Latest post Mon, Aug 23 2021 4:36 PM by jmap. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Jul 2 2021 5:26 PM
    • chuckkahn
    • Toronto
    • Posts 423
    • Points 4,695
    Punch-in Tool does not record audio from USB microphone
    I've submitted this case to support but maybe the forum will have a suggestion.
    Punch-in Tool does not record audio from USB microphone, neither to bin nor to MXF media folder. When record button in Punch-in Tool is pressed, I can see a "creating" file appear in the "Creating" folder of my media drive path "Avid MediaFiles/MXF/1" but when I click the Stop button in the Punch-in tool, the "creating" file disappears. I see these two lines appear in the console when attempting to record with Punch-in tool for the first time:
    Reloading plugin: AudioCodecManager.avx
    Reloading plugin: CMAvidMPEG1Layer2AudioCodec.avx
    Encountered issue on version 2021.5 on High Sierra.   Upgraded to 2021.6, problem persists.
    Audio levels not appearing in meters in Avid application.
    Audio levels do appear in System Preferences / Sound / Input tab.
    Zapped PRAM, problem persists, but iMac screen is now much brighter.
    Avid Media Composer 2018.12.10 / MacOS High Sierra / iMac (Retina 5K, 27-inch, 2017) / 4.2 GHz Intel Core i7 / 64 GB 2400 MHz DDR4 [view my complete system specs]
  • Mon, Jul 5 2021 8:59 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 595
    • Points 7,450
    Re: Punch-in Tool does not record audio from USB microphone
    I can't reproduce this on my own system - although I'm using Mojave rather than High Sierra. My USB mic works fine.
    A shot in the dark though - the error seems to imply that Media Composer is either trying to create MP2 audio insead of PCM, or that it's getting MP2 audio from the USB device and doesn't like it.
    The first of these seems unlikely to me. It's possible to transcode audio into MP2 format within Avid in the Consolidate/Transcode dialogue, but I don't think MP2 can be selected as an input format.
    Regarding the second: The fact that you're not seeing audio levels in the Audio Tool ( I presume you put it into Input mode by clicking the 'O' at the top of the meter....) suggests to me that Avid doesn't 'like' the audio it's getting from the USB device. Could it be compressing the audio it's creating into MP2? You don't say what device it is.
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Mon, Jul 5 2021 11:56 AM In reply to
    • chuckkahn
    • Toronto
    • Posts 423
    • Points 4,695
    This USB Condenser microphone was working on June 28, at least as far as creating files in the MXF/1 path but not creating clips in the bin.  If I selected the internal microphone of the Thunderbolt Display -- that creates files in the MXF/1 path and shows levels.  But not when I switch the Punch-in Tool to USB Condenser Microphone.  This is the device:
    https://www.amazon.ca/gp/product/B07M7BHYT1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  • Mon, Jul 5 2021 3:22 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 595
    • Points 7,450
    Hmm, I see your mic works at 192kHz  sample rate. I honestly don't know if Media Composer supports this for input - it may be the problem. Do let us all know what Support say.
  • Mon, Jul 5 2021 10:09 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 423
    • Points 4,695
    I did go into MacOS's Audio MIDI Setup and tried all the kHz's.   No fix there.
  • Tue, Aug 17 2021 2:35 PM In reply to
    • jmap
    • Joined on Tue, Aug 17 2021
    • Toronto
    • Posts 3
    • Points 25
    Any updates on this? I've had this exact issue off and on the past few years on mac and pc. Avid recognizes the mic, MXF media is created but clip doesn't appear in bin or timeline. Sometimes it sorts itself out, no idea how or why. I've been using the Rode NT-USB and half the time I need to jump into something like Adobe Audition to record scratch and V/O.
    Avid Media Composer 2021.5.0 / MacOS Big Sur / iMac (Retina 5K 27 inch 2020) / 3.6GHz 10-Core Intel i9 / 128 GB 2667 MHz DDR4 / AMD Radeon Pro 5700XT [view my complete system specs]
  • Thu, Aug 19 2021 11:33 AM In reply to
    • chuckkahn
    • Toronto
    • Posts 423
    • Points 4,695
    It seems to be due to the Film option being on for 23.98 projects.  When I create a 29.97 or 23.98 project with the Film option off, it works.   Also make sure the Audio project settings level is not at zero.
  • Thu, Aug 19 2021 11:48 AM In reply to
    Under Audio Project settings do you have the built in Mic selected?
    My IMac also has 2 other inputs I can select.
    Is input monitoring selected as ON?
    T 07581 201248 | E pat@vet-training.co.uk | www.vet-training.co.uk|
  • Sat, Aug 21 2021 1:16 AM In reply to
    • Jolo9254
    • Joined on Sun, Aug 15 2021
    • Posts 5
    • Points 45
    Same problem on 2021.6 Catalina. Sometimes I can see the file in the MXF folder, sometimes not. Have never got it to work, I'm stuck using Capture Tape Tool :(
  • Mon, Aug 23 2021 4:30 PM In reply to
    • jmap
    • Toronto
    • Posts 3
    • Points 25
    Hey thanks for this. This seems to be the case for me, I tested with another microphone plugged into a Focusrite Scarlett Solo thinking the interface might help but ran up against the same issues. Won't be changing that setting as we tend to perf slip a lot but I'm am so happy to finally have an answer for this!! Thanks again!
  • Mon, Aug 23 2021 4:36 PM In reply to
    • jmap
    • Toronto
    • Posts 3
    • Points 25
    Thanks Pat, yea I had gone through all those settings. In my case it seems to be what @chuckkahn said. My project relys on the the film option for perf slipping. Which has the unfortunate side effect of messing with the punch in tool.
