Latest post Sat, Feb 6 2021 1:21 PM by LDV20. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Feb 5 2021 4:43 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 376
    • Points 4,475
    Does MC handle red IPP2?
    DP I might use shoots with a RED -he wants to use IPP2.   He explained the benefits to me and said I red app/plugin is available for MC.  I did some poking around on the internet but could not find a proper answer.  I am not familair with this process - wondering if anyone knows about it or can tell me the upside and downside from a post production point of view.
    Thank you
    Larry
    Symphony 2021.5 - Win 10 pro (20H2),Gigabyte X299X with i9 10920X CPU, Quadro P2000,driver 461.72; 64gig memory, 1TB NV system drive, WD 4TB, BM Min Monitor... [view my complete system specs]
  • Fri, Feb 5 2021 4:53 PM In reply to
    Re: Does MC handle red IPP2?
    MC version 2020.9 and newer
    https://avid.secure.force.com/pkb/articles/en_US/Download/en394823
    Though the Source Settings color tab is limited if you are looking for full control of RED RAW. You may want to incoporate RedCine-X Pro application to your workflow.
    http://docs.red.com/955-0004_v50/REDCINE-XProOperationGuide/Content/1_RCXP_Intro/RCX.htm
    MC 2022, W10, MSI X299M, Intel 9940X, Gigabyte 3080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Big... [view my complete system specs]
  • Fri, Feb 5 2021 5:05 PM In reply to
    • LDV20
    • Posts 376
    • Points 4,475
    Thank you -  will reserach it.  However the I wont be cutting it and the editor I use is still on 2018.7 or something as he needs to stay in the same version as many of his clients and other edit houses.
  • Fri, Feb 5 2021 5:22 PM In reply to
    The previous version may support it also but may not support the gamma curves:
    "RED Image Processing Pipeline 2 with REDWideGamutRGB color space and Log3G10 gamma curve (Available with Media Composer 2020.9 and later.)"
  • Fri, Feb 5 2021 5:59 PM In reply to
    • LDV20
    • Posts 376
    • Points 4,475
    Thanks Dom -   I will do a test and send him the footage before I make any decision.  Might just stilck with the legacy Red - and avoid any complications.  I still need to wrap my head around this and will also play around with test footage on my MC which should work since it is 2020.12 -
    thank you
    Larry
  • Fri, Feb 5 2021 9:33 PM In reply to
    • Steve Thomas
    • Joined on Thu, Jan 22 2015
    • Jacksonville, FL
    • Posts 7
    • Points 95
    Yes - RED IPP2 is supported with the latest Avid AMA/Link plugin. Output transform tone mapping is included per camera metadata. As stated above, there are fewer raw options compared to Redcine-x but definitely enough for broad adjustments.
    Mac Pro 2019 3.3GHz 12-Core Intel Xeon W 96GB AMD Radeon Pro Vega II 32GB MacBook Pro 16 2019 2.3 GHz 8-Core Intel Core i9 32GB AMD Radeon Pro 5500M 8GB... [view my complete system specs]
  • Sat, Feb 6 2021 1:21 PM In reply to
    • LDV20
    • Posts 376
    • Points 4,475
    Thank you Steve - getting test footage to try with 2020.12
