I got this to work once on an android tablet, but the second time I tried to connect it wouoldn't work.
I followed the same steps in both instances. In the second instance the EU Control application would see my table, but not allow me to drag it to the right window and add it as a control surface, nor would the 'ADD' button work.
Anyone got any ideas?
I'm on windows 10 running 2020.10
Hi Mike I was playing with this the other day and got it to work ok on my android phone. Here's a link to a post I made about the experience, maybe it will help:
https://community.avid.com/forums/p/199440/902362.aspx#902362
Are the tablet and windows machine definitely on the same wifi network? I found that once I had set up my phone i didn't need to re-add it to the control surfaces panel, just needed to make sure MC was set to EUCON controller in the settings.
Andi
Hi, thank you for your reply.
I have done everything you listed in the link you provided. It worked the first time I tried it, but on subsequent attempts I cannot do this...
"In the EuControl settings you should see your tablet/phone etc on the left panel (All Surfaces). Drag it to the right panel (My Surfaces)."
It won't let me drag my tablet to the 'My Surfaces' and the 'Add->' button doesn't work either
thank u for a answer
I have been looking for the solution enverywhere, thank you so much
escape road
