Latest post Tue, May 25 2021 11:16 AM by gergelyv. 0 replies.
Page 1 of 1 (1 items)
  • Tue, May 25 2021 11:16 AM
    • gergelyv
    • Joined on Fri, May 21 2021
    • Posts 6
    • Points 50
    Generate EDL of a sequence via Web Services
    Hi All,
    I was wondering if it is possible to generate EDL like data out of a sequence via Web Services.
    I would need all the referenced master clips along with the information regarding the duration, startTC and endTC of each segment of that master clip.
    I would like to create similar output as seen below.
    TITLE:   Untitled Sequence.01
    FCM: NON-DROP FRAME
    000001  TEST_1080_25P_DNXHD_120 A3/V  C        01:00:00:00 01:01:00:00 01:00:00:00 01:01:00:00
    M2      TEST_1080_25P_DNXHD_120          025.0 01:00:00:00
    *FROM CLIP NAME:  TEST_1080_25P_DNXHD_120
    *PATCH TEST_1080_25P_DNXHD_120:  FROM SOURCE 2 TO RECORD 3
    *SOURCE FILE: TEST_1080_25P_DNXHD_120
    000002  1_76.WAV                A2    C        01:02:30:05 01:02:48:20 01:00:05:02 01:00:23:17
    *FROM CLIP NAME:  1_76.WAV
    *A2 VOL = -25.4 DB  PAN L100
    *PATCH 1_76.WAV:  FROM SOURCE 1 TO RECORD 2
    *SOURCE FILE: 1_76.WAV
    000003  1_76.WAV                A     C        01:02:30:05 01:02:59:22 01:00:08:11 01:00:38:03
    000004  GABOR-PITCHII_02.WAV    A2    C        01:04:42:06 01:04:49:09 01:00:40:04 01:00:47:07
    *FROM CLIP NAME:  GABOR-PITCHII_02.WAV
    *A2 VOL = -11.2 DB  PAN L100
    *PATCH GABOR-PITCHII_02.WAV:  FROM SOURCE 1 TO RECORD 2
    *SOURCE FILE: GABOR-PITCHII_02.WAV
