Latest post Fri, Jan 15 2021 5:05 PM by TVJohn. 28 replies.
Page 1 of 2 (29 items) 1 2 Next >
  • Wed, Jan 13 2021 3:22 PM
    • Squatter1
    • Joined on Wed, Dec 16 2015
    • Posts 24
    • Points 345
    Media Composer no longer plays anything
    Hi there
    Returning to use MC for the first time in a couple of months I find that no media will play either in the timeline or source window.
    Everything looks good, I can import/load video and drag through it to see it's there, but when I hit play, the play arrow goes green, the volume meters fill up, but not a single frame/sound is played. The same applies to previous projects of mine - everything loads up, I can see it all, load it into the monitors/timeline, drag through it, but not play.
    Last time I used MC everything was fine. But since then, I have installed 4GB extra RAM, and cloned my hard drive onto an SSD. All of this went swimmingly, and everything else on the computer has been working fine (better than every, actually, as you'd expect).
    Would really appreciate any thoughts folks might have as to what's going wrong here.
    Thanks in advance, tech specs below
    MC 2020.4
    Specs; Windows 10 Home PC, Intel i5-4590 @ 3.30 GHz, 16GB RAM, NVIDIA GeForce GTX 960, 64 bit opertating. 1TB SSD (Western Digital)
  • Wed, Jan 13 2021 3:46 PM In reply to
    Re: Media Composer no longer plays anything
    Quit Media Composer and delete the following settings from the directory below:
    C:\Users\Public\Documents\Avid Media Composer\Settings
    MCState
    Site_Attributes
    Site_Settings
    Restart Media Composer and see if that helps. If not, what I/O are you using and is it active and communicating with Media Composer? (Should be labelled at the top of the screen). Try to then disable H/W and see if that helps.
  • Wed, Jan 13 2021 4:11 PM In reply to
    • Squatter1
    • Posts 24
    • Points 345
    Thanks for the suggestions - appreciate it.
    I delted those settings files but sadly didn't solve it.
    Regarding I/O, and H/W, I'm sorry I don't understand the abbreviations - could you expand?
    MC 2020.4
  • Wed, Jan 13 2021 5:05 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,398
    • Points 54,340
    Sounds like the Video Driver. Was it updated?
    Using MC 20.10. Win 20H2  Avid FX6.4, Vegas Pro 18/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Wed, Jan 13 2021 6:47 PM In reply to
    • Squatter1
    • Posts 24
    • Points 345
    I just checked my NVIDIA GTX driver was up to date and it is.
    Is there another video driver I should be looking at?
    MC 2020.4
  • Wed, Jan 13 2021 6:55 PM In reply to
    Squatter1:
    If you're running 2020.4 (that's what's in your profile), take a look at page 36 of the Readme for what video driver you should be using:
    http://resources.avid.com/SupportFiles/attach/README_Avid_Editor_v20.4.pdf
    Media Composer 2020.12 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Wed, Jan 13 2021 7:24 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,398
    • Points 54,340
    As GeForce cards are not officially suported, you may have to tinker a bit.
  • Wed, Jan 13 2021 7:33 PM In reply to
    • Squatter1
    • Posts 24
    • Points 345
    Thanks - so I checked which NVIDIA driver 2020.4 supports and it is a driver which is not compatible with my Geforce card.
    However, the driver listed in the Avid manual is dated from Nov 2019. I was using MC without issue until Dec 2020.
    Does this mean I either have to buy a new graphics card (I'd much rather not)
    Or can I rollback the version of MC that I am using to whichever version was current two months ago, as everything worked at that point? If so, how to I rollback?
    Many thanks, appreciate the help
    MC 2020.4
  • Wed, Jan 13 2021 8:52 PM In reply to
    Squatter1:
    All the previous versions of Media Composer can be found in the Download Center (scroll down; they're not in order):
    https://esd.avid.com/ProductInformation.aspx?id=7
    I've only needed to downgrade a few times, but when I did I just ran the installer for whatever version I wanted to downgrade to, and let it uninstall the previous version.
    To be extra safe, I backup my Avid Projects and Avid Users folders, and make sure my Avid media is safe before installing an older version.
  • Wed, Jan 13 2021 9:32 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,398
    • Points 54,340
    This is a laptop? The GTX 860 is defined as a mobile "card" which is probably a permanent component of the motherboard. I'd try a driver a couple of years old if possible.Sometimes you, in case of a mobile pc have to source the driver from the Laptop manufacturer as there may have been customizations.
  • Wed, Jan 13 2021 10:54 PM In reply to
    • Squatter1
    • Posts 24
    • Points 345
    Ok I'll give that I try.
    Really, thanks for the input, so great have this kind of support.
    I'll let you know how I get on.
    MC 2020.4
  • Wed, Jan 13 2021 10:55 PM In reply to
    • Squatter1
    • Posts 24
    • Points 345
    "This is a laptop? The GTX 860 is defined as a mobile "card" which is probably a permanent component of the motherboard. "
    Aargh - I made an error in my spec. It's a GTX 960, desktop. Have changed my signature.
    Thanks a lot for the response in any case.
    MC 2020.4
  • Wed, Jan 13 2021 11:02 PM In reply to
    Squatter1:
    Might be worth trying some older drivers for that card.
  • Thu, Jan 14 2021 12:01 AM In reply to
    • Squatter1
    • Posts 24
    • Points 345
    The driver I have is from Aug 2020, and MC was working great up until Dec 2020. Nevertheless do you think it's still worth me trying older drivers on the card?
    MC 2020.4
  • Thu, Jan 14 2021 2:47 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,398
    • Points 54,340
    I see that that Intel CPU includes on chip graphics. Normally turned off in BIOS when a descrete video card is installed. Did you reset the BIOS to default that likely would have re-enabled the on board graphics? Could have happened when you added the menory and new SSD.
