Latest post Mon, Feb 15 2021 2:19 PM by Roland Achini. 2 replies.
  • Sun, Feb 14 2021 1:30 PM
    Export of long timelines as DNxHD HQX
    I have no problems to export sequences with a length up to 8 minutes, however I cannot export very long sequences, e.g. the timeline of the whole project (54 minutes). After a short time export tops and the message "out of memory" appears.
    All clips are 1920x1080 50p.
    MB: ASRock Z390 Taichi Ultimate. CPU: Intel Eight Core i9-9900K/3600 16MB Cache, SATA Hard Disks Raid (2x4 TB), GPU 1200MHz. GC: Gainward RTX2080 Super... [view my complete system specs]
  • Sun, Feb 14 2021 4:17 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,945
    • Points 47,605
    Re: Export of long timelines as DNxHD HQX
    Sounds sort of like the following:
    https://community.avid.com/forums/p/200659/899643.aspx#899643
    Unfortunately no resolution.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Mon, Feb 15 2021 2:19 PM In reply to
    Problem solved
    I took the following steps in the order given:
    1. upgraded Media Composer to latest version 21.2.0.
    2. checked memory usage, is ok.
    3. rebooted the computer properly as described in
    https://blog.frame.io/2018/02/19/avid-media-composer-troubleshooting-tips
    Of course, I should have checked after each step to see if the problem was solved, but was too lazy to do so.
