Latest post Tue, Nov 8 2022 2:20 PM by Vshevchenko. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Oct 5 2021 3:41 PM
    [Webservice API] SendToPlayback fails with the error
    Hi.
    We are trying to use the SendToPlayback function from Avid Interplay WS 2018.9.1.
    First, we call ListTransferEngines, then GetTransferDevices for "interplay-itv1" and then SendToPlayback with the corresponding parameters.
    But SendToPlayback fails with the error "An unexpected error occurred when send a asset to playback from transfer engine interplay-itv1 for interplay-itv1: 6534 / SND_TO_ARCHIVE type"
    Please, see listing below.
    Could you please help us fix current issue.
    Thank you in advance,
    Valerii.
    ListTransferEngines
    interplay-itv2
    avid-as-1
    avid-as-2
    avid-as[2]
    interplay-itv1
    Playback: FTP
    Playback: SND_TO_ARCHIVE
    SendToPlayback
    <?xml version="1.0"?>
    <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
      <SOAP-ENV:Header>
        <NS1:UserCredentials xmlns:NS1="http://avid.com/interplay/ws/assets/types">
          <Username xmlns="http://avid.com/interplay/ws/assets/types">*****</Username>
          <Password xmlns="http://avid.com/interplay/ws/assets/types">*********</Password>
        </NS1:UserCredentials>
      </SOAP-ENV:Header>
      <SOAP-ENV:Body>
        <SendToPlayback xmlns="http://avid.com/interplay/ws/transfer/types">
          <TransferEngineHostName>interplay-itv1</TransferEngineHostName>
          <InterplayURI>interplay://AvidWG?mobid=060a2b340101010101010f0013-000000-0d241b00340900fa-060e2b347f7f-d080</InterplayURI>
          <DestinationPlaybackDevice>interplay-itv1:6534/SND_TO_ARCHIVE</DestinationPlaybackDevice>
          <Priority>NORMAL</Priority>
          <Overwrite>true</Overwrite>
        </SendToPlayback>
      </SOAP-ENV:Body>
    </SOAP-ENV:Envelope>
    <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
      <soap:Body>
        <SendToPlaybackResponse xmlns="http://avid.com/interplay/ws/transfer/types" xmlns:ns2="http://avid.com/interplay/ws/assets/types">
          <Errors>
            <ns2:Error Code="OTHER_ERROR">
              <ns2:Message>An uncategorized error has occurred</ns2:Message>
              <ns2:Details>An unexpected error occurred when send a asset to playback from transfer engine interplay-itv1 for interplay-itv1:6534/SND_TO_ARCHIVE type.</ns2:Details>
            </ns2:Error>
          </Errors>
        </SendToPlaybackResponse>
      </soap:Body>
    </soap:Envelope>
  • Tue, Nov 8 2022 2:20 PM In reply to
    Re: [Webservice API] SendToPlayback fails with the error
    Hi!
    The working solution for us was to use the SubmitJobUsingParameters function instead of the SendToPlayback function, since we use Long GOP media in our configuration.
    Please find a sample request below:
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://avid.com/interplay/ws/assets/types" xmlns:typ1="http://avid.com/interplay/ws/jobs/types">
       <soapenv:Header>
          <typ:UserCredentials>
             <typ:Username>InterplayUser</typ:Username>
             <typ:Password>Test123</typ:Password>
          </typ:UserCredentials>
       </soapenv:Header>
       <soapenv:Body>
          <typ1:SubmitJobUsingParameters>
             <typ1:Service>com.avid.dms.longgopexport</typ1:Service>
             <typ1:InterplayURI>interplay://Engine-Hostname?mobid=060a2b340101010101010f0013-000000-0c351000eb7f00fb-060e2b347f7f-d080</typ1:InterplayURI>
             <typ1:Parameters>
                <!--Zero or more repetitions:-->
                <typ1:Parameter Name="MobID">060a2b340101010101010f0013-000000-0c351000eb7f00fb-060e2b347f7f-d080</typ1:Parameter>
                <typ1:Parameter Name="Audio Sample Rate">48000</typ1:Parameter>
                <typ1:Parameter Name="TapeID">Simple_Colorbar_STP_Test</typ1:Parameter>
                <typ1:Parameter Name="Overwrite">true</typ1:Parameter>
                <typ1:Parameter Name="High Priority">false</typ1:Parameter>
                <typ1:Parameter Name="Audio Bit Depth">24</typ1:Parameter>
                <typ1:Parameter Name="Output Filename">Simple_IPWS_STP_Test.mxf</typ1:Parameter>
                <typ1:Parameter Name="TMF_Export">false</typ1:Parameter>
                <typ1:Parameter Name="Priority">50</typ1:Parameter>
                <typ1:Parameter Name="TM_Server">transfer-engine-1</typ1:Parameter>
                <typ1:Parameter Name="Output Filepath">\\NEXIS\Ingest\Temp</typ1:Parameter>
                <typ1:Parameter Name="Starting Time Code"/>
                <typ1:Parameter Name="Duration"/>
                <typ1:Parameter Name="Requested Provider"/>
                <typ1:Parameter Name="DoReEncode">true</typ1:Parameter>
                <typ1:Parameter Name="TM Profile">OP1A-Export</typ1:Parameter>
             </typ1:Parameters>
          </typ1:SubmitJobUsingParameters>
       </soapenv:Body>
    </soapenv:Envelope>
