Latest post Mon, Jan 6 2025 8:16 PM by chuckkahn. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Mar 2 2021 10:22 PM
    • roddeo
    • Joined on Tue, Mar 2 2021
    • Posts 1
    • Points 15
    ScriptSync feature requests
    Hi.
    Love ScriptSync. But wish it could do these:
    1. Change Script Line length without using command+click+drag. Maybe select a row along with a script line and enter a hotkey that either shortens it from the beginning or the end.
    2. Faster way to change image in the Poster Frame without using step +. Almost like in the Scene Bins where you can play the Poster Frame/Thumbnail so its faster
    3. Keep script visible when scrolling horizontally. If there are a lot of slates/takes, the script disappears as you scroll right. Have a "Freeze Pane" option where the Script stays put.
    4. If you stop while auditioning several lines, have the ability to continue from where you left off.
    5. Ability to add comments to Script Lines like pop-up windows in Excel.
    6. The automated ScriptSync should search phonetically in order of how they are being found. So if it finds a phrase and makes a Script Mark, the next phrase should only be searched AFTER that mark.
    Thank you!
    R
  • Mon, Jan 6 2025 8:16 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 479
    • Points 5,315
    Re: ScriptSync feature requests
    #3 - this would be great especially when dealing with a lot of take lines
    Avid Media Composer 2023.3 / MacOS Big Sur 11.7.10 / iMac (Retina 5K, 27-inch, 2017) / 4.2 GHz Intel Core i7 / 64 GB 2400 MHz DDR4 [view my complete system specs]
