/Frameworks/SymptomAnalytics.framework/Versions/A/SymptomAnalytics
        0x7fff73dd4000 -     0x7fff73decfff  com.apple.SymptomPresentationFeed (1.0 - 1431.140.1) <39660362-929E-3A0A-A7D0-80C4F437711B> /System/Library/PrivateFrameworks/Symptoms.framework/Frameworks/SymptomPresentationFeed.framework/Versions/A/SymptomPresentationFeed
        0x7fff77964000 -     0x7fff7796bfff  libRosetta.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/libRosetta.dylib
        0x7fff77bd3000 -     0x7fff77cbefff  libcrypto.0.9.8.dylib (80) <32885A0F-F97D-3817-A50E-E53B2207B9CB> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff77fdb000 -     0x7fff78016fff  libssl.0.9.8.dylib (80) <B0B3D5A4-F9F7-3C44-B177-D6D784174D67> /usr/lib/libssl.0.9.8.dylib
        0x7fff7807e000 -     0x7fff780d1fff  libstdc++.6.dylib (104.1) <665B8A03-3510-34C4-A3D9-3E73CEAA8BC3> /usr/lib/libstdc++.6.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=2.1G resident=0K(0%) swapped_out_or_unallocated=2.1G(100%)
    Writable regions: Total=13.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=13.0G(100%)
                                    VIRTUAL   REGION
    REGION TYPE                        SIZE    COUNT (non-coalesced)
    Accelerate framework               384K        3
    Activity Tracing                   256K        1
    CG backing stores                 11.2M       12
    CG image                            32K        2
    CoreAnimation                       60K        8
    CoreGraphics                        16K        3
    CoreServices                       624K        2
    CoreUI image data                  560K        5
    Foundation                          16K        1
    Kernel Alloc Once                    8K        1
    MALLOC                             2.1G      268
    MALLOC guard page                   48K       10
    MALLOC_LARGE (reserved)          500.0M        1         reserved VM address space (unallocated)
    MALLOC_MEDIUM (reserved)           1.4G       14         reserved VM address space (unallocated)
    MALLOC_NANO (reserved)           256.0M        1         reserved VM address space (unallocated)
    OpenCL                            35.9M        6
    OpenGL GLSL                        256K        3
    STACK GUARD                       57.4M      347
    Stack                            225.7M      347
    VM_ALLOCATE                        8.2G      268
    VM_ALLOCATE (reserved)           289.0M       73         reserved VM address space (unallocated)
    __DATA                           151.0M      977
    __DATA_CONST                      30.1M      342
    __DATA_DIRTY                      1858K      226
    __FONT_DATA                          4K        1
    __GLSLBUILTINS                    5176K        1
    __LINKEDIT                       901.9M      323
    __NV_CUDA                         1172K        1
    __OBJC_RO                         70.3M        1
    __OBJC_RW                         2496K        2
    __TEXT                             1.2G      816
    __UNICODE                          588K        1
    mapped file                      429.4M       69
    shared memory                     2876K       26
    TOTAL                             15.8G     4162
    TOTAL, minus reserved VM space    13.4G     4162
    Model: MacPro7,1, BootROM 1554.140.20.0.0 (iBridge: 18.16.14759.0.1,0), 12 processors, 12-Core Intel Xeon W, 3.3 GHz, 96 GB, SMC
    Graphics: AMD Radeon Pro W5700X, AMD Radeon Pro W5700X, spdisplays_pcie_device, 16 GB
    Memory Module: Slot 3 (Channel E / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    Memory Module: Slot 4 (Channel E / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 5 (Channel D / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    Memory Module: Slot 6 (Channel D / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 7 (Channel A / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 8 (Channel A / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    Memory Module: Slot 9 (Channel B / DIMM 2), 8 GB, DDR4 R-DIMM, 2933 MHz, Micron, 9ASF1G72PZ-2G9E6
    Memory Module: Slot 10 (Channel B / DIMM 1), 16 GB, DDR4 R-DIMM, 2933 MHz, Samsung, M393A2K43CB2-CVF
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Aug 10 2021 20:10:47 version 9.30.444.18.32.5.71 FWID 01-30b2601e
    Bluetooth: Version 8.0.5d7, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    Network Service: Wi-Fi, AirPort, en2
    PCI Card: AMD Radeon Pro W5700X, gpu-controller, Slot-1@9,0,0
    PCI Card: pci1002,ab38, sppci_audiodevice, Slot-1@9,0,1
    PCI Card: pci1b21,625, sppci_ahci, Thunderbolt@29,0,0
    PCI Card: XHC4, sppci_usbxhci, Thunderbolt@200,0,0
    PCI Card: pci137a,8, sppci_audio, Thunderbolt@57,0,0
    PCI Card: XHC2, sppci_usbxhci, Thunderbolt@83,0,0
    PCI Card: pci8086,15eb, sppci_thunderbolt, Thunderbolt@201,0,0
    PCI Card: pci8086,15eb, sppci_thunderbolt, Thunderbolt@84,0,0
    PCI Card: XHC3, sppci_usbxhci, Thunderbolt@24,0,0
    PCI Card: pci8086,15eb, sppci_thunderbolt, Thunderbolt@25,0,0
    Serial ATA Device: G-RAID  with Thunderbolt, 16 TB
    USB Device: USB 3.0 Bus
    USB Device: USB3.0 Hub
    USB Device: G-DRIVE USB
    USB Device: Elements 25A3
    USB Device: d2 TBT2 USB 3.0
    USB Device: Backup+  Desk M
    USB Device: USB2.0 Hub
    USB Device: iLok
    USB Device: USB-Serial (0001)
    USB Device: USB 2.0 Hub [MTT]
    USB Device: USB-C dongle
    USB Device: d2 Professional
    USB Device: Apple T2 Bus
    USB Device: Headset
    USB Device: Apple T2 Controller
    Thunderbolt Bus: Mac Pro, Apple Inc., 63.3
    Thunderbolt Device: G-RAID Thunderbolt 3 USB 3.1, G-Technology, 1, 25.2
    Thunderbolt Device: 8M, MOTU, 3, 7.7
    Mac Pro, 3.7 GHz Quad-core, 64GB RAM, G-Tech G-RAID Studio 6TB and 10TB etc. [view my complete system specs]
  • Mon, Jan 24 2022 4:35 PM In reply to
    Re: DISK_LOCKED errors and MC crashes
    Try disabling the timemachine.
    When it is active and it tries to create one, I have this Disk locked error too!
    You could use an app called timemachineeditor to change when timemachine starts backing up.
    Hope this helps,
    Jasper
    Mac Pro late 2013 3,5 Ghz 6-Core, 64Gb, OSX 10.10.5, Avid MC 8.4, Blackmagic Ultrastudio Express Macbook Pro retina 2012 15 inch i7, 16Gb, OSX 10.10.5... [view my complete system specs]
Page 1 of 1 (11 items)
